[ 11.772]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 11.773] X Protocol Version 11, Revision 0
[ 11.773] Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
[ 11.773] Current Operating System: Linux lasse-System-Product-Name 4.4.0-64-generic #85-Ubuntu SMP Mon Feb 20 11:50:30 UTC 2017 x86_64
[ 11.773] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-64-generic root=UUID=963e84e3-f184-460b-958f-2a7f24d25f3a ro quiet splash vt.handoff=7
[ 11.773] Build Date: 02 November 2016 10:06:10PM
[ 11.773] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see
http://www.ubuntu.com/support)
[ 11.773] Current version of pixman: 0.33.6
[ 11.773] Before reporting problems, check
http://wiki.x.org
to make sure that you have the latest version.
[ 11.773] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 11.773] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 6 22:28:11 2017
[ 11.773] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.775] (==) No Layout section. Using the first Screen section.
[ 11.775] (==) No screen section available. Using defaults.
[ 11.775] (**) |-->Screen "Default Screen Section" (0)
[ 11.775] (**) | |-->Monitor "<default monitor>"
[ 11.776] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 11.776] (==) Automatically adding devices
[ 11.776] (==) Automatically enabling devices
[ 11.776] (==) Automatically adding GPU devices
[ 11.776] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.776] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 11.776] Entry deleted from font path.
[ 11.776] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 11.776] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 11.777] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 11.777] Entry deleted from font path.
[ 11.777] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 11.777] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 11.777] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 11.777] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 11.777] (II) Loader magic: 0x557c7a231dc0
[ 11.777] (II) Module ABI versions:
[ 11.777] X.Org ANSI C Emulation: 0.4
[ 11.777] X.Org Video Driver: 20.0
[ 11.777] X.Org XInput driver : 22.1
[ 11.777] X.Org Server Extension : 9.0
[ 11.777] (++) using VT number 7
[ 11.777] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.778] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.779] (--) PCI:*(0:0:2:0) 8086
1043:844d rev 9, Mem @ 0xfb400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[ 11.779] (II) LoadModule: "glx"
[ 11.780] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.793] (II) Module glx: vendor="X.Org Foundation"
[ 11.793] compiled for 1.18.4, module version = 1.0.0
[ 11.793] ABI class: X.Org Server Extension, version 9.0
[ 11.793] (==) AIGLX enabled
[ 11.793] (==) Matched intel as autoconfigured driver 0
[ 11.793] (==) Matched intel as autoconfigured driver 1
[ 11.793] (==) Matched modesetting as autoconfigured driver 2
[ 11.793] (==) Matched fbdev as autoconfigured driver 3
[ 11.793] (==) Matched vesa as autoconfigured driver 4
[ 11.793] (==) Assigned the driver to the xf86ConfigLayout
[ 11.793] (II) LoadModule: "intel"
[ 11.794] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 11.797] (II) Module intel: vendor="X.Org Foundation"
[ 11.797] compiled for 1.18.4, module version = 2.99.917
[ 11.797] Module class: X.Org Video Driver
[ 11.797] ABI class: X.Org Video Driver, version 20.0
[ 11.797] (II) LoadModule: "modesetting"
[ 11.797] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.798] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.798] compiled for 1.18.4, module version = 1.18.4
[ 11.798] Module class: X.Org Video Driver
[ 11.798] ABI class: X.Org Video Driver, version 20.0
[ 11.798] (II) LoadModule: "fbdev"
[ 11.798] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 11.799] (II) Module fbdev: vendor="X.Org Foundation"
[ 11.799] compiled for 1.18.1, module version = 0.4.4
[ 11.799] Module class: X.Org Video Driver
[ 11.799] ABI class: X.Org Video Driver, version 20.0
[ 11.799] (II) LoadModule: "vesa"
[ 11.799] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 11.799] (II) Module vesa: vendor="X.Org Foundation"
[ 11.799] compiled for 1.18.1, module version = 2.3.4
[ 11.799] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 11.800] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[ 11.800] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[ 11.800] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
[ 11.800] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 11.800] (II) FBDEV: driver for framebuffer: fbdev
