Installera FreeOffice
Här behandlar vi program för ordbehandling, kalkyl, presentation och även e-post.
Pink Panther
Inlägg av Pink Panther »
Jag beklagar dina problem med Chrome BankID.
Men något stämmer inte.
Varför har du installerat " i386 architecture för att kunna köra "FreeOffice"?
"FreeOffice comes in five Linux installation options"
"Two Debian/Ubuntu-based .deb packages in 32-bit and 64-bit versions support multiarch and nonmultiarch systems"
Linux Mint 18 Sarah
beow
Re: Installera FreeOffice
Inlägg av beow »
Följde deras installationsanvisningar:
Thank you for choosing SoftMaker FreeOffice for Linux.
1. Download
There are five different installation options. Please choose the one that is suitable for your system:
.rpm archive for 32-bit systems (for example SUSE, Red Hat, and Fedora):
http://www.softmaker.net/down/softmaker ... 3.i386.rpm
.rpm archive for 64-bit systems (for example SUSE 64 bit, Red Hat 64 bit, and Fedora 64 bit):
http://www.softmaker.net/down/softmaker ... x86_64.rpm
.deb archive for 32-bit systems (for example Debian and Ubuntu) and 64-bit systems with multiarch (see note below):
http://www.softmaker.net/down/softmaker ... 1_i386.deb
.deb archive for old 64-bit systems without multiarch (for example Debian 64 bit before version 7 and Ubuntu 64 bit before version 13):
http://www.softmaker.net/down/softmaker ... _amd64.deb
.tgz archive with an installation script (works with all Linux distributions; also suitable when you do not have root access on the system):
http://www.softmaker.net/down/softmaker ... ce-703.tgz
A note for users of 64-bit systems with multiarch
The 64-bit versions of Debian starting with version 7 and Ubuntu starting with version 13 support "multiarch", the running of 32-bit applications. On these systems, you should always install the 32-bit DEB package of FreeOffice:
- Open a shell or terminal window.
- Enter this: dpkg --add-architecture i386
- Then enter this: apt-get update
- Now install the 32-bit DEB package of FreeOffice using your preferred package manager (most easily done by double-clicking on the DEB package).
Borde jag gjort annorlunda?
Pink Panther
Nej!
Jag testade själv att ta ner FreeOffice för ett par minuter sedan. Ursäkta men vilket dåligt alternativ till LibreOffice. Att företaget inte erbjuder komplett stöd för alla 64-bit är dåligt.
Vilseledande information "Two Debian/Ubuntu-based .deb packages in 32-bit and 64-bit versions support multiarch and nonmultiarch systems" Det uppskattas inte i min värld.
Är du intresserad av ett alternativ till LibreOffice. Så välj följande i stället WPS Office for Linux. Minst lika bra om inte bättre. Har testat WPS Office for Linux under en längre tid.
WPS Office for Linux har stöd för 64-bit.
http://wps-community.org/download.html
Linux Mint 18 Sarah
beow
Inlägg av beow »
Lite OT den här diskussionen, men letar efter något som är så kompatibelt med MS Office som möjligt. Men BankID känns viktare än FreeOffice så jag tar bort det nu och ser om det var det som ställde till det.
beow
Inlägg av beow »
Verkar inte bero på i386 arch. "dpkg -l | grep i386" visar att den redan fanns innan jag installerade FreeOffice, har en massa sådana paket installerade, så den går inte att ta bort.
Testar att installera om både Chrome och BankID appen.
beow
Inlägg av beow »
Tack för tipset, WPS Office är ju mycket trevligare än Free Office. Och som det verkar, ett klart alternativ till LO om man framförallt behöver kompatibilitet med MS Office.
Om du inte behöver öppna ODF-dokument från MS Office (eller LO m.fl.)…
Pink Panther
Till beow
För att få svensk rättstavning i WPS Office så kan du hämta hem "svenska_fria_ordlistan-1.16-sm+tb+fx.xpi" länk nedan pack upp filen med ( öppna med arkivhanterare ) där hittar du "dictionaries" sv.aff, sv.dic och sv_FI.aff, sv_FI.dic.
Det har funkat för mej när jag har testat WPS Office för Linux.
https://addons.mozilla.org/sv-SE/firefo ... ade-ordli/
Sedan får man en varning när man öppnar WPS Office första gången om följande. Om allt ska funka i programmet så kräver WPS Office en eller två Windows Typsnitt/fonts för själva WPS Office programmet.
De har tidigare haft länkar via "Kingsoft WPS Office Community" till Typsnitten/fonts men det är nu borttaget. Nu skriver WPS Office att typsnitten/fonts kan hittas vi Internet.
Även alla "dictionaries" är borttagna från "Kingsoft WPS Office Community". WPS Office skriver att de inte säkra på att de får använda ordlisterna med tanke upphovsrätten. Därför får du använda ovanstående metod.
"Kingsoft WPS Office Community" för Linux är numera kontrollerat och bevakat av WPS Office på sätt som inte har förekommit tidigare.
Linux Mint 18 Sarah
Pink Panther skrev:För att få svensk rättstavning i WPS Office så kan du hämta hem "svenska_fria_ordlistan-1.16-sm+tb+fx.xpi" länk nedan pack upp filen med ( öppna med arkivhanterare ) där hittar du "dictionaries" sv.aff, sv.dic och sv_FI.aff, sv_FI.dic.
De listorna finns i paketet hunspell-sv i Ubuntu-förrådet.
Pink Panther
Tack! Gunnar :-)
Linux Mint 18 Sarah
Återgå till "Kontor"
