Får inte till att få mikrofonen (extern) att fungera!
Har provat "alsamixer" utan framgång
Följande - inställningar/ljud (se bild)
Förslag på åtgärder?
mikrofonen fungar inte på Ununtu 22.04
- mikrofon.png (30.45 KiB) Visad 2261 gånger
- Osprey
Re: mikrofonen fungar inte på Ununtu 22.04
Prova med det här scriptet, som jag hackat ihop. Iofs mest gjort för ljud, men det kanske kan funka....
#! /bin/bash
trap "exit" SIGQUIT; chkroot --kill has_to_not_be_root
echo
#Masked=$(systemctl list-unit-files | grep -i pulseaudio | awk '{ print $2 }')
MaskedService=$(systemctl --user is-enabled pulseaudio.service)
MaskedSocket=$(systemctl --user is-enabled pulseaudio.socket)
if [[ $MaskedService == "masked" || $MaskedSocket == "masked" ]]; then
echo "-Pulseaudio is marked as masked (very disabled)."
read -p "_Do you want to unmask it? [y/N]: " IN
if [[ $IN == "y" || $IN == "Y" ]]; then
systemctl --user unmask pulseaudio.{service,socket} --now
if [[ $MaskedService == "masked" ]]; then
systemctl --user unmask pulseaudio.service --now
fi
if [[ $MaskedSocket == "masked" ]]; then
systemctl --user unmask pulseaudio.socket --now
fi
systemctl --user status pulseaudio
fi
else
echo "-Pulseaudio is not masked..."
fi
AutoMute=$(amixer -c 0 sget 'Auto-Mute Mode' | grep -F "Item0:" | awk '{ print $2 }' | sed "s/[']//g")
if [[ $AutoMute == "Enabled" ]]; then
echo "-Pulseaudio is Automuted, turning this off..."
echo
echo -n " ="
/usr/bin/amixer -c 0 sset "Auto-Mute Mode" Disabled
else
echo "-Pulseaudio is not Automuted..."
fi
echo
pulseaudio --check
Running=$?
if [[ $Running == 0 ]]; then
echo "-Pulseaudio is currently running..."
read -p "_Do you want to restart it? [y/N]: " IN
pulseaudio --kill
#start-pulseaudio-x11 # Not needed..?
pulseaudio --start
fi
echo
else
echo "-Pulseaudio is currently not running..."
read -p "_Do you want to start it? [y/N]: " IN
pulseaudio --start
elif [[ $IN == "q" || $IN == "Q" ]]; then
echo
exit
fi
echo
fi
echo "-Available output devices:"
echo
pacmd list | grep "available: yes" | sort -u | sed 's/^\t//g'
echo
echo "-Select one of THEM in the list of pavucontrol below!"
echo
#pactl list | grep output- | sed 's/^\t//g'
#echo
echo 'Pavucontrol - go to "Configuration => Profile" and select "Analog stereo output"'
#echo 'Pavucontrol - go to "Configuration => Profile" and select one of the device shown above...'
read -p "[Press Enter to continue (or q to quit)] " IN
if [[ $IN != "q" && $IN != "Q" ]]; then
pavucontrol --tab=5
aplay /usr/share/sounds/alsa/Front_Center.wav
fi
echo
Tack Osprey!
Har kört scriptet men mikrofonen funkar inte i all fall!
mikken är lite speciell, det är till en Ipad/iPhone med en lightning-kontakt som jag har fixat mellanstegen på till en 3.5 mm kontakt som jag till datorn (se bifogad bild) - detta kanske inte fungerar alls!!
Ska testa med en annan mikrofon när jag får tag på en!!
- mikken.jpg (56.88 KiB) Visad 2249 gånger
Den kopplingen med ipad/iphone mikrofon funkade inte med de mellanstegen som jag skaffade
så jag köpte en billig mikrofon på "Kjell & company" för att testa och den mikrofonen funkade men med massa störningar/brus, jag ska lämna tillbaka den och köpa bättre mikrofon istället!
Så problemet är löst, och tack för scriptet "Osprey", det kommer säkert till användning för mig och många andra!!
