Så därför har jag hackat ihop ett script som gör det enkelt...
Det är bara att skriva "xr den-upplösning-du-vill-ha" och ja, jag har kallat scriptet för "xr", men det väljer man själv.
Scriptet är förberett för wayland, men den biten finns inte ännu.
#! /bin/bash
PROTOCOL=$(echo "$XDG_SESSION_TYPE")
if [[ $PROTOCOL != "x11" ]]; then
echo "-As the protocol is $PROTOCOL, we cannot continue (only x11 is supported)"
echo
exit
fi
function usage {
less << EOD
usage: $CMDNAME [function] [WIDTHxHEIGTH]
If "WIDTHxHEIGHT" is specified, this automatically implies a "set" function.
FUNCTIONS:
-c | --current
Show current resolution, this is also what is shown if "$CMDNAME" is run
without any specified function.
-d | --define
Define a new resolution for this monitor. The specified resolution must
be defined by the VESA standard. If the specified resolution is already
defined, a message is written and no further definition is made.
--dryrun
Performs all the actions specified except that no changes are made.
-h | --help
Show this.
-i | --inter | --interactive
All defined resolutions for this monitor is shown and it is possible
to select one of them, by entering its number. It is also possible to
enter "0" and then specify which resolution that is wanted.
Running this and selecting the number for 1920x1080 (eg. "1" ) has the
same result as running "$CMDNAME -l" to see that it is "1" and then run
"$CMDNAME 1" (or "$CMDNAME 1920x1080" first.
Running interactive and specifying "0" and then enter "1920x1080" has
the same result as running "xd --define 1920x1080".
-l | --list
List all modes are currently defined for this monitor. It only shows all
resolutions that are defined for the monitor, it does not show all possible
resolutions.
--rm | --remove
Remove a defined resolution. Generally there is no need for this function
as defined resolutions is removed by a reboot. It is not possible to remove
any resolution defined by the system.
This function sometimes misses, due to a bug in xrandr, but however a reboot
works.
-r | --reset
Reset monitor to the previous resolution. Most often this is the original
resolution.
The "previus" resolution is only saved the first time a change of resolution
is made. Therefore a reset after a number of changes only resets to the first
resolution.
The "reset-file" is deleted after each reset, but can however remain after a
certain reboot.
-v | --vesa
List possible resolutions that are defined by VESA. This does not imply
that the resolutions are supported by the actual monitor.
The purpose of this function is not to be a complete list of all possible
resolutions, but to give tips on the most common ones if none are available
via "-l" for the monitor in question.
-m MON | --mon=MON | --monitor=MON
Specifies which monitor to operate on. If not specified it is assumed
that only one monitor exists.
Both "-c" and "-l" performs an exit when the info is shown. If both are specified
only the first function will thus be performed. This is also the same when a resolution
("set") is specified. A resolution setting is always superseeded if "-c" or "-l" is
specified.
FILES:
The command uses a file called ".xr" in the users home-directory, so do not use
this name for anything else.
EXAMPLES:
$CMDNAME 5
Setup this monitor to run with the resolution defined by line #5 as
shown by "$CMDNAME -l".
$CMDNAME 1920x1080
Setup this monitor to run with the resolution "1920x1080". It only works if
1920x1080 is already defined. Check with "--list" and use "--define" if it
is not.
$CMDNAME -c | --current
Show current resolution - this is also default if no other action is specfied.
$CMDNAME -d 1920x1080 | --define=1920x1080
Define the resolution "1920x1080" for this monitor and change to it. If 1920x1080
is already defined, a new definition will not be made.
$CMDNAME -l | --list
$CMDNAME -m MON | --mon=MON | --monitor=MON
Specify that the monitor to be used are for example "HDMI-1" or "VGA". Of course
a function to be performed must also be specified, otherwise only the current
resolution will be shown.
If there only exist one monitor, it is not needed to specify this.
$CMDNAME -v | --vesa
Show the standard resolutions defined by VESA, as I have found so far. This script
will not try define anything else. Edit this script and add extra resolutions if
you want and know what you are doing.
