#! /bin/bash
# © Magnus Ewert & GPL
TTIMES=8 # Test times
TTIMEOUT=2 # Test timeout
MORE=true
STDIFS=$IFS
OS=$(cat /etc/os-release | grep ID_LIKE | awk '{ print $1 }' | awk -F = '{ print $2 }' | sed 's/"//g')
#echo "OS: $OS"
if [[ $(whoami) != "root" ]]; then
echo
echo "-This script must be run by root..."
echo
exit
fi
if [[ -t 1 ]]; then
if [[ $MORE == true ]]; then
if [[ $OS != "suse" ]]; then
$0 $@ | more
exit
else
#$0 $@ | less --QUIT-AT-EOF
$0 $@ | less -F -X --quit-at-eof
exit
fi
else
#clear -x
LILAC="\033[1m\033[35m"
GREEN="\033[1m\033[32m"
RED="\033[1m\033[31m"
STD="\033[0m"
fi
elif [[ -f /dev/stdout ]]; then
LILAC=""
GREEN=""
RED=""
STD=""
else
#clear -x
STD="\033[0m"
fi
##########################################[ USAGE ]#####################################################################
function usage {
cat << EOD
usage: $CMDNAME [-f] [-n] [-o] [-p] [-s] [-t] [-w] [DEVICE]
DEVICE specifies the device to operate on. If not specified the script uses the first
found device that looks ok.
Options:
-f|--fixed
The system uses hardcoded addresses and DHCP shall not be tested. This is
used by default if the host address is found in /etc/hosts.
-n|--no-colors
Do not use colors in the output. This is the default if output is
redirected to a file.
-o seconds|--timeout=seconds
Timeout for ping, nslookup and wget, the default is $TTIMEOUT seconds.
-p|--speed
Perform a test of the network speed (it may take a little while).
-s|--show
Show more information.
-t|--test
Perform a test of the network functions.
-w|--wget
Use a wget spider to check reachability instead of ping. In some environments
ping is prohibited and will always fail.
EOD
exit
function reachable {
IPADDRESS=$1
#echo "IPAD: $IPADDRESS"
if [[ $RTYPE == "Ping" ]]; then
putOut "-Checking reachability with $RTYPE" "--"
ping -f -W $TTIMEOUT -c $TTIMES $IPADDRESS > /dev/null 2>&1
IRET=$?
else
#LC_ALL=C wget -v -d --tries=1 --timeout=1 --no-check-certificate https://192.168.1.1
LC_ALL=C wget -q --tries=$TTIMES --timeout=$TTIMEOUT --spider --no-check-certificate https://${IPADDRESS}
IRET=$?
fi
return $IRET
function putOut {
INAME=$1
if [[ ! -z $2 ]]; then
VALUES=$2
else
VALUES="--"
fi
UP=$(echo $INAME | grep '^[A-Z]')
if [[ ! -z $UP && $BAR == true ]]; then
BAR=false
echo "----"
fi
IFS="|"
let I=0
for VALUE in $VALUES; do
let I+=1
done
#echo "I=$I"
if [[ $I -gt 1 ]]; then
IFS=" | "
let I=0
let I+=1
NAME="$INAME[$I]"
printf "%-40s%s\n" $NAME "$VALUE"
done
else
printf "%-40s%s\n" $INAME $VALUE
fi
##########################################[ GETOPT ]####################################################################
TEMP=`getopt -od:fhno:pstw --long dns:,fixed,help,no-colors,timeout:,show,speed,test,wget -n $(basename $0) -- "$@"`
if [[ $? -ne 0 ]]; then
usage
fi
eval set -- "$TEMP"
TEST=false
SPEED=false
FIXED=false
QUIET=false
SHOW=false
RTYPE="Ping"
NEWDNS=""
CMDNAME=$(basename $0)
while true; do
case $1 in
-d|--dns)
shift
NEWDNS=$1
shift
-f|--fixed)
FIXED=true
shift
-h|--help)
usage
-n|--no-colors)
LILAC=""
GREEN=""
RED=""
STD=""
shift
-o|--timeout)
shift
TTIMEOUT=$1
shift
-p|--speed)
SPEED=true
shift
-s|--show)
SHOW=true
shift
-t|--test)
TEST=true
shift
-w|--wget)
RTYPE="Wget"
shift
shift
break
echo "-Got a star..."
