GIMP 2.10.36
GIMP 2.10.36
GIMP 2.10.0 har släppts, sex år efter 2.8.0, och mycket har förstås ändrats på den tiden. Stöd för WebP, äntligen. Bevarande av metadata är också välkommet (i TIFF, PNG, JPEG och WebP).
GIMP 2.10.0 Released
GIMP 2.10 Release Notes
Re: GIMP 2.10.0
PPA med GIMP 2.10 för Ubuntu 17.10 och 18.04: https://launchpad.net/~otto-kesselgulas ... buntu/gimp
Re: GIMP 2.10.2
Re: GIMP 2.10.4
Re: GIMP 2.10.6
Re: GIMP 2.10.8
Re: GIMP 2.10.8
GIMP and GEGL in 2018
In this post, we are looking back at 2018 and then forward to outline future work on GIMP, GEGL, and babl.
Re: GIMP 2.10.10
Re: GIMP 2.10.12
Re: GIMP 2.10.14
Re: GIMP 2.10.18
GIMP 2.10.18 Released
We skipped announcing 2.10.16 due to a critical bug. Together, the two updates deliver several major usability improvements, a new tool for transformations in 3D space, new release checker, and the usual amount of bug fixes.
Re: GIMP 2.10.20
Re: GIMP 2.10.22
Re: GIMP 2.10.22
GIMP 2.99.2 Released (beta)
GIMP 2.99.2 marks the first step towards GIMP 3 based on GTK3 user interface toolkit.
Re: GIMP 2.10.22
This is 25
Exactly 25 years ago, Peter Mattis wrote a message to several newsgroups announcing a new image editor called GIMP.
Re: GIMP 2.10.22
Re: GIMP 2.10.24
GIMP 2.10.24 Released
Updated on 2021-03-30: GIMP 2.10.24 installer revision 1
Fixes issue #6664: Script-Fu crashes on 64-bit systems.
Re: GIMP 2.10.24
Re: GIMP 2.10.28
GIMP 2.10.28 Released
Note: you may have noticed we skipped GIMP 2.10.26. A build bug has been discovered just after tagging the release. GIMP 2.10.28 is the same without the bug. We recommend against building and using GIMP 2.10.26.
Re: GIMP 2.10.28
Återgå till "Bildhantering"
