Jag är fortfarande n00b på detta
patric@juggernaut:/tmp/Linux$ make
gcc -D__KERNEL__ -I/usr/src/linux/include -DCPU=586 -march=i586 -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -fno-strict-aliasing -pipe -DMODULE -c pl2303.c
In file included from pl2303.c:12:
/usr/include/linux/config.h:1:2: error: #error "Compilation aborted. Please read the FAQ for linux-libc-headers package."
/usr/include/linux/config.h:2:2: error: #error "(can be found at http://ep09.pld-linux.org/~mmazur/linux ... aders/doc/)"
In file included from /usr/include/linux/sched.h:16,
from pl2303.c:14:
/usr/include/linux/signal.h:2:2: warning: #warning "You should include <signal.h>. This time I will do it for you."
In file included from /usr/include/linux/resource.h:4,
from /usr/include/linux/sched.h:79,
from pl2303.c:14:
/usr/include/linux/time.h:9: error: redefinition of ‘struct timespec’
/usr/include/linux/time.h:15: error: redefinition of ‘struct timeval’
/usr/include/linux/time.h:20: error: redefinition of ‘struct timezone’
/usr/include/linux/time.h:47: error: redefinition of ‘struct itimerval’
In file included from pl2303.c:15:
pl2303.c:19:24: error: linux/slab.h: No such file or directory
pl2303.c:22:30: error: linux/tty_driver.h: No such file or directory
pl2303.c:23:28: error: linux/tty_flip.h: No such file or directory
In file included from pl2303.c:24:
/usr/include/linux/module.h:41: error: field ‘attr’ has incomplete type
/usr/include/linux/module.h:49: error: field ‘kobj’ has incomplete type
In file included from /usr/include/linux/spinlock.h:1,
from pl2303.c:25:
/usr/include/linux/err_kernel_only.h:1:2: error: #error Kernel only header included in userspace
In file included from usb-serial.h:40,
from pl2303.c:33:
In file included from pl2303.c:33:
usb-serial.h:72: error: syntax error before ‘wait_queue_head_t’
usb-serial.h:72: warning: no semicolon at end of struct or union
usb-serial.h:76: error: syntax error before ‘port_lock’
usb-serial.h:76: warning: type defaults to ‘int’ in declaration of ‘port_lock’
usb-serial.h:76: warning: data definition has no type or storage class
usb-serial.h:79: error: syntax error before ‘}’ token
usb-serial.h:92: error: array type has incomplete element type
usb-serial.h:117: error: field ‘driver_list’ has incomplete type
usb-serial.h:127: warning: ‘struct file’ declared inside parameter list
usb-serial.h:127: warning: its scope is only this definition or declaration, which is probably not what you want
usb-serial.h:128: warning: ‘struct file’ declared inside parameter list
usb-serial.h:131: warning: ‘struct file’ declared inside parameter list
usb-serial.h:132: warning: ‘struct termios’ declared inside parameter list
usb-serial.h: In function ‘serial_paranoia_check’:
usb-serial.h:164: warning: implicit declaration of function ‘dbg’
usb-serial.h: In function ‘port_paranoia_check’:
usb-serial.h:188: error: dereferencing pointer to incomplete type
usb-serial.h:193: error: dereferencing pointer to incomplete type
usb-serial.h:198: error: dereferencing pointer to incomplete type
usb-serial.h: In function ‘get_usb_serial’:
usb-serial.h:209: error: dereferencing pointer to incomplete type
usb-serial.h:215: error: dereferencing pointer to incomplete type
pl2303.c: At top level:
pl2303.c:42: warning: ‘struct file’ declared inside parameter list
pl2303.c:43: warning: ‘struct file’ declared inside parameter list
pl2303.c:45: warning: ‘struct termios’ declared inside parameter list
pl2303.c:47: warning: ‘struct file’ declared inside parameter list
pl2303.c:53: error: array type has incomplete element type
pl2303.c:54: warning: implicit declaration of function ‘USB_DEVICE’
pl2303.c:58: error: array type has incomplete element type
pl2303.c:78: warning: initialization from incompatible pointer type
pl2303.c:79: warning: initialization from incompatible pointer type
pl2303.c:83: warning: initialization from incompatible pointer type
pl2303.c:84: warning: initialization from incompatible pointer type
make: *** Deleting file `pl2303.o'
make: *** [pl2303.o] Interrupt