shift
esac
done
PARAM=$1
if [[ ! -z $NEWDNS ]]; then
echo
echo "NEWDNS: $NEWDNS"
echo
exit
fi
##########################################[ STARTUP ]###################################################################
clear -x
echo
# asleep - disconnected - connecting - connected
#LC_ALL=C nmcli -t -f STATE general
#systemctl start NetworkManager.service
#OUT=$(LC_ALL=C nmcli -t -f RUNNING general 2>&1)
echo -e $LILAC"Network Manager:"$STD
RUNNING=$(nmcli -t -f RUNNING general 2>&1)
which systemctl >> /dev/null 2>&1; SYSTEMCTL=$?
if [[ $RUNNING == "running" ]]; then
echo $RUNNING
if [[ $SYSTEMCTL == 0 ]]; then
systemctl status NetworkManager.service
echo
fi
else
echo -en $RED
echo "-Network Manager is not running"
echo -e $GREEN
echo "-Try with:"
echo
echo " systemctl start NetworkManager.service"
else
echo " start network-manager"
fi
echo -e $RED
echo "-Can not continue..."
echo -e $STD
exit
fi
DNS84=false
DNS88=false
#CONNECTIONS=$(nmcli -t -f name,device con)
IFS=$STDIFS
if [[ -z $PARAM ]]; then
DEVICE=""
DEVICES=$(LC_ALL=C nmcli -t -f device,state,connection device | grep -v ^lo: | grep -v "unavailable" )
for DEV in $DEVICES; do
NAME=$(echo $DEV | awk -F : '{ print $1 }')
STATE=$(echo $DEV | awk -F : '{ print $2 }')
CONN=$(echo $DEV | awk -F : '{ print $3 }')
#echo "NAME: $NAME"
#echo "STATE: $STATE"
#echo "CONN: $CONN"
if [[ $STATE == "connected" || $STATE == "disconnected" ]]; then
#GWY=$(nmcli -g IP4.GATEWAY device show $DEV)
IPADDR12=$(nmcli -g IP4.ADDRESS dev show $NAME | awk -F . '{ print $1"."$2 }')
#if [[ $DEV != $CONN ]]; then
#if [[ $GWY != "0.0.0.0" ]]; then
if [[ $IPADDR12 != "169.254" ]]; then # Skip link-local
DEVICE=$NAME
break
fi
elif [[ $STATE == "unmanaged" ]]; then
DEVICE=$NAME # Save device, but let it be overritten if some better
fi # comes, that is in stat connected or disconnected.
done
else
DEVICE=$PARAM
fi
STDERR=$(nmcli -g GENERAL.DEVICE device show $DEVICE 2>&1 > /dev/null)
if [[ $? != 0 ]]; then
#nmcli -g GENERAL.DEVICE device show $DEVICE >> /dev/null 2>&1
echo -en $RED
echo $STDERR
echo -e $STD
exit
fi
#DEVICE="usb0"
#echo "DEVICE: $DEVICE"
if [[ ! -z $DEVICE ]]; then
CONNECTION=$(nmcli -g GENERAL.CONNECTION device show $DEVICE)
if [[ ! -z $CONNECTION ]]; then
#echo "CONNECTION: $CONNECTION"
GATEWAY=$(nmcli -g IP4.GATEWAY connection show "$CONNECTION")
#echo "GATEWAY: $GATEWAY"
CONDHSRVR=$(nmcli con show "$CONNECTION" | grep " domain_name_servers" | awk -F = '{ print $2 }' | xargs)
fi
IPADDR=$(nmcli -g IP4.ADDRESS device show "$DEVICE" | awk -F / '{ print $1 }')
#echo "IPADDR: $IPADDR"
else
CONNECTION=""
IPADDR=""
fi
#CONNECTION="Tårdbunden anslutning 2"
##########################################[ MAIN ]######################################################################
##########################################[ SHOW ]######################################################################
if [[ $SHOW == true ]]; then
echo -e $LILAC"General Status:"$STD
nmcli general status
echo
echo -e $LILAC"Devices:"$STD
nmcli dev
if [[ ! -z $(nmcli device wifi list) ]]; then
echo
echo -e $LILAC"WiFi:"$STD
fi
echo
echo -e $LILAC"Connections:"$STD
nmcli con show
echo
BAR=false
echo -e $LILAC'Device: "'$DEVICE'"'$STD
nmcli device show $DEVICE
else
echo -e $LILAC"Device: No specific device found - showing all..."$STD
DEVICE="<none>"
fi
echo
BAR=true
echo -e $LILAC'Connection: "'$CONNECTION'"'$STD
VALUES="$(nmcli -g connection.id connection show "$CONNECTION")"
putOut "connection.id" "$VALUES"
VALUES="$(nmcli -g connection.type connection show "$CONNECTION")"
putOut "connection.type" "$VALUES"
