qtsim - kan inte få install scriptet att bygga den -har qmake qt -vanlig +dev
of_darkness
Inlägg av of_darkness »
Ja skulle instalera qtsim http://www.speedsim.net/forum/viewtopic.php?t=398&sid=14e7241eefd23a835a8dd8ab949b1401 men den kan inte bygga den.. har qmake, och qt vanlig och dev från repos.
saxat från readme filen
=== Prerequisites ===
--- Qt ---
To build QtSim you need at least the open source version of Qt 4.x which can
be found at http://www.trolltech.com/products/qt/downloads; usually the port-
or package management system of your operating system (if it's not a windows)
should be able to install the latest version of Qt without any problems. If you
are using windows, the zip file will hopefully work for you.
--- QtSim / SpeedKernel ---
If you didn't download this file with a couple of other files from sourceforge,
go and checkout the latest version from the sourceforge svn repository
(read https://sourceforge.net/svn/?group_id=122497) or download a tarball
provided by the sourceforge project download page
https://sourceforge.net/project/showfil ... _id=122497
Be sure that you download both, the QtSim AND the SpeedKernel directory trees,
since you will need to compile your own kernel.
det medelande jag får av ./install scriptet är
Welcome to QtSim.
This script will attempt to automatically install QtSim for you.
BEWARE: Unlike its predecessor, this script is non-interactive.
This means for you: if you want to alter any settings, please
change them in this 'install' before you continue!
[Enter to continue]
Checking for SpeedKernel's source directory...
  default, valid.
Ok, the source seems to be there.
Creating Makefile for SpeedKernel...
  Done.
Compiling SpeedKernel, please wait...
  Done.
Creating Makefile for QtSim...
Project MESSAGE: You are running linux/unix
Project MESSAGE: Qt version:
Project MESSAGE: Qt is installed in /usr
QtSim.pro:7: Unknown test function: warning
Project MESSAGE: ----------------------------------------------------
QtSim.pro:24: Unknown test function: warning
QtSim.pro:25: Unknown test function: warning
QtSim.pro:26: Parse Error ('break here')
Error processing project file: /home/blutengel/speedsim/qtsim/QtSim.pro
  Done.
Compiling QtSim, please wait...
  Done.
Installing in '/home/blutengel/qtsim/'
make: *** Inga mål angavs och ingen makefil hittades.  Stannar.
  Done.
make: *** Inga mål.  Stannar.
If you wish to install custom lang-files please put them into
'/home/blutengel/qtsim/lang/'.
If you wish to install custom css-files please put them into
'/home/blutengel/qtsim/css/'.
  Done.
Congratulations! Installation of QtSim successfully completed.
You can now start QtSim by issuing '/home/blutengel/qtsim/QtSim'. Have fun!
har laddat ner via svn
värt att notera att någon QtSim katalog i hem katalogen inte existerar...