[ 11.800] (II) VESA: driver for VESA chipsets: vesa
[ 11.800] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20151010
[ 11.800] (II) intel(0): SNA compiled: xserver-xorg-video-intel 2:2.99.917+git20160325-1ubuntu1.2 (Timo Aaltonen <
tjaalton@debian.org>)
[ 11.800] (II) intel(0): SNA compiled for use with valgrind
[ 11.802] (WW) Falling back to old probe method for modesetting
[ 11.802] (WW) Falling back to old probe method for fbdev
[ 11.802] (II) Loading sub module "fbdevhw"
[ 11.802] (II) LoadModule: "fbdevhw"
[ 11.802] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 11.802] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 11.802] compiled for 1.18.4, module version = 0.0.2
[ 11.802] ABI class: X.Org Video Driver, version 20.0
[ 11.802] (WW) Falling back to old probe method for vesa
[ 11.803] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 3000
[ 11.803] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx; using a maximum of 4 threads
[ 11.803] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 11.803] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 11.803] (==) intel(0): RGB weight 888
[ 11.803] (==) intel(0): Default visual is TrueColor
[ 11.803] (II) intel(0): Output VGA1 has no monitor section
[ 11.803] (II) intel(0): Enabled output VGA1
[ 11.803] (II) intel(0): Output HDMI1 has no monitor section
[ 11.803] (II) intel(0): Enabled output HDMI1
[ 11.803] (II) intel(0): Output DP1 has no monitor section
[ 11.803] (II) intel(0): Enabled output DP1
[ 11.803] (II) intel(0): Output HDMI2 has no monitor section
[ 11.803] (II) intel(0): Enabled output HDMI2
[ 11.803] (II) intel(0): Output HDMI3 has no monitor section
[ 11.803] (II) intel(0): Enabled output HDMI3
[ 11.803] (II) intel(0): Output DP2 has no monitor section
[ 11.803] (II) intel(0): Enabled output DP2
[ 11.803] (II) intel(0): Output DP3 has no monitor section
[ 11.803] (II) intel(0): Enabled output DP3
[ 11.803] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 11.803] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 11.803] (II) intel(0): Enabled output VIRTUAL1
[ 11.803] (--) intel(0): Output HDMI3 using initial mode 1920x1080 on pipe 0
[ 11.803] (==) intel(0): TearFree disabled
[ 11.803] (==) intel(0): DPI set to (96, 96)
[ 11.803] (II) Loading sub module "dri2"
[ 11.803] (II) LoadModule: "dri2"
[ 11.803] (II) Module "dri2" already built-in
[ 11.803] (II) Loading sub module "present"
[ 11.803] (II) LoadModule: "present"
[ 11.803] (II) Module "present" already built-in
[ 11.803] (II) UnloadModule: "modesetting"
[ 11.803] (II) Unloading modesetting
[ 11.803] (II) UnloadModule: "fbdev"
[ 11.803] (II) Unloading fbdev
[ 11.803] (II) UnloadSubModule: "fbdevhw"
[ 11.803] (II) Unloading fbdevhw
[ 11.804] (II) UnloadModule: "vesa"
[ 11.804] (II) Unloading vesa
[ 11.804] (==) Depth 24 pixmap format is 32 bpp
[ 11.809] (II) intel(0): SNA initialized with Sandybridge (gen6, gt2) backend
[ 11.809] (==) intel(0): Backing store enabled
[ 11.809] (==) intel(0): Silken mouse enabled
[ 11.810] (II) intel(0): HW Cursor enabled
[ 11.810] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 11.811] (==) intel(0): DPMS enabled
[ 11.811] (==) intel(0): Display hotplug detection enabled
[ 11.811] (II) intel(0): [DRI2] Setup complete
[ 11.811] (II) intel(0): [DRI2] DRI driver: i965
[ 11.811] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 11.811] (II) intel(0): direct rendering: DRI2 enabled
[ 11.811] (II) intel(0): hardware support for Present enabled
[ 11.811] (--) RandR disabled
[ 11.814] (II) SELinux: Disabled on system
[ 11.842] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 11.842] (II) AIGLX: enabled GLX_ARB_create_context
[ 11.842] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 11.842] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 11.842] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 11.842] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 11.842] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 11.842] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 11.842] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 11.842] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 11.842] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 11.842] (II) AIGLX: Loaded and initialized i965
[ 11.842] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 11.845] (II) intel(0): switch to mode 1920x1080@60.0 on HDMI3 using pipe 0, position (0, 0), rotation normal, reflection none
[ 11.845] (II) intel(0): Setting screen physical size to 508 x 285
