Arghh, nu starta inte Ubuntu. Kan någon titta på log filen, vad är fel??[LÖST]
jah2007
Inlägg av jah2007 »
Så ser den ut:
X Window System Version 7.2.0
Release Date: 22 January 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating System: Linux Ubuntu
Current Operating System: Linux jh-desktop 2.6.20-11-generic #2 SMP Thu Mar 15 08:03:07 UTC 2007 i686
Build Date: 28 February 2007
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 17 09:51:15 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |  |-->Monitor "Generic Monitor"
(**) |  |-->Device "Generic Video Card"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "stylus"
(**) |-->Input Device "cursor"
(**) |-->Input Device "eraser"
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
/usr/X11R6/lib/X11/fonts/misc,
/usr/share/fonts/X11/cyrillic,
/usr/X11R6/lib/  X11/fonts/Type1,
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81c92e0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.1
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.1
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0305 card 1043,8033 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8305 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:04:0: chip 1106,0686 card 1043,8033 rev 22 class 06,01,00 hdr 80
(II) PCI: 00:04:1: chip 1106,0571 card 0000,0000 rev 10 class 01,01,8a hdr 00
(II) PCI: 00:04:2: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:04:3: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:04:4: chip 1106,3057 card 1043,8033 rev 30 class 06,80,00 hdr 00
(II) PCI: 00:09:0: chip 8086,1040 card 8086,1000 rev 00 class 07,80,00 hdr 00
(II) PCI: 00:0a:0: chip 1102,0002 card 1102,8027 rev 08 class 04,01,00 hdr 80
(II) PCI: 00:0a:1: chip 1102,7002 card 1102,0020 rev 08 class 09,80,00 hdr 80
(II) PCI: 00:0b:0: chip 109e,036e card 1461,0003 rev 11 class 04,00,00 hdr 80
(II) PCI: 00:0b:1: chip 109e,0878 card 1461,0003 rev 11 class 04,80,00 hdr 80
(II) PCI: 00:0c:0: chip 10ec,8139 card 1429,d010 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:0d:0: chip 1106,3044 card 1106,e8e9 rev 46 class 0c,00,10 hdr 00
(II) PCI: 00:11:0: chip 105a,0d30 card 105a,4d33 rev 02 class 01,80,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0150 card 1043,4016 rev a3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd5000000 - 0xd66fffff (0x1700000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd7f00000 - 0xe5ffffff (0xe100000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:4:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI: (0:11:0) Brooktree Corporation Bt878 Video Capture rev 17, Mem @ 0xd7000000/12
(--) PCI:*(1:0:0) nVidia Corporation NV15 [GeForce2 GTS/Pro] rev 163, Mem @ 0xd5000000/24, 0xd8000000/27, BIOS @ 0xd7ff0000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe6000000 from 0xe7ffffff to 0xe5ffffff
(II) Active PCI resource ranges:
[0] -1 0 0x30000000 - 0x3000ffff (0x10000) MX[B]
[1] -1 0 0xd3000000 - 0xd301ffff (0x20000) MX[B]
[2] -1 0 0xd3800000 - 0xd38007ff (0x800) MX[B]
[3] -1 0 0xd4000000 - 0xd40000ff (0x100) MX[B]
[4] -1 0 0xd6800000 - 0xd6800fff (0x1000) MX[B]
[5] -1 0 0xd4800000 - 0xd4bfffff (0x400000) MX[B]
[6] -1 0 0xe6000000 - 0xe5ffffff (0x0) MX[B]O
[7] -1 0 0xd7ff0000 - 0xd7ffffff (0x10000) MX[B](B)
[8] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
[9] -1 0 0xd5000000 - 0xd5ffffff (0x1000000) MX[B](B)
[10] -1 0 0xd7000000 - 0xd7000fff (0x1000) MX[B](B)
[11] -1 0 0x00007800 - 0x0000783f (0x40) IX[B]
[12] -1 0 0x00008000 - 0x00008003 (0x4) IX[B]
[13] -1 0 0x00008400 - 0x00008407 (0x8) IX[B]