EOD
function checkIfResolIsDefined {
RSL=$1
ResolIsDefined=false
if [[ $PROTOCOL == "x11" ]]; then
LINES=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | awk '{ print $1 }')
elif [[ $PROTOCOL == "wayland" ]]; then
# We will never reach here as "$PROTOCOL==wayland" has already performed an exit...
# It is just here for future development...
RESOL="<wayland>"
return 1
else
# We will never reach here as "$PROTOCOL==other" has already performed an exit...
RESOL="<other>"
return 1
fi
origIFS=$IFS
IFS=$'\n'
for LINE in $LINES; do
if [[ $RSL == $LINE ]]; then
ResolIsDefined=true
RESOL=$RSL
break
fi
done
IFS=$origIFS
if [[ $ResolIsDefined == false ]]; then
return 1
fi
return 0
function currentModes {
SPECIFIED_MODE=$1
MODES=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | awk '{ print $1 }')
MODES="<wayland>"
return 1
else
MODES="<other>"
return 1
fi
for MODE in $MODES; do
if [[ $SPECIFIED_MODE == $MODE ]]; then
return 0
fi
done
return 1
function doReset {
getMonitor
if [[ -r ~/.xr ]]; then
RESOL=$(cat ~/.xr)
echo "-Resetting resolution to $RESOL"
echo "=> xrandr $OPT --output $MONITOR --mode $RESOL"
rm ~/.xr
else
echo "-No previous resolution found..."
fi
echo
function findMonitor {
NUM=$1
xrandr --listmonitors | tail -n +2 | sed 's/^[[:space:]]*//' | grep "^$NUM:" | awk '{ print $4 }'
echo "<wayland>"
else
echo "<unknown>"
fi
function getMonitor {
if [[ -z $MONITOR ]]; then
NMON=$(xrandr --listmonitors | grep "Monitors:" | awk '{ print $2 }')
NMON="0"
else
NMON="0"
fi
if [[ $NMON -gt 1 ]]; then
echo "-More than one monitor exists, you have specify which one to use with name or number"
echo "-Existing monitors:"
echo
showMonitors
echo
read -p "_Monitor: " IN
MONITORS=$(xrandr --listmonitors | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | awk '{ print $4 }')
MONITORS="<wayland>"
else
MONITORS="<other>"
fi
isnum $IN
if [[ $? == 0 ]]; then
MONITOR=$(findMonitor $IN)
else
MONITOR=$(toupper $IN)
fi
if [[ ! -z $MONITOR ]]; then
monitorExist $MONITOR
if [[ $? != 0 ]]; then
echo "-Specified monitor $MONITOR not found..."
echo
exit
fi
echo "-Monitor specified as $MONITOR"
echo
else
echo "-Specified monitor not found..."
echo
exit
fi
else
MONITOR=$(xrandr | grep -e " connected [^(]" | cut -d\ -f1 | xargs)
echo "-Monitor implicitly set to $MONITOR (only 1 exists)..."
MONITOR="<wayland>"
else
MONITOR="<other>"
fi
fi
else
else
echo "-Monitor $MONITOR does not exist..."
echo
exit
fi
fi
function isnum {
if [[ $1 =~ ^[0-9]+$ ]]; then
return 0
fi
return 1
function listDefined {
#xrandr | grep "^ "[0-9] | grep -v none
echo '-Preferred resolutions is denoted by "+" (plus)'
echo '-Current resolution is denoted by a "*" (asterisk)'
echo '-A resolution that ends with an "i" means "interlaced" and a "p" means "progressive"'
echo "-(Interlaced is mostly used for CRT monitors)"
echo
xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | cat -n
echo "<wayland>"
else
echo "<unknown>"
fi
echo
function monitorExist {
MN=$1
FOUNDMON=false
MONITORS=$(xrandr --listmonitors | tail -n +2 | awk '{ print $4 }')
for MONIT in $MONITORS; do
if [[ $MONIT == $1 ]]; then
FOUNDMON=true
return 0
fi
done
echo "<wayland>"
else
echo "<unknown>"
fi
return 1
function number2resol {
IN=$1
NumToResol=false
#LINES=$(xrandr | grep "^ "[0-9] | cat -n | sed -E 's/^[[:space:]]+//')
LINES=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | cat -n)
RESOL="<wayland>"
return 1
else
RESOL="<other>"
return 1
fi
origIFS=$IFS
IFS=$'\n'
NUM=$(echo $LINE | awk '{ print $1 }')
if [[ $NUM == $IN ]]; then
NumToResol=true
break
fi
done
IFS=$origIFS
if [[ $NumToResol == true ]]; then
RESOL=$(echo $LINE | awk '{ print $2 }')
else
RESOL=""
return 1
fi
return 0
function removeResol {
RESOL=$1
echo
showMonitors
echo
isnum $IN
else
fi
echo
exit
fi
echo
else
echo
exit
fi
else
fi
checkIfResolIsDefined $RESOL
echo "=> xrandr $OPT --delmode $MONITOR $RESOL 2> /dev/null"
echo "=> xrandr $OPT --rmmode $RESOL 2> /dev/null"
echo "-Remove failed, if it is a user defined resolution it will be removed at next reboot..."
