Mer ftp problem
look2
Mer ftp problem
Inlägg av look2 »
Nu har jag stött på lite mer problem. Försökte att köra ftp via ssl men det gick inte så vidare bra.
Min vsftp.conf ser ut som följande.
listen=YES
anonymous_enable=NO
local_enable=YES
write_enable=YES
local_umask=077
dirmessage_enable=YES
xferlog_enable=YES
# connect_from_port_21=YES
pasv_min_port=50505
pasv_max_port=50505
# pasv_promiscuous=YES
ftpd_banner=Välkommen till ....
chroot_local_user=YES
ls_recurse_enable=YES
secure_chroot_dir=/var/run/vsftpd
pam_service_name=vsftpd
## SSL - krypterad trafik
ssl_enable=YES
force_local_logins_ssl=NO
force_local_data_ssl=NO
rsa_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
rsa_private_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
Använder filezilla för att försöka ansluta och den säger såhär:
Status:	Connecting to 90.xxx.xxx.xxx ...
Status:	Connected with 90.xxx.xxx.xxx, negotiating SSL connection...
Response:	220 Välkommen till ....
Command:	AUTH SSL
Response:	234 Proceed with negotiation.
Status:	SSL connection established. Waiting for welcome message...
Command:	USER ftp
Response:	331 Please specify the password.
Command:	PASS ********
Response:	230 Login successful.
Command:	SYST
Response:	215 UNIX Type: L8
Command:	FEAT
Response:	211-Features:
Response:	 AUTH SSL
Response:	 AUTH TLS
Response:	 EPRT
Response:	 EPSV
Response:	 MDTM
Response:	 PASV
Response:	 PBSZ
Response:	 PROT
Response:	 REST STREAM
Response:	 SIZE
Response:	 TVFS
Response:	211 End
Command:	PBSZ 0
Response:	200 PBSZ set to 0.
Command:	PROT P
Response:	200 PROT now Private.
Status:	Connected
Status:	Retrieving directory listing...
Command:	PWD
Response:	257 "/"
Command:	CWD /
Response:	250 Directory successfully changed.
Command:	PWD
Response:	257 "/"
Command:	TYPE A
Response:	200 Switching to ASCII mode.
Command:	PASV
Response:	227 Entering Passive Mode (192,168,0,100,197,73)
Command:	LIST
Error:	Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Error:	Could not retrieve directory listing
Command:	REST 0
Error:	Timeout detected!
Och jag ser inte mapparna som skall finnas där, om jag kör utan SSL så fungerar det.
I routern så är port 21 och 50505 öppnade och pekar mot servern. Nån som har nån idé vad som kan vara fel?
Upptäckte en sak, när jag kör utan ssl så står det "entering passive mode 90.xxx.xxx.xxx" alltså min publika ipadress.
med ssl så står det min interna ipadress istället. Kan det betyda nånting?
http://stoppa-storebror.se/
http://stoppafralagen.nu/
server med Fiesty Fawn server edition
HP NC40xx Fiesty Fawn 8.10
HP Pavillion 9095ea Windows XP
