Mumbles
Okänd
Mumbles
Inlägg av Okänd »
Nytt projekt som skickar meddelanden av olika slag...
Komposit såklart... ;D
http://www.mumbles-project.org/about
http://sourceforge.net/project/screensh ... _id=193587
Kan man väl "pillra" lite med... :D
invaderjohn
SV: Mumbles
Inlägg av invaderjohn »
lyckades inte instalera det :/
john@ubuntu:~$ sudo '/home/john/.mumbles-0.3/setup.py'
Password:
cd: 1: can't cd to ./src/plugins/gaim
python: can't open file 'setup.py': [Errno 2] No such file or directory
cd: 1: can't cd to ./src/plugins/rhythmbox
cd: 1: can't cd to ./src/plugins/generic
Installation Complete. You can now run mumbles by typing ./mumbles
Okänd
SV: Mumbles
Inlägg av Okänd »
Du måste göra så här.....
plun@dunder:~$ cd /home/plun/mumbles
plun@dunder:~/mumbles$ ./setup.py
running develop
Checking .pth file support in ..
/usr/bin/python -E -c pass
running egg_info
creating GaimMumbles.egg-info
writing GaimMumbles.egg-info/PKG-INFO
writing top-level names to GaimMumbles.egg-info/top_level.txt
writing dependency_links to GaimMumbles.egg-info/dependency_links.txt
writing entry points to GaimMumbles.egg-info/entry_points.txt
writing manifest file 'GaimMumbles.egg-info/SOURCES.txt'
reading manifest file 'GaimMumbles.egg-info/SOURCES.t
Men det är lite dåligt med "pluggar" just nu.... ;)
