Problem ipw2200/Radio Frequency Kill Switch is On [LÖST]
labbetuss
Inlägg av labbetuss »
Hei
Får ikke opp mit trådløse nettverk. Iwconfig:Radio off. I message:" ipw2200:Radio Frequency Kill is on. Kill Switch must be turned off for wireless networking to work."
WLan knappen på tastaturet virker bare under Windows. Hvordan får man slått av denne Killer Switchen ???
Emil.s
SV: Problem ipw2200/Radio Frequency Kill Switch is On
Inlägg av Emil.s »
Hm, har egentligen ingen aning.
Vad har du för kort?
Kör "lspci -v" i terminalen och klistra in här. :)
labbetuss
lspci -v:
00:00.0 Host bridge: Intel Corporation 82855PM Processor to I/O Controller (rev
21)
        Subsystem: Wistron Corp. Unknown device 4010
        Flags: bus master, fast devsel, latency 0
        Memory at e0000000 (32-bit, prefetchable) [size=256M]
        Capabilities: [e4] Vendor Specific Information
        Capabilities: [a0] AGP version 2.0
00:01.0 PCI bridge: Intel Corporation 82855PM Processor to AGP Controller (rev 2
1) (prog-if 00 [Normal decode])
        Flags: bus master, 66MHz, fast devsel, latency 96
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
        I/O behind bridge: 00003000-00003fff
        Memory behind bridge: d0100000-d01fffff
        Prefetchable memory behind bridge: d8000000-dfffffff
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) U
SB UHCI Controller #1 (rev 03) (prog-if 00 [UHCI])
        Subsystem: Wistron Corp. Unknown device 4001
        Flags: bus master, medium devsel, latency 0, IRQ 11
        I/O ports at 1800
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) U
SB UHCI Controller #2 (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 10
        I/O ports at 1820
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) U
SB UHCI Controller #3 (rev 03) (prog-if 00 [UHCI])
        I/O ports at 1840
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Co
ntroller (rev 03) (prog-if 20 [EHCI])
        Subsystem: Wistron Corp. Unknown device 1071
        Memory at d0000000 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
        Capabilities: [58] Debug port
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 83) (prog-if
00 [Normal decode])
        Bus: primary=00, secondary=02, subordinate=0a, sec-latency=32
        I/O behind bridge: 00004000-00004fff
        Memory behind bridge: d0200000-d02fffff
        Prefetchable memory behind bridge: 30000000-39ffffff
00:1f.0 ISA bridge: Intel Corporation 82801DBM (ICH4-M) LPC Interface Bridge (re
v 03)
00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 0
3) (prog-if 8a [Master SecP PriP])
        I/O ports at 01f0
        I/O ports at 03f4
        I/O ports at 0170
        I/O ports at 0374
        I/O ports at 1860
        Memory at 3a000000 (32-bit, non-prefetchable) [size=1K]
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Cont
roller (rev 03)
        Flags: medium devsel, IRQ 10
        I/O ports at 1880
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH
4-L/ICH4-M) AC'97 Audio Controller (rev 03)
        Subsystem: Wistron Corp. Unknown device 200b
        I/O ports at 1c00
        I/O ports at 18c0 [size=64]
        Memory at d0000c00 (32-bit, non-prefetchable) [size=512]
        Memory at d0000800 (32-bit, non-prefetchable) [size=256]
00:1f.6 Modem: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Mode
m Controller (rev 03) (prog-if 00 [Generic])
        Subsystem: Wistron Corp. Unknown device 10ac
        I/O ports at 2400 [size=256]
        I/O ports at 2000 [size=128]
01:00.0 VGA compatible controller: ATI Technologies Inc RV350 [Mobility Radeon 9
600 M10] (prog-if 00 [VGA])
        Subsystem: Wistron Corp. Unknown device 2072
        Flags: bus master, fast Back2Back, 66MHz, medium devsel, latency 255, IR
Q 11
        Memory at d8000000 (32-bit, prefetchable) [size=128M]
        I/O ports at 3000 [size=256]
        Memory at d0100000 (32-bit, non-prefetchable) [size=64K]
        [virtual] Expansion ROM at d0120000 [disabled] [size=128K]
        Capabilities: [58] AGP version 2.0
02:04.0 CardBus bridge: Texas Instruments PCIxx21/x515 Cardbus Controller
        Subsystem: Wistron Corp. Unknown device 3007
        Flags: bus master, medium devsel, latency 168, IRQ 11
        Memory at d020a000 (32-bit, non-prefetchable) [size=4K]
        Bus: primary=02, secondary=03, subordinate=06, sec-latency=176
        Memory window 0: 30000000-33fff000 (prefetchable)
        Memory window 1: 3c000000-3ffff000
        I/O window 0: 00004000-000040ff
        I/O window 1: 00004400-000044ff
        16-bit legacy interface ports at 0001
02:04.1 CardBus bridge: Texas Instruments PCIxx21/x515 Cardbus Controller
        Flags: bus master, medium devsel, latency 168, IRQ 10
        Memory at d020b000 (32-bit, non-prefetchable) [size=4K]
        Bus: primary=02, secondary=07, subordinate=0a, sec-latency=176
        Memory window 0: 34000000-37fff000 (prefetchable)
        Memory window 1: 40000000-43fff000
        I/O window 0: 00004800-000048ff
        I/O window 1: 00004c00-00004cff
02:04.2 FireWire (IEEE 1394): Texas Instruments OHCI Compliant IEEE 1394 Host Co
ntroller (prog-if 10 [OHCI])
        Flags: bus master, medium devsel, latency 64, IRQ 10
        Memory at d0209000 (32-bit, non-prefetchable) [size=2K]
        Memory at d0200000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [44] Power Management version 2
02:04.3 Mass storage controller: Texas Instruments PCIxx21 Integrated FlashMedia                                            Controller
        Flags: bus master, medium devsel, latency 64, IRQ 11
        Memory at d0204000 (32-bit, non-prefetchable) [size=8K]
02:05.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
        Subsystem: Symphony Labs Unknown device 170c
        Flags: bus master, fast devsel, latency 64, IRQ 10
        Memory at d0206000 (32-bit, non-prefetchable) [size=8K]
        [virtual] Expansion ROM at 38000000 [disabled] [size=128K]
        Capabilities: [40] Power Management version 2
02:06.0 Network controller: Intel Corporation PRO/Wireless 2200BG Network Connec                                            tion (rev 05)
        Subsystem: Intel Corporation Unknown device 2701
        Memory at d0208000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [dc] Power Management version 2
Hjalp det ???
labbetuss
Hei igjen(åter)
Problemet løst. Lå på hardwaret i min Mediom. Gikk inn i Bios Satte Wifi til Last State og voila ;D
Så får jeg prøve meg på WPA-PSK :P
