Kan inte instalera Wine
Gubben i Kalmar
Inlägg av Gubben i Kalmar »
Hej igen.
Kan ni hjälpa mig med att installer Wine.
Jag kör en snitslad bana:
https://wine.htmlvalidator.com/install- ... 20.04.html
Men får ett felmedelande
tommy@HP-Compaq-6200-Pro:~$ $ dpkg --print-architecture
$: kommandot hittades inte
tommy@HP-Compaq-6200-Pro:~$ dpkg --print-architecture
amd64
tommy@HP-Compaq-6200-Pro:~$ dpkg --print-foreign-architectures
i386
tommy@HP-Compaq-6200-Pro:~$ wine --version
Kommandot "wine" hittades inte, men kan installeras med:
sudo apt install wine              # version 5.0-3ubuntu1, or
sudo apt install wine-development  # version 5.5-3ubuntu1
amd64
i386
tommy@HP-Compaq-6200-Pro:~$ sudo wget -nc -O /usr/share/keyrings/winehq-archive.key https://dl.winehq.org/wine-builds/winehq.key
[sudo] lösenord för tommy:
--2022-11-13 13:53:37--  https://dl.winehq.org/wine-builds/winehq.key
Slår upp dl.winehq.org (dl.winehq.org)... 151.101.86.217
Ansluter till dl.winehq.org (dl.winehq.org)|151.101.86.217|:443 … ansluten.
HTTP-begäran skickad, väntar på svar... 200 OK
Längd: 3220 (3,1K) [application/pgp-keys]
Sparar till: "/usr/share/keyrings/winehq-archive.key"
/usr/share/keyrings 100%[===================>]   3,14K  --.-KB/s    om 0,001s
2022-11-13 13:53:38 (2,42 MB/s) - "/usr/share/keyrings/winehq-archive.key" sparades [3220/3220]
tommy@HP-Compaq-6200-Pro:~$ sudo wget -nc -P /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/ubuntu/dists/focal/winehq-focal.sources
--2022-11-13 13:54:11--  https://dl.winehq.org/wine-builds/ubuntu/dists/focal/winehq-focal.sources
Längd: 163
Sparar till: "/etc/apt/sources.list.d/winehq-focal.sources"
winehq-focal.source 100%[===================>]     163  --.-KB/s    om 0s
2022-11-13 13:54:11 (6,58 MB/s) - "/etc/apt/sources.list.d/winehq-focal.sources" sparades [163/163]
tommy@HP-Compaq-6200-Pro:~$ sudo apt update
Bra:1 http://se.archive.ubuntu.com/ubuntu focal InRelease
Läs:2 https://dl.winehq.org/wine-builds/ubuntu focal InRelease [8 041 B]
Bra:3 http://se.archive.ubuntu.com/ubuntu focal-updates InRelease
Bra:4 http://se.archive.ubuntu.com/ubuntu focal-backports InRelease
Bra:5 http://security.ubuntu.com/ubuntu focal-security InRelease
Fel:2 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
  Följande signaturer kunde inte verifieras för att den öppna nyckeln inte är tillgänglig: NO_PUBKEY 76F1A20FF987672F
Läser paketlistor… Färdig
W: GPG-fel: https://dl.winehq.org/wine-builds/ubuntu focal InRelease: Följande signaturer kunde inte verifieras för att den öppna nyckeln inte är tillgänglig: NO_PUBKEY 76F1A20FF987672F
E: The repository 'https://dl.winehq.org/wine-builds/ubuntu focal InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
tommy@HP-Compaq-6200-Pro:~$ https://dl.winehq.org/wine-builds/ubuntu
bash: https://dl.winehq.org/wine-builds/ubuntu: Filen eller katalogen finns inte
tommy@HP-Compaq-6200-Pro:~$ sudo apt install --install-recommends winehq-stable
Bygger beroendeträd
Läser tillståndsinformation… Färdig
E: Kunde inte hitta paketet winehq-stable
Ni ser själva "E:" på två ställen.
Vad ska jag göra för att få ordning på detta?
Vänligen
Gubben i Kalmar
moonwolf
Re: Kan inte instalera Wine
Inlägg av moonwolf »
Installera Wine från https://www.winehq.org/ istället. Står här https://wiki.winehq.org/Ubuntu hur man ska installera Wine i Ubuntu.
Gubben i Kalmar
Tack moonvolf.
Nu ligger wine 7.0.1 i min dator
Usage: wine PROGRAM [ARGUMENTS...]   Run the specified program
       wine --help                   Display this help and exit
       wine --version                Output version information and exit
wine-7.0.1
Hur får jag igång wine?
Skulle behöva en genväg att starta?
wine ska väl konfigureras tex
Eller har jag missat något på deras hemsida?
Gubben i Kalmar
Tack .
Nu är jag på banan igen.
Man skulle köra:
wine winecfg
sedan:
wine clock
Sedan:
wine iexplore
Nu tror jag att "wine" är på plats.
I morgon ska jag testa att installera "SMath studio"
Tack moonwolf för din snabba input
Vänligen
Gubben i kalmar
