http://www.norman.com/Download/Full_versions/nvc/se
Har läst read me:n som följer med men lyckas inte installera detta. Någon som har några handfasta tips på hur man ska göra?
Read me innehåll:
Norman Virus Control v5 Command Line Scanner for Linux
Document revision 1.3.3
This document covers the following areas :
- What is NVC?
- System requirements
- Obtaining software and documentation
- Installation and removal
- RPM
- DEB
- TGZ
- Completing the installation (all packages)
- Components
- nvcoa (console)
- nvcc (console)
- niu (console)
- niucf (java)
- nvccf (java)
- Interfacing NVC with MTAs
- Recommended additions
What is NVC?
Norman Virus Control (NVC) is an anti-virus program that scans your
computer for malicious software, also referred to as malware.
Malware is viruses, worms, and other varieties of destructive code.
NVC can detect and remove known and unknown viruses from hard disks,
floppy disks, and e-mail attachments (see "Interfacing NVC with mail
programs").
Latest version of NVC for Linux is available at:
Manuals can be downloaded from :
http://www.norman.com/manuals.shtml
System requirements
NVC for Linux requires the following :
- i386 or compatible architecture
- a working Linux installation with:
- glibc 2.2 or better
- X server for configuration
- Java 1.4 for configuration
Installation, update and removal
NVC for Linux is available in three different package formats:
RPM for RedHat, Mandrake, SuSE and other RPM-based distributions.
DEB for Debian, Skolelinux, Lindows and other DPKG-based distributions.
TGZ for Slackware, gentoo and other source-based distributions.
NVC for Linux will install itself to the /opt/norman directory and make
symbolic links to all executable components in /usr/bin. You need
sufficient rights to install NVC for Linux, such as root.
The following components are sym-linked :
nvcoa - On-access scanner
nvcc - Command line scanner
niucf - Internet Update Configuration
nvccf - Main configuration tool
niu - Internet Update
Log files :
If run as root - /opt/norman/logs/
If run as a regular user - $HOME/.norman/logs
RPM :
Go to the directory which contains the RPM file and type the following:
rpm -i nvcc-x.xx-xx.rpm
To remove NVC for Linux type the following:
rpm -e nvcc
DEB :
Go to the directory which contains the DEB file and type the following:
dpkg -i nvcc-x.xx-xx.deb
dpkg -r nvcc
TGZ :
Move the .tgz file to /. and type the following
tar xvzfp ./nvcc-x.xx-x.tgz
Run the program 'install.sh' to set up symbolic links
/opt/norman/nvc/bin/install.sh
To remove NVC for Linux you should type the following:
/opt/norman/nvc/bin/uninstall.sh
Completing the installation (all packages) :
After installing NVC for Linux you must perform the following steps
to complete the installation :
- Run 'nvccf' and insert your authentication key under
the "Authentication" tab.
alternatively you can supply license information with the
--key argument to nvccf
- Run 'niucf' and select all applicable options. niucf is
optional for single user installations
- Run 'niu' to update the installation
** NOTE WELL **
niucf is only needed if you want NVC for Linux to maintain a
distributed NVC installation. Please see NVC's "Administrator's
Guide" for further information.
Components
nvcc (console)
nvcc is the actual command line scanner. Run with --help for more
information about the different arguments.
Example :
nvcc -s -u -cl /
The line above will check the entire filesystem and clean without prompting
for what action to take.
Example :
nvcc -s -u -cl /home/johndoe
The line above will check the directory /home/johndoe and all
subdirectories and clean without prompting for what action to take.
Also note that nvcc does not follow symlinks unless specified.
NIU (console)
NIU is responsible for the actual updating of NVC for Linux. NIU will
extract the information needed from the files 'niucf.ndf' and
'nvccf.ndf' made with 'niucf' and 'nvccf'.
Run with --help for more information about the different arguments.
niucf (java dependant)
niucf is used to configure updating of a network-distributed NVC,
including distribution to Windows platforms. Please see the
NVC's "Administrators Guide" for further information.
nvccf (java dependant)
nvccf is used primarily for entering data applicable to network
distributions and is similar to the "Configuration Editor" found
in NVC for other platforms. Please see NVC's "Reference Guide" or
"Administrator's Guide" for detailed information.
Interfacing NVC with mail servers
NVC for Linux is compatible with recent versions of the AMaViS wrapper,
and can therefore be interfaced with all major mail daemons (MTAs)
such as sendmail, postfix, qmail and exim.
AMaViS is available from <a class="postlink" href="http://www.amavis.org">http://www.amavis.org</a>
Recommended additions to NVC for Linux
An on-access scanner is also under development, and is scheduled for
release in Q1 2004.
NVC documentation and software are Copyright © 1990-2003 Norman ASA.
All rights reserved.
