#1. Installera "alldisks" som ger info om alla diskar (och partitioner) som finns....
#! /bin/bash
function usage {
cat << EOD
alldisks [-d|-p] [-b bus] [-f filesystem] [-v]
Get a list of all disks that meer ceratin criterias.
-d|-p
Specifies if disks or partitions are to be shown. If none of them
is specified, partitions is the default.
-b bus
Specifies which kind of disks that are to be shown. Possible values
are for example "ata" or "usb". If nor specified, all disks are shown.
-f filesystem
Specifies the filesystem a partition must have to be shown. Possible
values are for example "ntfs", "fat", "ext3" or "ext4". It is also
possible to specify "ext", which means that "ext2", "ext3" and "ext4"
is shown but! "extended" is not shown, as it is no filesystem. If not
specified, all partitions are shown.
-v
Tells the command to be verbose and print the bus and the filesystem
for each partition and the bus for each disk. This can for example be
used to determine how to search for the right disks.
Example:
alldisks
alldisks -p -b usb
alldisks -p -b usb -f ext4
EOD
function filesystem {
if [[ -z $1 ]]; then
PART=$(mount | grep "$(dirname $(readlink -f $(pwd)) | awk -F / '{ print "/"$2 }') " | awk '{ print $1 }')
else
PART=$1
fi
FS=$(blkid -o value -s TYPE $PART)
if [[ -z $FS ]]; then
NUM=$(echo $PART | tr -dc '0-9')
DEV=$(echo $PART | sed 's/[0-9]//g')
TYP=$(parted $DEV print | sed -n '/Nummer/,$p' | tail -n +2 | head -c -1 | sed 's/^ //g' | grep "^$NUM" | awk '{ print $5 }')
if [[ ! -z $TYP ]]; then
echo $TYP
else
TYP=$(parted $DEV print | sed -n '/Number/,$p' | tail -n +2 | head -c -1 | sed 's/^ //g' | grep "^$NUM" | awk '{ print $5 }')
echo $TYP
else
echo "none1"
fi
fi
else
echo $FS
fi
function alldisks {
pFUNC=$1
pBUS=$2
pFS=$3
pDEV=$4
if [[ $pFUNC == "disk" ]]; then
# -Show all disks
DISKS=$(fdisk -l 2>> /dev/null | grep ^/dev | awk '{ print $1 }' | sed 's/[1-9]//g' | sort -u)
for DISK in $DISKS; do
if [[ ! -z $(echo $DISK | grep $pDEV) ]]; then
BUS=$(udevadm info --query=all -n $DISK | grep ID_BUS | awk -F = '{ print $2 }')
#FS=$(filesystem $PART)
FS="disk"
if [[ $pBUS == "all" ]]; then
if [[ $pFS == "all" ]]; then
if [[ $VERB == false ]]; then
echo $DISK
else
printf "%-12s%4s %s\n" $DISK $BUS $FS
fi
else
if [[ ! -z $(echo $FS | grep $pFS) ]]; then
echo $DISK
else
fi
fi
fi
else
if [[ $BUS == $pBUS ]]; then
echo $DISK
else
fi
elif [[ ! -z $(echo $FS | grep $pFS) ]]; then
echo $DISK
else
fi
fi
fi
fi
fi
done
elif [[ $pFUNC == "part" ]]; then
# -Show all parts
PARTS=$(fdisk -l 2>> /dev/null | grep ^/dev | awk '{ print $1 }')
for PART in $PARTS; do
if [[ ! -z $(echo $PART | grep $pDEV) ]]; then
BUS=$(udevadm info --query=all -n $PART | grep ID_BUS | awk -F = '{ print $2 }')
echo $PART
else
printf "%-12s%4s %s\n" $PART $BUS $FS
fi
if [[ $pFS != "ext" || $FS != "extended" ]]; then
echo $PART
else
fi
fi
fi
elif [[ $BUS == $pBUS ]]; then
#echo "BUS: $BUS"
#echo "FS: $FS"
#echo "P3: $3"
echo $PART
else
fi
if [[ $pFS != "ext" && $FS != "extended" ]]; then
echo $PART
else
fi
fi
fi
fi
fi
done
fi
TEMP=`getopt -ob:df:hpv --long bus:,disk,fs:,help,part,verb -n $(basename $0) -- "$@"`
if [[ $? -ne 0 ]]; then
usage
exit
fi
eval set -- "$TEMP"
FS="all"
BUS="all"
DISK=false
HELP=false
PART=false
VERB=false
while true; do
case $1 in
-b|--bus)
shift
BUS=$1
shift
-d|--disk)
DISK=true
shift
-f|--fs)
shift
FS=$1
shift
-h|--help)
HELP=true
shift
-p|--part)
PART=true
shift
-v|--verb)
VERB=true
shift
shift
break
shift
esac
done
DEV="/dev"
else
DEV=$1
fi
P1=$1
P2=$2
P3=$3
if [[ $HELP == true ]]; then
usage
exit
elif [[ $DISK == false && $PART == false ]]; then
PART=true
elif [[ $DISK == true && $PART == true ]]; then
echo "-Both --disk and --part is specified, unable to do both"
echo
exit
fi
if [[ $DISK == true ]]; then
alldisks disk $BUS $FS $DEV
else
alldisks part $BUS $FS $DEV
fi
rsrvd:
#! /bin/bash
# Needs: alldisks
# -If DEBUG is set to "true", nothing is actually changed
DEBUG=true
SCRIPTDIR=$(dirname $(readlink -f $0))
function usage {
cat << EOD
rsrvd [-e] [partition]
-e Edit, possibly change the reserved space size
partition Name of the partition to show/modify (if -a is not specified).