VALUES="$(nmcli -g connection.interface-name connection show "$CONNECTION")"
putOut "connection.interface-name" "$VALUES"
VALUES="$(nmcli -g connection.autoconnect connection show "$CONNECTION")"
putOut "connection.autoconnect" "$VALUES"
VALUES="$(nmcli -g connection.read-only connection show "$CONNECTION")"
putOut "connection.read-only" "$VALUES"
VALUES="$(nmcli -g 802-3-ethernet.mtu connection show "$CONNECTION")"
putOut "802-3-ethernet.mtu" "$VALUES"
VALUES="$(nmcli -g ipv4.method connection show "$CONNECTION")"
putOut "ipv4.method" "$VALUES"
VALUES="$(nmcli -g ipv4.dns connection show "$CONNECTION")"
putOut "ipv4.dns" $VALUES
VALUES="$(nmcli -g ipv4.addresses connection show "$CONNECTION")"
putOut "ipv4.addresses" $VALUES
VALUES="$(nmcli -g ipv4.gateway connection show "$CONNECTION")"
putOut "ipv4.gateway" $VALUES
VALUES="$(nmcli -g ipv4.routes connection show "$CONNECTION")"
putOut "ipv4.routes" $VALUES
VALUES="$(nmcli -g ipv4.ignore-auto-routes connection show "$CONNECTION")"
putOut "ipv4.ignore-auto-routes" $VALUES
VALUES="$(nmcli -g ipv4.ignore-auto-dns connection show "$CONNECTION")"
putOut "ipv4.ignore-auto-dns" $VALUES
else
CONNECTION="<none>"
echo -en $RED
echo "-No existing connection found..."
echo -en $STD
fi
echo
fi
##########################################[ TEST ]######################################################################
if [[ $TEST == true || $SPEED == true ]]; then
BAR=false
echo -e $LILAC'Internet: "'$CONNECTION'" via "'$DEVICE'"'$STD
if [[ $DEVICE == "" || $DEVICE == "<none>" ]]; then
echo -e $RED
echo "-Can not run test without a device..."
echo -e $STD
exit
fi
DNSs=$(nmcli -g IP4.DNS device show $DEVICE)
IFS=" | "
for DNS in $DNSs; do
if [[ $DNS == "8.8.4.4" ]]; then
DNS84=true
elif [[ $DNS == "8.8.8.8" ]]; then
DNS88=true
fi
done
fi
if [[ $TEST == true ]]; then
# GENERAL
#INTERNET=$(nmcli general status | tail -n +2 | awk '{ print $2 }')
NONETWORK=false
INTERNET=$(nmcli networking connectivity)
#INTERNET="limited"
if [[ $INTERNET == "full" ]]; then
putOut "General Status:" "Full (the computer reaches Internet)"
elif [[ $INTERNET == "limited" ]]; then
putOut "General Status:" "Limited connection (to the gateway, but no more)"
echo -e $RED
echo "-The host is connected to a network, but it has no access to the Internet."
echo "-Check that power is on, cables are connected and that the network is started."
echo -e $GREEN
echo "-Try with:"
echo
echo " nmcli device connect $DEVICE"
echo
echo " and if that does not work:"
echo
echo " nmcli networking on"
echo
echo "-Check also further on in the following tests..."
echo -e $STD
elif [[ $INTERNET == "portal" ]]; then
putOut "General Status:" "Portal"
echo -e $RED
echo "-The host is behind a captive portal and cannot reach the full Internet."
echo -e $STD
echo
exit
elif [[ $INTERNET == "none" ]]; then
putOut "General Status:" "Not connected"
echo -e $RED
echo "-The host is not connected to any network."
echo -e $GREEN
echo "-Try with:"
echo
echo
echo
echo -e $STD
echo
exit
elif [[ $INTERNET == "unknown" ]]; then
putOut "General Status:" "Unknown"
echo -e $RED
echo "-The connectivity status cannot be found out."
echo -e $STD
echo
exit
fi
echo
# DHCP
HOSTS=$(cat /etc/hosts | grep $(hostname) | grep -v 127.0 | awk -F \# '{ print $1 }' | awk '{ print $1 }')
if [[ ! -z $HOSTS ]]; then
putOut "NOT Testing DHCP" "Hostname exists in /etc/hosts"
elif [[ $FIXED == false ]]; then
putOut "Testing DHCP" "--"
if [[ $OS == "suse" ]]; then
DHCPADDR=$(dhclient -v 2>&1 >/dev/null | grep bound | awk '{ print $3 }')
IRET1=$?
