Så därför har jag hackat ihop ett litet script som förenklar det, lite iaf:
#! /bin/bash
function usage {
cat << EOD
usage: cam { all | help | list | reset | set | show }
all
print all info (approximately "info"+"list")
help | -h | --help
show this
info
show info about the camera
list | show
lists the settings for available cameras
reset
reset the camera to its default settings
set [param=value]
set any of the parameters shown by "list" or "show" to a value,
as long as it is between MIN and MAX.
EOD
exit
TEMP=`getopt -oh --long help -n $(basename $0) -- "$@"`
if [[ $? -ne 0 ]]; then
usage
fi
eval set -- "$TEMP"
HELP=false
CMDNAME=$(basename $0)
while true; do
case $1 in
-h|--help)
usage
exit
shift
break
echo "-Got a star... [$1]"
exit
esac
done
FUNCTION=$1
PARAMVAL=$2
if [[ -z $(which which v4l2-ctl) ]]; then
echo
read -p "v4l2-ctl is not installed, do you want to install it? [y/N]: " IN
if [[ $IN == "y" || $IN == "Y" ]]; then
apt-get -y --allow-downgrades --allow-remove-essential --allow-change-held-packages --allow-unauthenticated install v4l-utils
else
echo
exit
fi
fi
WRITTEN=false
VIDEOS=$(v4l2-ctl --list-devices 2> /dev/null | grep /dev/video)
if [[ $? != 0 ]]; then
echo
echo "-Can not find any camera device..."
echo
exit
fi
for VIDEO in $VIDEOS; do
OUT=$(v4l2-ctl -d $VIDEO --list-ctrls)
if [[ ! -z $OUT ]]; then
WRITTEN=true
echo
echo $VIDEO
if [[ $FUNCTION == "help" ]]; then
usage
elif [[ $FUNCTION == "all" ]]; then
v4l2-ctl -d $VIDEO --all
elif [[ $FUNCTION == "info" ]]; then
v4l2-ctl -d $VIDEO --info
elif [[ $FUNCTION == "list" || $FUNCTION == "show" ]]; then
v4l2-ctl -d $VIDEO --list-ctrls-menus
elif [[ $FUNCTION == "set" ]]; then
if [[ ! -z $PARAMVAL ]]; then
PARAM=$(echo $PARAMVAL | awk -F = '{ print $1 }')
VALUE=$(echo $PARAMVAL | awk -F = '{ print $2 }')
if [[ -z $VALUE ]]; then
echo "-$PARAM has no value..."
echo
exit
fi
LINE=$(v4l2-ctl -d $VIDEO --list-ctrls-menus | grep "$PARAM ")
NAME=$(echo $LINE | awk '{ print $1 }' | xargs)
REST=$(echo $LINE | awk '{ $1=""; print $0 }' | xargs)
IFS=" "
for PARAM in $REST; do
if [[ ! -z $(echo $PARAM | grep "default=") ]]; then
DEFAULT=$(echo $PARAM | awk -F = '{ print $2 }')
elif [[ ! -z $(echo $PARAM | grep "min=") ]]; then
MIN=$(echo $PARAM | awk -F = '{ print $2 }')
elif [[ ! -z $(echo $PARAM | grep "max=") ]]; then
MAX=$(echo $PARAM | awk -F = '{ print $2 }')
fi
done
if [[ $VALUE -gt $MAX ]]; then
echo "-Value $VALUE is greater than MAX..."
elif [[ $VALUE -lt $MIN ]]; then
echo "-Value $VALUE is less than MIN..."
else
echo "v4l2-ctl --device $VIDEO --set-ctrl $PARAMVAL"
fi
else
echo "-Can not set $VIDEO to nothing..."
fi
elif [[ $FUNCTION == "reset" ]]; then
LINES=$(v4l2-ctl -d $VIDEO --list-ctrls | awk '{ $2=""; $3=""; $4=""; print $0 }')
IFS='
for LINE in $LINES; do
IFS=" "
if [[ ! -z $(echo $PARAM | grep "value=") ]]; then
VALUE=$(echo $PARAM | awk -F = '{ print $2 }')
elif [[ ! -z $(echo $PARAM | grep "default=") ]]; then
fi
done
PARAMVAL="$NAME=$DEFAULT"
if [[ $VALUE != $DEFAULT ]]; then
fi
IFS='
done
fi
fi
done
if [[ $WRITTEN == true ]]; then
echo
fi
#! /bin/bash
cam set brightness=110
cam set contrast=30
cam set saturation=20
cam set hue=200
cam set gamma=200
cam set backlight_compensation=50
Hoppas någon kan ha nytta av det...
