Ladda ner från SVT
lasseroth
Ladda ner från SVT
Inlägg av lasseroth »
Tidigare har jag kunnat ladda ner från svt via terminal
nu ser det ut så här
i terminal
lasse@lasse-System-Product-Name:~$ svtplay-dl http://www.svtplay.se/video/6023901/sim ... -avsnitt-2
INFO: Outfile: simma-lugnt-larry-avsnitt-2-svt-play.mpd
[4731/4731][==================================================] INFO: no thumb requested
därefter skapas en fil under home med ändelsen .mpd
därefter händer inget.
filens innehåll
Gömt innehåll: Visa!
<MPD mediaPresentationDuration="PT1726.742S" minBufferTime="PT2.00S" profiles="urn:hbbtv:dash:profile:isoff-live:2012,urn:mpeg:dash:profile:isoff-live:2011" type="static" xmlns="urn:mpeg:dash:schema:mpd:2011" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:mpeg:DASH:schema:MPD:2011 DASH-MPD.xsd">
<BaseURL>./</BaseURL>
<Period>
<AdaptationSet contentType="audio" mimeType="audio/mp4" subsegmentAlignment="true" subsegmentStartsWithSAP="1">
<Accessibility schemeIdUri="urn:tva:metadata:cs:AudioPurposeCS:2007" value="6" />
<Role schemeIdUri="urn:mpeg:dash:role:2011" value="main" />
<SegmentTemplate initialization="$RepresentationID$/$RepresentationID$_00000.m4a" media="$RepresentationID$/$RepresentationID$_$Number%05d$.m4a" startNumber="1" timescale="48000">
<SegmentTimeline>
<S d="287744" t="0" />
<S d="288768" r="285" />
<S d="8192" />
</SegmentTimeline>
</SegmentTemplate>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_240_5">
<AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011" value="2" />
</Representation>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_2796_5">
</Representation>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_988_5">
</Representation>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_636_5">
</Representation>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_456_5">
</Representation>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_1680_5">
</Representation>
<Representation audioSamplingRate="48000" bandwidth="97386" codecs="mp4a.40.2" id="PG-1141052-002A-CURBYOURENTHUS-01_348_5">
</Representation>
</AdaptationSet>
<AdaptationSet contentType="video" mimeType="video/mp4" par="16:9" subsegmentAlignment="true" subsegmentStartsWithSAP="1">
<SegmentTemplate initialization="$RepresentationID$/$RepresentationID$_00000.m4v" media="$RepresentationID$/$RepresentationID$_$Number%05d$.m4v" startNumber="1" timescale="25000">
<SegmentTimeline>
<S d="150000" t="0" />
<S d="150000" r="285" />
<S d="118000" />
</SegmentTimeline>
</SegmentTemplate>
<Representation bandwidth="412638" codecs="avc1.42c015" frameRate="25" height="288" id="PG-1141052-002A-CURBYOURENTHUS-01_456_2" sar="1:1" scanType="progressive" width="512" />
<Representation bandwidth="3382232" codecs="avc1.64001f" frameRate="25" height="720" id="PG-1141052-002A-CURBYOURENTHUS-01_2796_2" sar="1:1" scanType="progressive" width="1280" />
<Representation bandwidth="632625" codecs="avc1.42c015" frameRate="25" height="288" id="PG-1141052-002A-CURBYOURENTHUS-01_636_2" sar="1:1" scanType="progressive" width="512" />
<Representation bandwidth="1140701" codecs="avc1.4d401f" frameRate="25" height="720" id="PG-1141052-002A-CURBYOURENTHUS-01_988_2" sar="1:1" scanType="progressive" width="1280" />
<Representation bandwidth="168782" codecs="avc1.42c015" frameRate="25" height="288" id="PG-1141052-002A-CURBYOURENTHUS-01_240_2" sar="1:1" scanType="progressive" width="512" />
<Representation bandwidth="2012092" codecs="avc1.4d401f" frameRate="25" height="720" id="PG-1141052-002A-CURBYOURENTHUS-01_1680_2" sar="1:1" scanType="progressive" width="1280" />
<Representation bandwidth="285841" codecs="avc1.42c015" frameRate="25" height="288" id="PG-1141052-002A-CURBYOURENTHUS-01_348_2" sar="1:1" scanType="progressive" width="512" />
</AdaptationSet>
</Period>
</MPD>
Re: Lada ner från SVT
Kunde hämta det programmet med svtplay-dl utan problem.
