compiz och ati
jonkan
compiz och ati
Inlägg av jonkan »
har presis lagt in nya drivare till mitt grafikkort och fixat så jag kan köra 1280x800 och fixat och donat lite. men nu så funkar varken compiz och beryl. skrivbordet blinkar lite bara och sen så händer inge mer.
någom som vet vad det kan vara för fel?
MVH JOhnny
jonkan
SV: compiz och ati
Inlägg av jonkan »
så ser min xorg.conf ut. någe som ska ändras?
är ganska ny imon linux =D
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#  sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
Fontpath "/usr/share/fonts/X11/misc"
Fontpath "/usr/share/fonts/X11/cyrillic"
Fontpath "/usr/share/fonts/X11/100dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/75dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/Type1"
Fontpath "/usr/share/fonts/X11/100dpi"
Fontpath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
Fontpath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "se"
Option "XkbOptions" "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/wacom"# Change to
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
# /dev/input/event
# for USB
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
# /dev/input/event
# for USB
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
# /dev/input/event
# for USB
EndSection
Section "Device"
Identifier "ATI Technologies Inc Radeon Mobility X700 (PCIE)"
Driver "fglrx"
Busid "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc Radeon Mobility X700 (PCIE)"
Monitor "Generic Monitor"
Defaultdepth 24
SubSection "Display"
Depth 1
Modes "1280x800" "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
  screen "Default Screen"
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
Inputdevice "stylus" "SendCoreEvents"
Inputdevice "cursor" "SendCoreEvents"
Inputdevice "eraser" "SendCoreEvents"
Inputdevice "Synaptics Touchpad"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "0"
EndSection
