Problem med Java samt sen uppdatering av Ubuntu.
Tokuzo
Inlägg av Tokuzo »
Hejsan gott folk! Har märkt nu när jag har varit borta i 6 veckor, så hade jag ca 90 updates att göra så jag gjorde dem men sedan så när jag skulle försöka mig på att starta gtk-gnutella så får jag felmedelandet:
07-04-08 12:17:00 (MESSAGE): language code: "en"
07-04-08 12:17:00 (MESSAGE): using locale character set "UTF-8"
07-04-08 12:17:00 (MESSAGE): primary filename character set "UTF-8"
07-04-08 12:17:00 (MESSAGE): gtk-gnutella/0.96.1 (2006-02-22; GTK2; Linux i686)
07-04-08 12:17:00 (MESSAGE): D-BUS set up and ready for use.
07-04-08 12:17:00 (MESSAGE): Sent D-BUS signal 'Events': started
07-04-08 12:17:00 (WARNING): [hosts] retrieving from "/home/jimmy/.gtk-gnutella/hosts.orig" instead
07-04-08 12:17:00 (WARNING): [hosts] retrieving from "/home/jimmy/.gtk-gnutella/ultras.orig" instead
07-04-08 12:17:00 (WARNING): [hostile IP addresses] unable to retrieve: no alternate locations known
07-04-08 12:17:00 (WARNING): [Bogus IP addresses] trying to load from alternate locations...
07-04-08 12:17:00 (WARNING): [Bogus IP addresses] retrieving from "/usr/share/gtk-gnutella/bogons.txt" instead
07-04-08 12:17:00 (WARNING): [Geographic IP mappings] trying to load from alternate locations...
07-04-08 12:17:00 (WARNING): [Geographic IP mappings] retrieving from "/usr/share/gtk-gnutella/geo-ip.txt" instead
07-04-08 12:17:00 (WARNING): [Favorite web icon] trying to load from alternate locations...
07-04-08 12:17:00 (WARNING): [Favorite web icon] retrieving from "/usr/share/gtk-gnutella/favicon.png" instead
07-04-08 12:17:00 (WARNING): [Robot exclusion] trying to load from alternate locations...
07-04-08 12:17:00 (WARNING): [Robot exclusion] retrieving from "/usr/share/gtk-gnutella/robots.txt" instead
07-04-08 12:17:00 (WARNING): [Host Whitelist] unable to retrieve: no alternate locations known
07-04-08 12:17:00 (WARNING): searches file does not exist: /home/jimmy/.gtk-gnutella/searches.xml
07-04-08 12:17:00 (WARNING): retrieving searches from /home/jimmy/.gtk-gnutella/searches.xml.orig instead
*** ANCIENT VERSION DETECTED! ***
Sorry, this program is too ancient to run without
an explicit user action: If it's not possible to upgrade
you may edit the file
        /home/jimmy/.gtk-gnutella/config_gnet
and set the variable "ancient_version_force" to
"gtk-gnutella/0.96.1 (2006-02-22; GTK2; Linux i686)".
You will then be able to run this version forever, but
please consider upgrading, as Gnutella is an evolving
network in which ancient software is less useful or even
harmful!
*** EXITING ***
07-04-08 12:17:01 (WARNING): trapped foreign exit(), cleaning up...
07-04-08 12:17:01 (WARNING): idtable_destroy: destroying table with 3 ids
07-04-08 12:17:01 (WARNING): cleanup all done.
07-04-08 12:17:00 (WARNING): adns_do_transfer: EOF (read)
Det står visserligen ovan att jag ska ändra en liten rad, men lyckas inte få den att spara och har för mig att jag ska starta något speciellt text-editerings-program för att kunna få det att spara?
Och när jag ska starta Frostwire (som förövrigt gick så fint igår efter att jag installlerat det, men nu när jag starta om datorn så funka det icke).
Starting FrostWire...
Java exec found in PATH. Verifying...
