wine och winetricks priblem 20.04
lasseroth
Inlägg av lasseroth »
Efter gårdgens uppgradering från 18.04 gårallt bra
det enda jag har problemmed är wine och winetricks
Gömt innehåll: Visa!
sudo apt install wine64 wine32
Reading package lists... Done
Building dependency tree
Reading state information... Done
wine64 is already the newest version (5.0-3ubuntu1).
wine64 set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
ang.winetricks, försöker instalera adobe reader 1.7
lasse@lasses:~$ sudo winetricks
[sudo] password for lasse:
Running Wine/winetricks as root is highly discouraged. See https://wiki.winehq.org/FAQ#Should_I_ru ... as_root.3F
Executing mkdir -p /root
You are using a 64-bit WINEPREFIX. Note that many verbs only install 32-bit versions of packages. If you encounter problems, please retest in a clean 32-bit WINEPREFIX before reporting a bug.
Using winetricks 20200412 - sha256sum: 7651c93e39fcb080483c38836513bf912273a87ea97d137f6b958ed3d9628c3d with wine-5.0 (Ubuntu 5.0-3ubuntu1) and WINEARCH=win64
winetricks GUI enabled, using zenity 3.32.0
Executing w_do_call adobe_diged
Executing load_adobe_diged
Executing mkdir -p /root/.cache/winetricks/adobe_diged
Executing cd /root/.cache/winetricks/adobe_diged
Downloading https://kb2.adobe.com/cps/403/kb403051/ ... /setup.exe to /root/.cache/winetricks/adobe_diged
Executing cd /home/lasse
Executing wine /root/.cache/winetricks/adobe_diged/setup.exe
it looks like wine32 is missing, you should install it.
as root, please execute "apt-get install wine32"
002b:err:module:__wine_process_init L"Y:\\adobe_diged\\setup.exe" not supported on this system
Note: command wine /root/.cache/winetricks/adobe_diged/setup.exe returned status 123. Aborting.
Re: wine och winetricks priblem 20.04
Jag är ingen expert på Wine, men varför ska du installera wine64 och wine32 samtidigt..?
I övrigt prova med:
sudo apt-get -f install
...efteråt.....
Surfaren
Inlägg av Surfaren »
Blir nyfiken på varför du måste ha Adobe reader. De vanliga webläsarna visar ju pdf filer direkt.
Skit på dig Putin
lasseroth
adobe reader, jag lånar på biblioteket
Ang. wine
Verkligen ägnat många timmar på google.
Det verkar som om dom som har problem
är dom som precis som jag har uppgraderat
lasseroth
-f install
lasse@lasses:~$ sudo apt-get -f install
The following packages were automatically installed and are no longer required:
glib-networking:i386 gstreamer1.0-plugins-base:i386
gstreamer1.0-plugins-good:i386 gstreamer1.0-x:i386 i965-va-driver:i386
intel-media-va-driver:i386 libaa1:i386 libaom0:i386 libapparmor1:i386
libaribb24-0:i386 libasn1-8-heimdal:i386 libasound2:i386
libasound2-plugins:i386 libasyncns0:i386 libatomic1:i386
libavahi-client3:i386 libavahi-common-data:i386 libavahi-common3:i386
libavc1394-0:i386 libbrotli1:i386 libbsd0:i386 libcaca0:i386
libcairo-gobject2:i386 libcairo2:i386 libcap2:i386 libcapi20-3:i386
libcdparanoia0:i386 libcodec2-0.9:i386 libcups2:i386 libcurl3-gnutls:i386
libdatrie1:i386 libdbus-1-3:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386
libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libdv4:i386
libedit2:i386 libelf1:i386 libexif12:i386 libexpat1:i386 libffi7:i386
libflac8:i386 libfontconfig1:i386 libfreetype6:i386 libfribidi0:i386
libgd3:i386 libgdbm-compat4:i386 libgdbm6:i386 libgdk-pixbuf2.0-0:i386
libgl1:i386 libgl1-mesa-dri:i386 libglapi-mesa:i386 libglib2.0-0:i386
libglu1-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386