EOD
exit
function lcalc {
awk --use-lc-numeric "BEGIN { print $* ; }"
function isnum {
if [[ $1 =~ ^[0-9]+$ ]]; then
return 0
fi
return 1
function isBlockfile {
if [[ -b $1 ]]; then
return 0
fi
return 1
function isDisk {
partNum=$(echo $1 | grep [1-9])
if [[ -z $partNum ]]; then
return 0
fi
return 1
fi
return 1
function isPart {
if [[ ! -z $partNum ]]; then
return 0
fi
return 1
fi
return 1
function btoh {
echo $1 | awk '{sum=$1;
#hum[1024**4]="Tb";hum[1024**3]="Gb";hum[1024**2]="Mb";hum[1024**1]="Kb";hum[1024**0]="B";
hum[1024**3]="Tb";hum[1024**2]="Gb";hum[1024**1]="Mb";hum[1024**0]="Kb";
for (x=1024**4; x>=1; x/=1024){
if (sum>=x) {
#printf "6.2f %s\n",sum/x,hum[x];break # For fixed length and positions
printf "%.2f %s\n",sum/x,hum[x];break
function checkInput {
# input, min, max
INP=$1
MIN=$2
MAX=$3
isnum $INP; IRET=$?
if [[ $IRET -gt 0 ]]; then
echo "-Value is no positive integer" >> /dev/tty
return 1
elif [[ $INP -lt $MIN ]]; then
echo "-Value is less than 0%" >> /dev/tty
return 1
elif [[ $INP -gt $MAX ]]; then
echo "-Value is bigger than the default 5%" >> /dev/tty
return 2
fi
return 0
function checkReserved {
pPART=$1
pEDIT=$2
FS=$(blkid -o value -s TYPE $pPART)
if [[ $FS == "ext3" || $FS == "ext4" ]]; then
rsrvd=$(tune2fs -l $pPART 2> /dev/null | grep 'Reserved block count' | awk -F : '{ print $2 }' | xargs)
blocks=$(tune2fs -l $pPART 2> /dev/null | grep 'Block count' | awk -F : '{ print $2 }' | xargs)
blksiz=$(tune2fs -l $pPART 2> /dev/null | grep 'Block size' | awk -F : '{ print $2 }' | xargs)
let factor=$blksiz/1024
let rsrvd_kbytes=$rsrvd*$factor
if [[ ! -z $rsrvd ]]; then
# -Normally 5% of a disk is reserved for root etc. to make it possible
# -for root to login and fix even if the disk is full.
# -However, it is possible to set reserved count to 0 (zero).
if [[ $rsrvd == 0 ]]; then
RESERVED_SIZ="0"
RESERVED_PCT="0"
else
RESERVED_SIZ=$(btoh $rsrvd_kbytes)
RESERVED_PCT=$(lcalc 100*$rsrvd/$blocks)
fi
if [[ $pEDIT == true ]]; then
printf "%-10s%15s%10.2f%%\n" "$PART" "$RESERVED_SIZ" "$RESERVED_PCT"
read -p "_Trim? enter an Integer for percents or Enter to skip: " IN
if [[ ! -z $IN ]]; then
# input, min, max, value
checkInput $IN 0 5; IRET=$?
if [[ $IRET -eq 0 ]]; then
if [[ $DEBUG == false ]]; then
tune2fs -m $IN $pPART
else
echo "tune2fs -m $IN $pPART"
fi
elif [[ $IRET -eq 2 ]]; then
echo "-Value converted to 5, do you want to continue? [y/N]: " IN
if [[ $IN == "y" || $IN == "Y" ]]; then
tune2fs -m 5 $pPART
else
echo "tune2fs -m 5 $pPART"
fi
fi
fi
fi
echo
else
fi
fi
else
RESERVED_SIZ="0"
RESERVED_PCT="0"
DEV=$(echo $pPART | sed 's/[0-9]//g')
NUM=$(echo $pPART | tr -dc '0-9')
FS=$TYP
else
FS=$TYP
else
FS="none"
fi
fi
fi
echo "-$pPART "'does not seem to be a valid ext3/ext4 filesystem, it seems tp be "'$FS'"'
return 1
fi
return 0
Det som scriptet gör är att visa hur stor del av diskarna som är reserverat. Varje disk/partition inom EXT3 och EXT4 reserverar 5% som extra urymme för att root ska kunna reda ut problem.... men på stora diskar är 5% vansinnigt mycket och definitivt mer än vad som behövs....
Med de här scripten kan man lätt se hur mycket som är upplåst och ändra det (rsrvd -e).... Slösa inte disk i onödan, även om funktionen i sig är bra....