[ 11.874] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 11.874] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 11.874] (II) LoadModule: "evdev"
[ 11.874] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 11.876] (II) Module evdev: vendor="X.Org Foundation"
[ 11.876] compiled for 1.18.1, module version = 2.10.1
[ 11.876] Module class: X.Org XInput Driver
[ 11.876] ABI class: X.Org XInput driver, version 22.1
[ 11.876] (II) Using input driver 'evdev' for 'Power Button'
[ 11.876] (**) Power Button: always reports core events
[ 11.876] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 11.876] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 11.876] (--) evdev: Power Button: Found keys
[ 11.876] (II) evdev: Power Button: Configuring as keyboard
[ 11.876] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 11.876] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 11.876] (**) Option "xkb_rules" "evdev"
[ 11.876] (**) Option "xkb_model" "pc105"
[ 11.876] (**) Option "xkb_layout" "se"
[ 11.888] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
[ 11.888] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 11.888] (II) Using input driver 'evdev' for 'Video Bus'
[ 11.888] (**) Video Bus: always reports core events
[ 11.888] (**) evdev: Video Bus: Device: "/dev/input/event2"
[ 11.888] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 11.888] (--) evdev: Video Bus: Found keys
[ 11.888] (II) evdev: Video Bus: Configuring as keyboard
[ 11.888] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5/event2"
[ 11.888] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 11.888] (**) Option "xkb_rules" "evdev"
[ 11.888] (**) Option "xkb_model" "pc105"
[ 11.888] (**) Option "xkb_layout" "se"
[ 11.888] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 11.888] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 11.888] (II) Using input driver 'evdev' for 'Power Button'
[ 11.888] (**) Power Button: always reports core events
[ 11.888] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 11.888] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 11.888] (--) evdev: Power Button: Found keys
[ 11.888] (II) evdev: Power Button: Configuring as keyboard
[ 11.888] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 11.888] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id
[ 11.889] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[ 11.889] (II) No input driver specified, ignoring this device.
[ 11.889] (II) This device may have been added with another device file.
[ 11.889] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event8)
[ 11.889] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event9)
[ 11.889] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event10)
[ 11.889] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event11)
[ 11.889] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event12)
[ 11.890] (II) No input driver specified, ignoring this device.
[ 11.890] (II) This device may have been added with another device file.
[ 11.890] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 11.890] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event5)
[ 11.890] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6)
[ 11.890] (II) config/udev: Adding input device USBPS2 (/dev/input/event3)
[ 11.890] (**) USBPS2: Applying InputClass "evdev keyboard catchall"
[ 11.890] (II) Using input driver 'evdev' for 'USBPS2'
[ 11.890] (**) USBPS2: always reports core events
[ 11.890] (**) evdev: USBPS2: Device: "/dev/input/event3"
[ 11.890] (--) evdev: USBPS2: Vendor 0xd3d Product 0x1
[ 11.890] (--) evdev: USBPS2: Found keys
[ 11.890] (II) evdev: USBPS2: Configuring as keyboard
[ 11.890] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:0D3D:0001.0001/input/input6/event3"
[ 11.890] (II) XINPUT: Adding extended input device "USBPS2" (type: KEYBOARD, id 9)
[ 11.890] (**) Option "xkb_rules" "evdev"
[ 11.891] (II) config/udev: Adding input device USBPS2 (/dev/input/event4)
[ 11.891] (**) USBPS2: Applying InputClass "evdev pointer catchall"
[ 11.891] (**) USBPS2: Applying InputClass "evdev keyboard catchall"
[ 11.891] (II) Using input driver 'evdev' for 'USBPS2'
[ 11.891] (**) USBPS2: always reports core events
[ 11.891] (**) evdev: USBPS2: Device: "/dev/input/event4"
[ 11.891] (--) evdev: USBPS2: Vendor 0xd3d Product 0x1
[ 11.891] (--) evdev: USBPS2: Found 9 mouse buttons
[ 11.891] (--) evdev: USBPS2: Found scroll wheel(s)
[ 11.891] (--) evdev: USBPS2: Found relative axes
[ 11.891] (--) evdev: USBPS2: Found x and y relative axes
[ 11.891] (--) evdev: USBPS2: Found absolute axes
[ 11.891] (II) evdev: USBPS2: Forcing absolute x/y axes to exist.