libgmp10:i386 libgnutls30:i386 libgomp1:i386 libgphoto2-6:i386
libgphoto2-port12:i386 libgraphite2-3:i386 libgsm1:i386
libgssapi-krb5-2:i386 libgssapi3-heimdal:i386
libgstreamer-plugins-base1.0-0:i386 libgstreamer-plugins-good1.0-0:i386
libgstreamer1.0-0:i386 libgudev-1.0-0:i386 libharfbuzz0b:i386
libhcrypto4-heimdal:i386 libheimbase1-heimdal:i386 libheimntlm0-heimdal:i386
libhogweed5:i386 libhx509-5-heimdal:i386 libicu66:i386 libiec61883-0:i386
libieee1284-3:i386 libigdgmm11:i386 libjack-jackd2-0:i386 libjbig0:i386
libjpeg-turbo8:i386 libjpeg8:i386 libk5crypto3:i386 libkeyutils1:i386
libkrb5-26-heimdal:i386 libkrb5-3:i386 libkrb5support0:i386 liblcms2-2:i386
libldap-2.4-2:i386 libllvm11:i386 libltdl7:i386 libmp3lame0:i386
libmpg123-0:i386 libmysqlclient21:i386 libnettle7:i386 libnghttp2-14:i386
libnuma1:i386 libodbc1:i386 libogg0:i386 libopenal1:i386
libopencore-amrnb0:i386 libopencore-amrwb0:i386 libopenjp2-7:i386
libopus0:i386 liborc-0.4-0:i386 libosmesa6:i386 libp11-kit0:i386
libpango-1.0-0:i386 libpangocairo-1.0-0:i386 libpangoft2-1.0-0:i386
libpcap0.8:i386 libpci3:i386 libpciaccess0:i386 libperl5.30:i386
libpixman-1-0:i386 libpng16-16:i386 libproxy1v5:i386 libpsl5:i386
libpulse0:i386 libraw1394-11:i386 libroken18-heimdal:i386 librsvg2-2:i386
librsvg2-common:i386 librtmp1:i386 libsamplerate0:i386 libsane:i386
libsasl2-2:i386 libsasl2-modules:i386 libsasl2-modules-db:i386
libsdl2-2.0-0:i386 libsensors5:i386 libshine3:i386 libshout3:i386
libslang2:i386 libsnappy1v5:i386 libsndfile1:i386 libsndio7.0:i386
libsnmp35:i386 libsoup2.4-1:i386 libsoxr0:i386 libspeex1:i386
libsqlite3-0:i386 libssh-4:i386 libssl1.1:i386 libstb0:i386 libstdc++6:i386
libtag1v5:i386 libtag1v5-vanilla:i386 libtasn1-6:i386 libthai0:i386
libtheora0:i386 libtiff5:i386 libtwolame0:i386 libusb-1.0-0:i386
libv4l-0:i386 libv4lconvert0:i386 libva-drm2:i386 libva-x11-2:i386
libva2:i386 libvdpau1:i386 libvisual-0.4-0:i386 libvkd3d1:i386
libvo-amrwbenc0:i386 libvorbis0a:i386 libvorbisenc2:i386 libvpx6:i386
libvulkan1:i386 libwavpack1:i386 libwayland-client0:i386
libwayland-cursor0:i386 libwayland-egl1:i386 libwebp6:i386 libwebpmux3:i386
libwind0-heimdal:i386 libwrap0:i386 libx11-6:i386 libx11-xcb1:i386
libx264-155:i386 libx265-179:i386 libxau6:i386 libxcb-dri2-0:i386
libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-randr0:i386
libxcb-render0:i386 libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386
libxcb1:i386 libxcomposite1:i386 libxcursor1:i386 libxdamage1:i386
libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxi6:i386 libxinerama1:i386
libxkbcommon0:i386 libxml2:i386 libxpm4:i386 libxrandr2:i386
libxrender1:i386 libxshmfence1:i386 libxslt1.1:i386 libxss1:i386 libxv1:i386
libxvidcore4:i386 libxxf86vm1:i386 libzvbi0:i386 mesa-va-drivers:i386
mesa-vdpau-drivers:i386 mesa-vulkan-drivers:i386 ocl-icd-libopencl1:i386
va-driver-all:i386 vdpau-driver-all:i386
Use 'sudo apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 14 not to upgrade.
lasse@lasses:~$
Vad händer om du kör:
sudo apt install libwine:i386
lasseroth
asse@lasses:~$ sudo apt install libwine:i386
libwine:i386 : Depends: libfaudio0:i386 (>= 19.06.07) but it is not going to be installed
lasse@lasses:~$
lasseroth skrev:-f install
...det där ser ju bara ut som att du bör köra "apt-get autoremove"....
lasseroth skrev:adobe reader, jag lånar på biblioteket
Ang. wine
Varför ska du hålla på och krångla med wine och adobe...??