fi
echo
exit
else
echo "-Resolution $RESOL is not defined..."
echo
exit
fi
function setupDefine {
ASK=$1
MODE=$2
if [[ $ASK == "yes" ]]; then
read -p '_Enter "WIDTHxHEIGHT": ' MODE
if [[ -z $MODE || $MODE == "q" || $MODE == "Q" ]]; then
echo
exit
fi
fi
WxH=$(echo $MODE | awk -F \_ '{ print $1 }')
checkIfResolIsDefined $MODE
DEFINE=false
RESOL=$WxH
echo "-Resolution $MODE is already defined for this monitor..."
return 0
fi
vesaStd $WxH
echo "-Unsupported resolution (no such VESA standard) - $WxH..."
echo
exit
fi
DEFINE=true
FREQ=$(echo $MODE | awk -F _ '{ print $2 }')
WIDTH=$(echo $WxH | awk -F x '{ print $1 }')
HEIGHT=$(echo $WxH | awk -F x '{ print $2 }')
MODE=$(cvt $WIDTH $HEIGHT | grep -i modeline | awk '{ $1=""; print $0 }' | sed -E 's/^[[:space:]]+//')
NAME=$(echo $MODE | awk '{ print $1 }' | sed 's/\"//g' | awk -F _ '{ print $1 }')
LINE=$(echo $MODE | awk '{ $1=""; print $0 }' | sed -E 's/^[[:space:]]+//')
MODELINE="$NAME $LINE"
MODSET=true
RESOL=$WxH
currentModes $WxH
function showCurrent {
CURRENT=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | grep \* | awk '{ print $1 }')
CURRENT="<wayland>"
else
CURRENT="<other>"
fi
echo "-Current resolution is: $CURRENT"
echo
function showFunctions {
if [[ $CURRENT == true ]]; then
echo " current - yes"
else
echo " current - no"
fi
if [[ $HELP == true ]]; then
echo " help - yes"
else
echo " help - no"
fi
if [[ $INTER == true ]]; then
echo " inter - yes"
else
echo " inter - no"
fi
if [[ $LIST == true ]]; then
echo " list - yes"
else
echo " list - no"
fi
if [[ $RESET == true ]]; then
echo " reset - yes"
else
echo " reset - no"
fi
if [[ $RM == true ]]; then
echo " rm - yes"
else
echo " rm - no"
fi
if [[ $VESA == true ]]; then
echo " vesa - yes"
else
echo " vesa - no"
fi
if [[ $SPEC == true ]]; then
echo " spec - yes (specified resolution)"
else
echo " spec - no (specified resolution)"
fi
function showMonitors {
xrandr --listmonitors | grep -v Monitors:
echo "<wayland>"
else
echo "<other>"
fi
function toupper {
echo $1 | awk '{ print toupper($0) }'
function vesaList {
cat << EOV
This is not a complete list of all possible resolutions. It is only tips about common resolutions
that possibly can be defined if there are to few pre defined as shown by "-l".
To define resolutions other than these, the script must be edited. The idea behind this, is to
prevent for unreasonable resolutions.
