NOTE 1: This worked for me with my card (lspci says "ATI Technologies Inc Radeon R250 [Mobility FireGL 9000] (rev 01)"). Your mileage may wary. Also, as I'm writing this after I got this to work there might be some errors in the description below. If you find one please let me know.
NOTE 2: DRI doesn't seem to work for me right now. I haven't looked into it any further. Let me know if you get it to work.
Instructions
To downgrade x.org I had to add the Edgy repositories to /etc/apt/sources.list. Just copy the lines for feisty and replace feisty with edgy. Here's what my sources.list looks like:
Code:
deb http://dk.archive.ubuntu.com/ubuntu/ feisty main restricted universe multiverse
deb-src http://dk.archive.ubuntu.com/ubuntu/ feisty main restricted universe multiverse
deb http://dk.archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb-src http://dk.archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb http://dk.archive.ubuntu.com/ubuntu/ edgy main restricted universe multiverse
deb-src http://dk.archive.ubuntu.com/ubuntu/ edgy main restricted universe multiverse
deb http://dk.archive.ubuntu.com/ubuntu/ edgy-updates main restricted
deb-src http://dk.archive.ubuntu.com/ubuntu/ edgy-updates main restricted
Code:
APT::Default-Release "feisty";
Code:
Package: xorg
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-dev
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-core
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-all
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-mouse
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-video-all
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-video-ati
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-evdev
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-kbd
Pin: release a=edgy
Pin-Priority: 1001
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-synaptics
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-wacom
Pin: release a=edgy
Pin-Priority: 1001
Package: xserver-xorg-input-elographics
Pin: release a=edgy
Pin-Priority: 1001
Code:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xserver-xorg-core
The final step is to download Envy and use it to install the fglrx driver. It will detect the card you have and download the correct driver:
Code:
wget http://albertomilone.com/ubuntu/nvidia/scripts/envy_0.9.1-0ubuntu4_all.deb
sudo dpkg -i envy_0.9.1-0ubuntu4_all.deb
sudo apt-get -f install
sudo envy -t