Varför inte bara installera "okular"..??
lasseroth
okular kan inye ladda ner från stadsbiblioteket + att det finns ett annat exe program jag behöver
Kan inte riktigt prova det här, eftersom jag inte har något konto på stadsbiblioteket...
Men hur funkar det med t.ex https://linuxconfig.org/how-to-install- ... ossa-linux...?
lasseroth
tack för engagemang, men jag tycker inte det verkar vara vägen att gå
2 alternativ om wine misslyckas
frågat kompis som har gammal laptop
eller nyinstallera Ubuntu, men visst skulle det vara roligt om jag slapp
Frågan är var problemet egentligen ligger. Okular är en helt utomförträffligt bra PDF-läsare. Och hämta hem från Internet kan du ju (om du måste) hämta hem med både "wget" och "curl". Så jag har inte riktigt själva problembilden klar för mig.....
lasseroth
problemet är att biblioteket har rdm-skydd
okular kan inte ladda ner och eller öppna böckerna
man måste vara lösenordad på Adobe
man laddar ner en acsm fil som öppnas i adobe och kan som epub bara läsas i Adobe
Konstiga fel du får. :)
Vad säger det här kommandot:
dpkg --print-foreign-architectures
lasseroth
lasse@lasses:~$ dpkg --print-foreign-architectures
i386
lasse@lasses:~$
Det har jag också på min 20.04, men för mig kom inga protester när jag påbörjade installation av wine.
Det får mig att misstänka att du har installerat något från utanför det officiella Ubuntu-förrådet, såsom ett PPA eller någon annan extern källa. Sådant kan ställa till det i form av avvikande versioner av vissa paket. Med installation av wine följer ju rätt många i386-paket...
lasseroth
Jag vill inte på något sätt säga att det är löst
ny info har tillkommit i wiki som gör att det verkar som det är ett annat paket som bråkar nu
lasse@lasses:~$ sudo apt install libpulse0:i386
The following additional packages will be installed:
libapparmor1:i386 libasyncns0:i386 libbsd0:i386 libdbus-1-3:i386
libflac8:i386 libogg0:i386 libsndfile1:i386 libvorbis0a:i386
libvorbisenc2:i386 libwrap0:i386 libxau6:i386 libxcb1:i386 libxdmcp6:i386
The following NEW packages will be installed
libflac8:i386 libogg0:i386 libpulse0:i386 libsndfile1:i386 libvorbis0a:i386
0 to upgrade, 14 to newly install, 0 to remove and 0 not to upgrade.
Need to get 0 B/1 133 kB of archives.
After this operation, 4 272 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package libapparmor1:i386.
(Reading database ... 230247 files and directories currently installed.)
Preparing to unpack .../00-libapparmor1_2.13.3-7ubuntu5.1_i386.deb ...
Unpacking libapparmor1:i386 (2.13.3-7ubuntu5.1) ...
Selecting previously unselected package libbsd0:i386.
Preparing to unpack .../01-libbsd0_0.10.0-1_i386.deb ...
Unpacking libbsd0:i386 (0.10.0-1) ...
Selecting previously unselected package libdbus-1-3:i386.
Preparing to unpack .../02-libdbus-1-3_1.12.16-2ubuntu2.1_i386.deb ...
Unpacking libdbus-1-3:i386 (1.12.16-2ubuntu2.1) ...
Selecting previously unselected package libxau6:i386.
Preparing to unpack .../03-libxau6_1%3a1.0.9-0ubuntu1_i386.deb ...
Unpacking libxau6:i386 (1:1.0.9-0ubuntu1) ...
Selecting previously unselected package libxdmcp6:i386.
Preparing to unpack .../04-libxdmcp6_1%3a1.1.3-0ubuntu1_i386.deb ...
Unpacking libxdmcp6:i386 (1:1.1.3-0ubuntu1) ...
Selecting previously unselected package libxcb1:i386.
Preparing to unpack .../05-libxcb1_1.14-2_i386.deb ...
Unpacking libxcb1:i386 (1.14-2) ...
Selecting previously unselected package libasyncns0:i386.
Preparing to unpack .../06-libasyncns0_0.8-6_i386.deb ...
Unpacking libasyncns0:i386 (0.8-6) ...
Selecting previously unselected package libogg0:i386.
Preparing to unpack .../07-libogg0_1.3.4-0ubuntu1_i386.deb ...