EOV
# 4:3
echo " 4:3"
echo " 3840x2880"
echo " 3200x2400"
echo " 2560x1920"
echo " 2048x1536"
echo " 1920x1440"
echo " 1600x1200"
echo " 1400x1050"
echo " 1280x960"
echo " 1024x768"
echo " 800x600"
echo " 640x480"
echo
# 5:4
echo " 5:4"
echo " 1280x1024"
echo
# 15:9
echo " 15:9"
echo " 1280x768"
echo
# 16:9
echo " 16:9"
echo " 5120x2880"
echo " 4264x2400"
echo " 3408x1920"
echo " 2728x1536"
echo " 2560x1440"
echo " 2128x1200"
echo " 1920x1080"
echo " 1864x1050"
echo " 1704x960"
echo " 1360x768"
echo " 1280x720"
echo " 1064x600"
echo " 848x480"
echo
# 16:10
echo " 16:10"
echo " 4608x2880"
echo " 3840x2400"
echo " 3072x1920"
echo " 2456x1536"
echo " 2304x1440"
echo " 1920x1200"
echo " 1728x1080"
echo " 1680x1050"
echo " 1536x960"
echo " 1224x768"
echo " 1152x720"
echo " 960x600"
echo " 768x480"
echo
function vesaStd {
wxh=$1
# 4:3
if [[ $wxh == 3840x2880 ]]; then
return 0
elif [[ $wxh == 3200x2400 ]]; then
return 0
elif [[ $wxh == 2560x1920 ]]; then
return 0
elif [[ $wxh == 2048x1536 ]]; then
return 0
elif [[ $wxh == 1920x1440 ]]; then
return 0
elif [[ $wxh == 1600x1200 ]]; then
return 0
elif [[ $wxh == 1400x1050 ]]; then
return 0
elif [[ $wxh == 1280x960 ]]; then
return 0
elif [[ $wxh == 1024x768 ]]; then
return 0
elif [[ $wxh == 800x600 ]]; then
return 0
elif [[ $wxh == 640x480 ]]; then
return 0
# 5:4
elif [[ $wxh == 1280x1024 ]]; then
return 0
# 15:9
elif [[ $wxh == 1280x768 ]]; then
return 0
# 16:9
elif [[ $wxh == 5120x2880 ]]; then
return 0
elif [[ $wxh == 4264x2400 ]]; then
return 0
elif [[ $wxh == 3408x1920 ]]; then
return 0
elif [[ $wxh == 2728x1536 ]]; then
return 0
elif [[ $wxh == 2560x1440 ]]; then
return 0
elif [[ $wxh == 2128x1200 ]]; then
return 0
elif [[ $wxh == 1920x1080 ]]; then
return 0
elif [[ $wxh == 1864x1050 ]]; then
return 0
elif [[ $wxh == 1704x960 ]]; then
return 0
elif [[ $wxh == 1360x768 ]]; then
return 0
elif [[ $wxh == 1280x720 ]]; then
return 0
elif [[ $wxh == 1064x600 ]]; then
return 0
elif [[ $wxh == 848x480 ]]; then
return 0
# 16:10
elif [[ $wxh == 4608x2880 ]]; then
return 0
elif [[ $wxh == 3840x2400 ]]; then
return 0
elif [[ $wxh == 3072x1920 ]]; then
return 0
elif [[ $wxh == 2456x1536 ]]; then
return 0
elif [[ $wxh == 2304x1440 ]]; then
return 0
elif [[ $wxh == 1920x1200 ]]; then
return 0
elif [[ $wxh == 1728x1080 ]]; then
return 0
elif [[ $wxh == 1680x1050 ]]; then
return 0
elif [[ $wxh == 1536x960 ]]; then
return 0
elif [[ $wxh == 1224x768 ]]; then
return 0
elif [[ $wxh == 1152x720 ]]; then
return 0
elif [[ $wxh == 960x600 ]]; then
return 0
elif [[ $wxh == 768x480 ]]; then
return 0
else
return 1
fi
echo
TEMP=`getopt -ocdhilm:rv --long current,define,dryrun,help,inter,interactive,list,mon:,monitor:,rm,remove,vesa,reset -n $(basename $0) -- "$@"`
if [[ $? -ne 0 ]]; then
usage
exit
fi
eval set -- "$TEMP"
MODELINE="<not created as we are not defining a new mode>"
RESNAME="<not created as we are not defining a new mode>"
OPT=""
CURR=false
CURRENT=false
DEFINE=false
DRYRUN=false
HELP=false
INTER=false
LIST=false
NONE=true
RESET=false
RM=false
SPEC=false
VESA=false
MODSET=false
let COUNT=0
CMDNAME=$(basename $0)
while true; do
case $1 in
-c|--current)
NONE=false
let COUNT+=1
CURRENT=true
shift
-d|--define)
DEFINE=true
shift
--dryrun)
DRYRUN=true
OPT="--dryrun "
shift
-h|--help)
NONE=false
let COUNT+=1
HELP=true
shift
-i|--inter|--interactive)
NONE=false
let COUNT+=1
INTER=true
shift
-l|--list)
NONE=false
let COUNT+=1
LIST=true
shift
-m|--mon|--monitor)
shift
MONITOR=$(toupper $1)
shift
--rm|--remove)
NONE=false
RM=true
shift
-v|--vesa)
NONE=false
let COUNT+=1
VESA=true
shift
-r|--reset)
NONE=false
let COUNT+=1
RESET=true
shift
shift
break
echo "-Got a star... [$1]"
exit
esac
done
P1=$1
P2=$2
P3=$3
P4=$4
if [[ ! -z $P1 ]]; then
NONE=false
SPEC=true
#RESOL=$P1
let COUNT+=1
fi
if [[ $COUNT -gt 1 ]]; then
echo "-Only possible to specify one function..."