[ 11.891] (--) evdev: USBPS2: Found keys
[ 11.891] (II) evdev: USBPS2: Configuring as mouse
[ 11.891] (II) evdev: USBPS2: Configuring as keyboard
[ 11.891] (II) evdev: USBPS2: Adding scrollwheel support
[ 11.891] (**) evdev: USBPS2: YAxisMapping: buttons 4 and 5
[ 11.891] (**) evdev: USBPS2: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 11.891] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:0D3D:0001.0002/input/input7/event4"
[ 11.891] (II) XINPUT: Adding extended input device "USBPS2" (type: KEYBOARD, id 10)
[ 11.891] (**) Option "xkb_rules" "evdev"
[ 11.891] (II) evdev: USBPS2: initialized for relative axes.
[ 11.891] (WW) evdev: USBPS2: ignoring absolute axes.
[ 11.891] (**) USBPS2: (accel) keeping acceleration scheme 1
[ 11.891] (**) USBPS2: (accel) acceleration profile 0
[ 11.891] (**) USBPS2: (accel) acceleration factor: 2.000
[ 11.891] (**) USBPS2: (accel) acceleration threshold: 4
[ 11.891] (II) config/udev: Adding input device USBPS2 (/dev/input/mouse0)
[ 11.891] (II) No input driver specified, ignoring this device.
[ 11.891] (II) This device may have been added with another device file.
[ 11.892] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event14)
[ 11.892] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 11.892] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[ 11.892] (**) Eee PC WMI hotkeys: always reports core events
[ 11.892] (**) evdev: Eee PC WMI hotkeys: Device: "/dev/input/event14"
[ 11.892] (--) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 11.892] (--) evdev: Eee PC WMI hotkeys: Found keys
[ 11.892] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 11.892] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input17/event14"
[ 11.892] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 11)
[ 11.892] (**) Option "xkb_rules" "evdev"
[ 11.892] (**) Option "xkb_model" "pc105"
[ 11.892] (**) Option "xkb_layout" "se"
[ 13.517] (--) intel(0): HDMI max TMDS frequency 225000KHz
[ 13.580] (--) intel(0): HDMI max TMDS frequency 225000KHz
[ 13.646] (--) intel(0): HDMI max TMDS frequency 225000KHz
[ 63.690] (--) intel(0): HDMI max TMDS frequency 225000KHz
[ 65.574] (II) config/udev: Adding input device USBPS2 (/dev/input/mouse0)
[ 65.574] (II) No input driver specified, ignoring this device.
[ 65.574] (II) This device may have been added with another device file.
[ 65.579] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse1)
[ 65.579] (II) No input driver specified, ignoring this device.
[ 65.579] (II) This device may have been added with another device file.
[ 65.589] (WW) config/udev: device USBPS2 already added. Ignoring.
[ 65.597] (WW) config/udev: device USBPS2 already added. Ignoring.
[ 65.699] (II) config/udev: Adding input device Logitech M570 (/dev/input/mouse2)
[ 65.699] (II) No input driver specified, ignoring this device.
[ 65.699] (II) This device may have been added with another device file.
[ 65.709] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event15)
[ 65.709] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 65.709] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[ 65.709] (**) USB Optical Mouse: always reports core events
[ 65.709] (**) evdev: USB Optical Mouse: Device: "/dev/input/event15"
[ 65.765] (--) evdev: USB Optical Mouse: Vendor 0x1bcf Product 0x5
[ 65.765] (--) evdev: USB Optical Mouse: Found 9 mouse buttons
[ 65.765] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[ 65.765] (--) evdev: USB Optical Mouse: Found relative axes
[ 65.765] (--) evdev: USB Optical Mouse: Found x and y relative axes
[ 65.765] (II) evdev: USB Optical Mouse: Configuring as mouse
[ 65.765] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[ 65.765] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 65.765] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 65.765] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3.2/2-1.3.2:1.0/0003:1BCF:0005.0003/input/input18/event15"
[ 65.765] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 12)
[ 65.765] (II) evdev: USB Optical Mouse: initialized for relative axes.