Unpacking libogg0:i386 (1.3.4-0ubuntu1) ...
Selecting previously unselected package libflac8:i386.
Preparing to unpack .../08-libflac8_1.3.3-1build1_i386.deb ...
Unpacking libflac8:i386 (1.3.3-1build1) ...
Selecting previously unselected package libvorbis0a:i386.
Preparing to unpack .../09-libvorbis0a_1.3.6-2ubuntu1_i386.deb ...
Unpacking libvorbis0a:i386 (1.3.6-2ubuntu1) ...
Selecting previously unselected package libvorbisenc2:i386.
Preparing to unpack .../10-libvorbisenc2_1.3.6-2ubuntu1_i386.deb ...
Unpacking libvorbisenc2:i386 (1.3.6-2ubuntu1) ...
Selecting previously unselected package libsndfile1:i386.
Preparing to unpack .../11-libsndfile1_1.0.28-7_i386.deb ...
Unpacking libsndfile1:i386 (1.0.28-7) ...
Selecting previously unselected package libwrap0:i386.
Preparing to unpack .../12-libwrap0_7.6.q-30_i386.deb ...
Unpacking libwrap0:i386 (7.6.q-30) ...
Selecting previously unselected package libpulse0:i386.
Preparing to unpack .../13-libpulse0_1%3a13.99.1-1ubuntu3.10_i386.deb ...
Unpacking libpulse0:i386 (1:13.99.1-1ubuntu3.10) ...
Setting up libxau6:i386 (1:1.0.9-0ubuntu1) ...
Setting up libapparmor1:i386 (2.13.3-7ubuntu5.1) ...
Setting up libogg0:i386 (1.3.4-0ubuntu1) ...
Setting up libflac8:i386 (1.3.3-1build1) ...
Setting up libwrap0:i386 (7.6.q-30) ...
Setting up libdbus-1-3:i386 (1.12.16-2ubuntu2.1) ...
Setting up libvorbis0a:i386 (1.3.6-2ubuntu1) ...
Setting up libasyncns0:i386 (0.8-6) ...
Setting up libbsd0:i386 (0.10.0-1) ...
Setting up libvorbisenc2:i386 (1.3.6-2ubuntu1) ...
Setting up libxdmcp6:i386 (1:1.1.3-0ubuntu1) ...
Setting up libxcb1:i386 (1.14-2) ...
Setting up libsndfile1:i386 (1.0.28-7) ...
Setting up libpulse0:i386 (1:13.99.1-1ubuntu3.10) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
lasse@lasses:~$ sudo dpkg --add-architecture i386 && sudo apt update
Hit:1 http://archive.canonical.com/ubuntu focal InRelease
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
Hit:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:7 https://dl.winehq.org/wine-builds/ubuntu xenial InRelease
Hit:8 http://archive.ubuntu.com/ubuntu focal-security InRelease
All packages are up-to-date.
lasse@lasses:~$ udo dpkg --add-architecture i386 && sudo apt update
Command 'udo' not found, but can be installed with:
sudo apt install udo
lasse@lasses:~$ sudo apt install \
> wine-development \
> wine32-development \
> wine64-development \
> libwine-development \
> libwine-development:i386 \
> fonts-wine
libwine-development : Depends: libfaudio0 (>= 19.06.07) but it is not going to be installed
libwine-development:i386 : Depends: libfaudio0:i386 (>= 19.06.07) but it is not going to be installed
lasse@lasses:~$
lasseroth skrev:ny info har tillkommit i wiki
Vilken wiki?
lasseroth skrev:som gör att det verkar som det är ett annat paket som bråkar nu
Vad jag kan se kör den fast på libfaudio0:i386, dvs. samma paket som den inte ville installera när du försökte installera libwine:i386.
Kan du köra det här kommandot och visa oss resultatet:
grep -vE '^(#|$)' /etc/apt/sources.list /etc/apt/sources.list.d/*.list
anth
Inlägg av anth »
Har du provat att installera acrobat reader som snap?
$ sudo apt update
$ sudo apt install snapd
$ sudo snap install acrordrdc
Edit: korrigerade felaktigt kommando, det ska vara snap install acrordrdc, inte apt install.
anth skrev:Har du provat att installera acrobat reader som snap?
$ sudo apt update
$ sudo apt install acrordrdc
Kreativ idé! Fast det sista kommandot blir förstås då:
@lasseroth: Detta är värt att prova innan vi trasslar vidare med ditt paketproblem.