echo "-Specified functions:"
showFunctions
echo
exit
fi
ResolIsDefined=unknown
NumToResol=unknown
if [[ $CURRENT == true || $NONE == true ]]; then
showCurrent
exit
elif [[ $HELP == true ]]; then
usage
exit
elif [[ $LIST == true ]]; then
listDefined
exit
elif [[ $RESET == true ]]; then
doReset
exit
elif [[ $RM == true ]]; then
removeResol $P1
exit
elif [[ $VESA == true ]]; then
vesaList
exit
else # -If $INTER or specified resolution - find which monitor
getMonitor
fi
# -Interactive was specified, so we have to show defined resolutions and ask about which to use.
listDefined
echo '_Enter a number that exists to change to that resolution, "0" to define a new resolution or "q" to quit.'
echo "-It is not possible to enter resolution directly here!!"
read -p '_Number: ' IN
if [[ -z $IN || $IN == "q" || $IN == "Q" ]]; then
echo
exit
elif [[ $IN != 0 ]]; then
number2resol $IN
echo "-No such resolution number - $IN..."
echo
exit
fi
elif [[ $IN == 0 ]]; then
DEFINE=true
setupDefine "yes"
fi
echo "-Session protocol is Wayland - not possible to fix yet-1..."
echo
exit
else
echo "-Session protocol is unknown - not possible to fix..."
echo
exit
fi
elif [[ $SPEC == true ]]; then
# -A resolution was specified in the command line, so we will check it out and possibly use it.
X=$(echo $P1 | grep "x")
if [[ ! -z $X ]]; then
checkIfResolIsDefined $P1
if [[ $DEFINE == true ]]; then
setupDefine "no" $P1
else
echo "-Resolution $P1 is already defined for this monitor..."
fi
else
echo "-Undefined resolution for this monitor - $P1..."
echo
exit
fi
RESOL=$P1
fi
elif [[ ! -z $P1 ]]; then
number2resol $P1
echo "-No such resolution number - $P1 (check with \"$(basename $0) -l\"..."
echo
exit
elif [[ $DEFINE == true ]]; then
echo "-Resolution $RESOL is already defined for this monitor..."
fi
else
# We should never reach here, but add a message in case of...
echo "-Unknown resolution error..."
fi
fi
if [[ $CURRENT == $RESOL ]]; then
echo "-Specified resolution is the same as current - no reason to change..."
echo
exit
fi
if [[ $MODSET == true ]]; then
RESNAME=$(echo $MODELINE | awk '{ print $1 }' | sed 's/"//g')
fi
TRACE=false
if [[ $TRACE == true ]]; then
echo
echo "IN: $IN"
echo "SPEC: $SPEC"
echo "FOUNDNUM: $FOUNDNUM"
echo "ResolIsDefined: $ResolIsDefined"
echo "NumToResol: $NumToResol"
echo "DEFINE: $DEFINE"
echo "MONITOR: $MONITOR"
echo "MODELINE: $MODELINE"
echo "RESNAME: $RESNAME"
echo "RESOL: $RESOL"
echo
fi
if [[ ($SPEC == true && $ResolIsDefined == true) || ($NumToResol == true) ]]; then
echo "-Setting resolution to $RESOL"
if [[ ! -e ~/.xr ]]; then
echo $CURRENT > ~/.xr
fi
echo "-Session protocol is Wayland - not possible to fix yet-2..."
else
fi
echo "-Mode $WxH already exist, will not redefine it..."
else
echo "-Defining mode $RESOL"
echo "=> xrandr $OPT --newmode $MODELINE"
echo "=> xrandr $OPT --addmode $MONITOR $RESNAME"
fi
fi
echo "-Session protocol is Wayland - not possible to fix yet..."
else
fi
else
echo "-Resolution $IN not found..."
fi
echo