[ 65.765] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 65.765] (**) USB Optical Mouse: (accel) acceleration profile 0
[ 65.765] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 65.765] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 65.766] (II) config/udev: Adding input device Logitech M570 (/dev/input/event16)
[ 65.766] (**) Logitech M570: Applying InputClass "evdev pointer catchall"
[ 65.766] (II) Using input driver 'evdev' for 'Logitech M570'
[ 65.766] (**) Logitech M570: always reports core events
[ 65.766] (**) evdev: Logitech M570: Device: "/dev/input/event16"
[ 65.788] (--) evdev: Logitech M570: Vendor 0x46d Product 0x1028
[ 65.788] (--) evdev: Logitech M570: Found 20 mouse buttons
[ 65.788] (--) evdev: Logitech M570: Found scroll wheel(s)
[ 65.788] (--) evdev: Logitech M570: Found relative axes
[ 65.788] (--) evdev: Logitech M570: Found x and y relative axes
[ 65.788] (II) evdev: Logitech M570: Configuring as mouse
[ 65.788] (II) evdev: Logitech M570: Adding scrollwheel support
[ 65.788] (**) evdev: Logitech M570: YAxisMapping: buttons 4 and 5
[ 65.788] (**) evdev: Logitech M570: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 65.788] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3.3/2-1.3.3:1.2/0003:046D:C52B.0006/0003:046D:1028.0007/input/input19/event16"
[ 65.788] (II) XINPUT: Adding extended input device "Logitech M570" (type: MOUSE, id 13)
[ 65.788] (II) evdev: Logitech M570: initialized for relative axes.
[ 65.788] (**) Logitech M570: (accel) keeping acceleration scheme 1
[ 65.788] (**) Logitech M570: (accel) acceleration profile 0
[ 65.788] (**) Logitech M570: (accel) acceleration factor: 2.000
[ 65.788] (**) Logitech M570: (accel) acceleration threshold: 4
[ 65.789] (II) config/udev: Adding input device HD Pro Webcam C920 (/dev/input/event17)
[ 65.789] (**) HD Pro Webcam C920: Applying InputClass "evdev keyboard catchall"
[ 65.789] (II) Using input driver 'evdev' for 'HD Pro Webcam C920'
[ 65.789] (**) HD Pro Webcam C920: always reports core events
[ 65.789] (**) evdev: HD Pro Webcam C920: Device: "/dev/input/event17"
[ 65.789] (--) evdev: HD Pro Webcam C920: Vendor 0x46d Product 0x82d
[ 65.789] (--) evdev: HD Pro Webcam C920: Found keys
[ 65.789] (II) evdev: HD Pro Webcam C920: Configuring as keyboard
[ 65.789] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/input/input20/event17"
[ 65.789] (II) XINPUT: Adding extended input device "HD Pro Webcam C920" (type: KEYBOARD, id 14)
[ 65.789] (**) Option "xkb_rules" "evdev"
[ 65.789] (**) Option "xkb_model" "pc105"
[ 65.789] (**) Option "xkb_layout" "se"
[ 65.789] (WW) Option "xkb_variant" requires a string value
[ 65.789] (WW) Option "xkb_options" requires a string value
[ 529.462] (--) intel(0): HDMI max TMDS frequency 225000KHz
[ 544.814] (--) intel(0): HDMI max TMDS frequency 225000KHz
[ 1575.561] (II) config/udev: removing device USB Optical Mouse
[ 1575.576] (II) evdev: USB Optical Mouse: Close
[ 1575.576] (II) UnloadModule: "evdev"
[ 1581.759] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse1)
[ 1581.759] (II) No input driver specified, ignoring this device.
[ 1581.759] (II) This device may have been added with another device file.
[ 1581.822] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event15)
[ 1581.822] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 1581.822] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[ 1581.822] (**) USB Optical Mouse: always reports core events
[ 1581.822] (**) evdev: USB Optical Mouse: Device: "/dev/input/event15"
[ 1581.896] (--) evdev: USB Optical Mouse: Vendor 0x1bcf Product 0x5
[ 1581.896] (--) evdev: USB Optical Mouse: Found 9 mouse buttons
[ 1581.896] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[ 1581.896] (--) evdev: USB Optical Mouse: Found relative axes
[ 1581.896] (--) evdev: USB Optical Mouse: Found x and y relative axes
[ 1581.896] (II) evdev: USB Optical Mouse: Configuring as mouse
[ 1581.896] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[ 1581.896] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 1581.896] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 1581.896] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3.2/2-1.3.2:1.0/0003:1BCF:0005.0008/input/input21/event15"
[ 1581.896] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 12)
[ 1581.896] (II) evdev: USB Optical Mouse: initialized for relative axes.
[ 1581.897] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 1581.897] (**) USB Optical Mouse: (accel) acceleration profile 0
[ 1581.897] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 1581.897] (**) USB Optical Mouse: (accel) acceleration threshold: 4
