Restricted Manager
Okänd
Restricted Manager
Inlägg av Okänd »
Rykande färskt från Feistys forum...
sudo aptitude install restricted-manager
sudo restricted-manager för att köra.
[bifogad fil raderad av administratör]
Emil.s
SV: Restricted Manager
Inlägg av Emil.s »
Nice!
För drivrutiner alltså?
Okänd
Inlägg av Okänd »
Okänd
Inlägg av Okänd »
Rekommenderar inte några större test med den här... ;)
Före:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Fri Dec 15 10:12:14 PST 2006
Section "ServerLayout"
    Identifier    "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
    RgbPath        "/usr/lib/X11/rgb"
EndSection
Section "Module"
    Load          "dbe"
    Load          "extmod"
    Load          "type1"
    Load          "freetype"
    Load          "glx"
EndSection
Section "InputDevice"
    # generated from default
    Identifier    "Mouse0"
    Driver        "mouse"
    Option        "Protocol" "auto"
    Option        "Device" "/dev/psaux"
    Option        "Emulate3Buttons" "no"
    Option        "ZAxisMapping" "4 5"
EndSection
    Identifier    "Keyboard0"
    Driver        "kbd"
    Option        "XkbModel" "pc105"
    Option        "XkbLayout" "se"
    Option        "XkbOptions" "lv3:ralt_switch"
EndSection
Section "Monitor"
    Identifier    "Monitor0"
    VendorName    "Unknown"
    ModelName      "Unknown"
    HorizSync      30.0 - 110.0
    VertRefresh    50.0 - 150.0
    Option        "DPMS"
EndSection
Section "Device"
    Identifier    "Device0"
    Driver        "nvidia"
    VendorName    "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier    "Screen0"
    Device        "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option        "AddARGBGLXVisuals" "True"
    Option        "XAANoOffscreenPixmaps"
    SubSection    "Display"
        Depth      24
        Modes      "1600x1200" "1280x1024" "1024x768" "800x600" "640x480"
    EndSubSection
EndSection
Section "Extensions"
    Option        "Composite" "Enable"
EndSection
Efter:    ;D
/etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#  sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
EndSection
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/wacom" # Change to
# /dev/input/event
# for USB
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
# /dev/input/event
# for USB
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
# /dev/input/event
# for USB
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-51
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "Generic Monitor"
DefaultDepth 24
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice    "stylus" "SendCoreEvents"
InputDevice    "cursor" "SendCoreEvents"
InputDevice    "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Blidde inte alls nå bra..... 8)
freemanen
Inlägg av freemanen »
om man trycker på desktop-effects kommer den upp automatiskt då?
Okänd
Inlägg av Okänd »
freemanen skrev: om man trycker på desktop-effects kommer den upp automatiskt då?
Den logiken har jag inte provat.... säkrast är nog att gå via Restricted Managern som
verkar göra rätt numera.  dvs enable så triggas drivarnedladdning.
Sedan att burken man gör det med är "standard", har man redan en drivare så
verkar det bli en röra,  iaf blev det så när jag testade igår.
johan_pirate
Inlägg av johan_pirate »
Coolt :D