DHCPSRVR=$(dhclient -v 2>&1 >/dev/null | grep DHCPACK | awk '{ print $3 }')
IRET2=$?
else
DHCPADDR=$(dhclient -v 2>&1 >/dev/null | grep DHCPACK | awk '{ print $3 }')
IRET1=$?
DHCPSRVR=$(dhclient -v 2>&1 >/dev/null | grep DHCPACK | awk '{ print $5 }')
IRET2=$?
fi
if [[ $IRET1 == 0 && $IRET2 == 0 ]]; then
putOut "-Got address from $DHCPSRVR:" "$DHCPADDR"
if [[ $DHCPADDR == $IPADDR ]]; then
putOut "--This is the currently used address" "Ok"
else
echo -en $RED
putOut "--Another address is used:" "$IPADDR"
echo "DHCPADDR: $DHCPADDR"
echo -en $STD
putOut "---DHCP has changed address to:" "$DHCPADDR"
else
echo -en $RED
putOut "---DHCP could not change address" "Fail"
echo
echo "-To fix this, you have to execute:"
echo
echo " ip addr flush dev $DEVICE"
echo -en $STD
fi
fi
else
putOut "-Got no address" "Fail ($IRET1/$IRET2)"
echo -e $RED
echo "-Check that the DHCP server (probably $GATEWAY) is setup to handle DHCP."
echo '-If hardcoded addresses is used, run this script with "-f" to skip this test'
echo -e $GREEN
echo "-Try with:"
echo
echo " dhclient -v"
echo -e $STD
echo
exit
fi
else
putOut "NOT Testing DHCP" "-f is specified"
fi
echo
# GATEWAY
putOut "Testing Gateway reachacility" "--"
reachable $GATEWAY
IRET=$?
###IRET=1
if [[ $IRET == 0 ]]; then
putOut "--Gateway is responding" "Ok"
else
putOut "--Gateway does NOT respond" "Fail"
echo -en $RED
echo "--Check that power is on, cables are connected and that network is started."
echo
echo "--Normally in a DHCP network, both the Gateway and the DHCP server is defined"
echo "--by DHCP. So check out the status of this server."
echo "--DHCP server: $DHCPSRVR"
echo "--Gateway: $GATEWAY"
if [[ $GATEWAY != $DHCPSRVR ]]; then
echo
echo "--Note! that Gateway is not the same as DHCP-server. Although this is quite"
echo "--possible, it is uncommon for home networks."
fi
echo -e $STD
echo
exit
fi
echo
# DNS
let EXTDNS=0
let TOTDNS=0
FIRSTDNS=""
DNSs=$(nmcli -g IP4.DNS connection show "$CONNECTION")
#echo "DNSs: >$DNSs<"
IFS=" | "
let TOTDNS+=1
putOut "Testing DNS from nmcli" "$DNS"
reachable $DNS
IRET=$?
putOut "--$RTYPE to $DNS" "Ok"
else
putOut "--$RTYPE to $DNS" "Fail ($IRET)"
fi
putOut "-Testing nameserver function" "--"
LOOKUP=$(nslookup -timeout=$TTIMEOUT "www.google,com" $DNS | wc -l)
IRET=$?
let EXTDNS+=1
if [[ -z $FIRSTDNS ]]; then
FIRSTDNS=$DNS
fi
putOut "--Nslookup via $DNS" "Ok"
else
putOut "--NSlookup via $DNS" "Fail"
fi
done
# RESOLV
IFS=$STDIFS
let INTDNS=0
RESOLVs=$(grep ^nameserver /etc/resolv.conf | awk '{ print $2 }')
for RESOLV in $RESOLVs; do
ALREADY_TESTED=false
for iDNS in $DNSs; do
DNS=$(echo $iDNS | xargs)
if [[ $RESOLV == $DNS ]]; then
ALREADY_TESTED=true
break
fi
done
if [[ $ALREADY_TESTED == false ]]; then
let TOTDNS+=1
if [[ $RESOLV == "127.0.0.53" ]]; then
putOut "Testing DNS from /etc/resolv.conf:" "$RESOLV (internal cache)"
putOut "-No test with $RTYPE is done" "-- (not possible for this address)"
else
putOut "Testing DNS from /etc/resolv.conf:" "$RESOLV"
if [[ ! -z $RESOLV ]]; then
reachable $RESOLV
IRET=$?