Suitable java version found [java = 1.5.0_08]
Configuring environment...
Loading FrostWire:
Warning: Cannot convert string "-b&h-luxi sans-medium-r-normal--*-140-*-*-p-*-iso8859-1" to type FontStruct
Warning: Cannot convert string "-misc-ar pl shanheisun uni-medium-r-normal--*-*-*-*-p-*-iso10646-1" to type FontStruct
java.lang.ClassNotFoundException: irc.plugin.
        at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
        at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:164)
        at irc.IRCApplication.loadPlugin(Unknown Source)
        at irc.IRCApplication.init(Unknown Source)
        at com.limegroup.gnutella.gui.chat.ChatMediator.tryToStartAndAddChat(ChatMediator.java:141)
        at com.limegroup.gnutella.gui.chat.ChatMediator.<init>(ChatMediator.java:102)
        at com.limegroup.gnutella.gui.chat.ChatMediator.<clinit>(ChatMediator.java:70)
        at com.limegroup.gnutella.gui.MainFrame.<init>(MainFrame.java:122)
        at com.limegroup.gnutella.gui.GUIMediator.<init>(GUIMediator.java:219)
        at com.limegroup.gnutella.gui.GUIMediator.instance(GUIMediator.java:327)
        at com.limegroup.gnutella.gui.Initializer.initialize(Initializer.java:256)
        at com.limegroup.gnutella.gui.GUILoader.load(GUILoader.java:52)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:585)
        at com.limegroup.gnutella.gui.Main.main(Main.java:44)
Event dispatch in wrong thread
expected thread was [Lirc.DispatchThread;@e45b5e
current thread is Thread[main,5,main]
please submit a bug report to bugs@frostwire.com with the following information :
java.lang.Exception: Stack trace
        at java.lang.Thread.dumpStack(Thread.java:1158)
        at irc.EventDispatcher.dispatchEventSyncEx(Unknown Source)
        at irc.ListenerGroup.sendEventEx(Unknown Source)
        at irc.ListenerGroup.sendEvent(Unknown Source)
        at irc.gui.pixx.PixxTaskBar.enter(Unknown Source)
        at irc.gui.pixx.PixxTaskBar.addStatus(Unknown Source)
        at irc.gui.pixx.PixxMDIInterface.statusCreated(Unknown Source)
        at irc.gui.pixx.PixxMDIInterface.sourceCreated(Unknown Source)
        at irc.IRCApplication.sourceCreated(Unknown Source)
        at irc.IRCServer.enumerateSourcesAsCreated(Unknown Source)
        at irc.IRCApplication.newServer(Unknown Source)
        at irc.gui.pixx.PixxTaskBar.activate(Unknown Source)
        at irc.Source.report(Unknown Source)
        at irc.IRCServer.sendStatusMessage(Unknown Source)
        at irc.IRCServer.connect(Unknown Source)
        at irc.gui.pixx.BaseAWTSource.print(Unknown Source)
        at irc.gui.pixx.BaseAWTSource.reportReceived(Unknown Source)
# An unexpected error has been detected by HotSpot Virtual Machine:
#  SIGSEGV (0xb) at pc=0xb0da38da, pid=6743, tid=2963577760
# Java VM: Java HotSpot(TM) Client VM (1.5.0_08-b03 mixed mode, sharing)
# Problematic frame:
# C  [libfontmanager.so+0x2a8da]
# An error report file with more information is saved as hs_err_pid6743.log
# If you would like to submit a bug report, please visit:
http://java.sun.com/webapps/bugreport/crash.jsp
/usr/lib/frostwire/runFrostwire.sh: line 122:  6743 Avbruten (SIGABRT)      (core dumped) ${JAVA_PROGRAM_DIR}java -ea -Dorg.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog -Djava.library.path=. $EXECUTABLE -jar FrostWire.jar $ARGUMENTS
Vad ska jag hitta på för att lösa detta?