[14] -1 0 0x00008800 - 0x00008803 (0x4) IX[B]
[15] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[16] -1 0 0x00009400 - 0x0000947f (0x80) IX[B]
[17] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[18] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[19] -1 0 0x0000a400 - 0x0000a41f (0x20) IX[B]
[20] -1 0 0x0000d000 - 0x0000d01f (0x20) IX[B]
[21] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[22] -1 0 0x0000d800 - 0x0000d80f (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
[0] -1 0 0x00100000 - 0x2fffffff (0x2ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
(II) All system resource ranges:
[4] -1 0 0x30000000 - 0x3000ffff (0x10000) MX[B]
[5] -1 0 0xd3000000 - 0xd301ffff (0x20000) MX[B]
[6] -1 0 0xd3800000 - 0xd38007ff (0x800) MX[B]
[7] -1 0 0xd4000000 - 0xd40000ff (0x100) MX[B]
[8] -1 0 0xd6800000 - 0xd6800fff (0x1000) MX[B]
[9] -1 0 0xd4800000 - 0xd4bfffff (0x400000) MX[B]
[10] -1 0 0xe6000000 - 0xe5ffffff (0x0) MX[B]O
[11] -1 0 0xd7ff0000 - 0xd7ffffff (0x10000) MX[B](B)
[12] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
[13] -1 0 0xd5000000 - 0xd5ffffff (0x1000000) MX[B](B)
[14] -1 0 0xd7000000 - 0xd7000fff (0x1000) MX[B](B)
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x00007800 - 0x0000783f (0x40) IX[B]
[18] -1 0 0x00008000 - 0x00008003 (0x4) IX[B]
[19] -1 0 0x00008400 - 0x00008407 (0x8) IX[B]
[20] -1 0 0x00008800 - 0x00008803 (0x4) IX[B]
[21] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[22] -1 0 0x00009400 - 0x0000947f (0x80) IX[B]
[23] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[24] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[25] -1 0 0x0000a400 - 0x0000a41f (0x20) IX[B]
[26] -1 0 0x0000d000 - 0x0000d01f (0x20) IX[B]
[27] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[28] -1 0 0x0000d800 - 0x0000d80f (0x10) IX[B]
(II) LoadModule: "i2c"
(II) Loading /usr/lib/xorg/modules//libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.2.0
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules//libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.2.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.7184
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.1.0
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: XFree86 Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.1.1
(II) LoadModule: "wacom"
(II) Loading /usr/lib/xorg/modules/input//wacom_drv.so
(II) Module wacom: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
ABI class: X.Org XInput driver, version 0.6
(II) Wacom driver level: 47-0.7.2 $
(II) NVIDIA dlloader X Driver  1.0-7184  Tue Aug  1 18:40:06 PDT 2006
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(WW) NVIDIA: No matching Device section for instance (BusID PCI:1:0:0) found
(EE) No devices detected.
Fatal server error:
no screens found
Okänd
SV: Arghh, nu starta inte Ubuntu. Kan någon titta på log filen, vad är fel??
Inlägg av Okänd »
jah2007 skrev:
Så ser den ut:
Det ser ju ut som en uppgraderad Feisty eftersom det är gamla nVidia drivare.
Skifta till en terminal när X kraschar  ;)
Ctrl-Alt-F1  > Logga in .
sudo apt-get install nvidia-glx
Eventuellt eftersom det är ett gammalt kort  nVidia Corporation NV15 [GeForce2 GTS/Pro
sudo apt-get install nvidia-glx-legacy
Du ser på installationen vad som händer.
Ctrl-Alt-Del för omstart.
Funkar det inte.
http://ubuntu-se.org/smf/index.php/topic,833.0.html
sudo dpkg-reconfigure xserver-xorg
Sen ligger den här tråden i fel grupp eftersom Feisty inte finns....test just nu.
jah2007
Inlägg av jah2007 »
Tack för hjälpen!
Nu fungerar det  :D