putOut "-$RTYPE to $RESOLV" "Ok"
else
putOut "-$RTYPE to $RESOLV" "Fail"
fi
fi
fi
LOOKUP=$(nslookup -timeout=$TTIMEOUT "www.google,com" $RESOLV | wc -l)
IRET=$?
if [[ $RESOLV != "127.0.0.53" ]]; then
FIRSTDNS=$HOST
fi
let EXTDNS+=1
else
let INTDNS+=1
fi
putOut "--Nslookup via $RESOLV" "Ok"
else
putOut "--NSlookup via $RESOLV" "Fail"
fi
else
#putOut "$RESOLV" "already tested"
fi
done
let WRKDNS=$EXTDNS+$INTDNS
putOut "Total defined DNSs:" "$TOTDNS"
putOut "Total working DNSs:" "$WRKDNS"
putOut "-Working External DNSs:" "$EXTDNS"
putOut "-Working Internal DNSs:" "$INTDNS"
###let EXTDNS=0
if [[ $EXTDNS -lt 1 ]]; then
echo -en $RED
echo "Total number of DNSs, that can translate site names are zero. This means"
echo "that it is maybe possible to reach external sites via their numerical"
echo "addresses, but NOT via their names."
echo
if [[ ! -z $DHCPADDR ]]; then
echo "DHCP is working so the DNS should probably be defined there. Check the DHCP-"
echo "server ($DHCPSRVR) so that everything is Ok there."
echo -e $GREEN
echo "To hardcode a DNS until this is fixed, you can try with:"
echo
echo ' nmcli con modify "'$CONNECTION'" +ipv4.dns "'8.8.8.8'"'
echo
echo " and then restart the connection with:"
echo
echo ' nmcli con down "'$CONNECTION'"'
echo ' nmcli con up "'$CONNECTION'"'
echo
echo "This setting is then removed with:"
echo
echo ' nmcli con modify "'$CONNECTION'" -ipv4.dns "'8.8.8.8'"'
echo
echo " and a restart in the same way."
echo
else
echo "DHCP is not used, so the DNS has to be defined in /etc/resolv.conf. Check"
echo "this file and add a nameserver there."
fi
echo -e $STD
echo
exit
fi
echo
# EXTERNAL IP
which wget >> /dev/null 2>&1
WGET=$?
which curl >> /dev/null 2>&1
CURL=$?
#FETCHADDR="http://nst.sourceforge.net/nst/tools/ip.php"
FETCHADDR="https://api.ipify.org"
if [[ $WGET == 0 ]]; then
LOOKUP=$(nslookup -timeout=$TTIMEOUT $FETCHADDR | wc -l)
IRET=$?
EXTIP=$(wget -qO - $FETCHADDR)
if [[ $? == 0 ]]; then
putOut "Checking External IP with Wget" "Ok"
putOut "-External IP address:" "$EXTIP"
else
putOut "Checking External IP with Wget" "Fail"
putOut "-External IP address:" "Fail"
fi
else
putOut "-No answer via nslookup" "Fail"
fi
elif [[ $CURL == 0 ]]; then
IRET=$?
EXTIP=$(curl -s $FETCHADDR)
putOut "Checking External IP with Curl" "Ok"
else
putOut "Checking External IP with Curl" "Fail"
putOut "-External IP address:" "--"
fi
fi
else
putOut "Checking External IP" "Fail"
echo -en $RED
echo "Neither Wget or Curl is installed, install one of them to check this..."
echo -en $STD
fi
echo
fi
# SPEED
if [[ $SPEED == true ]]; then
#putOut "Checking speed - this may take a while..." " "
echo "Checking speed - this may take a while..."
which speedtest-cli >> /dev/null 2>&1
SPEEDTEST=$?
#if [[ ! -z $(which speedtest-cli) ]]; then
if [[ $SPEEDTEST == 0 ]]; then
UPLOAD=$(speedtest-cli --no-download | grep "^Upload" | awk -F : '{ print $2 }' | xargs)
DOWNLOAD=$(speedtest-cli --no-upload | grep "^Download" | awk -F : '{ print $2 }' | xargs)
putOut "-Upload:" "$UPLOAD"
putOut "-Download:" $DOWNLOAD
else
putOut "-Not installed:" "speedtest-cli"
echo -en $RED
echo "speedtest-cli must be installed to check the connection speed..."
echo -en $STD
fi
else
echo -en $RED
echo "-Can not test speed, Internet is not available"
echo -en $STD
fi
echo
fi
exit