$ lsb_release -d
Description: Ubuntu 15.10
$ dpkg-query -W svtplay-dl
svtplay-dl 0.10.2015.05.24-1
Vilken Ubuntu-version har du?
lasseroth
14.04
Re: Ladda ner från SVT
Okej, då har du förmodligen en äldre version av svtplay-dl. Möjligen är det så att den versionen inte funkar med SVT längre.
Du skulle kunna pröva med att hämta och installera Xenial-versionen av svtplay-dl.
TicToc
Inlägg av TicToc »
Jag har samma problem med svtplay-dl 0.9.2014.04.27-1~ubuntu14.04.1.
lasseroth
lasse@lasse-System-Product-Name:~$ svtplay-dl http://www.svtplay.se/video/6090189/ens ... t-hitler-1
INFO: Selected to download hls, bitrate: 2793
INFO: Outfile: ensamma.mot.hitler-0551415-svtplay.ts
[069/313][=========....................................] ETA: 1:27:14
Ja, nu laddas det ner
Väldigt långsamt dock
Kan man ändra kvalitet på filen
jag vet från förr att den laddades ner i bästa kvalitet vilket är onödigt bra
Lägg till --list-quality för att se tillgängliga kvaliteter.
Ladda sedan ned önskad kvalitet med --quality=önskat dataflöde.
Se hela hjälpen med svtplay-dl -h.
lasseroth
Vill du ha den stora vänligheten att skriva textraden?
1. nerladdningslänk (skriv länk som finns)+ texten om info vilka strömmar som finns.
2. nerladdningstext efter info om strömmar-
på så vis kan jag ha texterna i ett dokument och bara byta http-länken
Det är ju så att missar man ett mellanslag t.ex. så funkar det inte
sedan ...ang "Se hela hjälpen med svtplay-dl -h."
är det här?
https://svtplay-dl.se/
Om svaret är ja= jag begriper noll komma noll av vad som står där.
Hoppas du vill göra dig besvär med detta, och att du förstått vad jag menar.
tillägg exempel
skall det vara
eller
--quality= önskat dataflöde
önskat dataflöde
exempel det står 633 hs
skriver jag bara 633?
För programmet i ditt första inlägg blir koden
svtplay-dl http://www.svtplay.se/video/6023901/simma-lugnt-larry/simma-lugnt-larry-sasong-8-avsnitt-2 --list-quality
som ger följande lista med kvaliteter:
INFO: Quality	Method
INFO: 2794	HLS
INFO: 2794	HDS
INFO: 1678	HLS
INFO: 1678	HDS
INFO: 986	HLS
INFO: 986	HDS
INFO: 634	HLS
INFO: 634	HDS
INFO: 454	HLS
INFO: 454	HDS
INFO: 346	HLS
INFO: 346	HDS
INFO: 238	HLS
INFO: 238	HDS
Så, om du t.ex. vill ladda ned programmet med 986 kbps, blir koden:
svtplay-dl http://www.svtplay.se/video/6023901/simma-lugnt-larry/simma-lugnt-larry-sasong-8-avsnitt-2 --quality=986
svtplay-dl -h är hela koden för att visa hela hjälpen för svtplay-dl.
svtplay-dl -h
Usage: svtplay-dl [options] url
Options:
  --version             show program's version number and exit
  -h, --help            show this help message and exit
  -o OUTPUT, --output=OUTPUT
                        outputs to the given filename
  -f, --force           overwrite if file exists already
  -r, --resume          resume a download (RTMP based ones)
  -l, --live            enable for live streams (RTMP based ones)
  -s, --silent          be less verbose
  -v, --verbose         explain what is going on
  -q quality, --quality=quality
                        choose what format to download based on bitrate /
                        video resolution.it will download the best format by
                        default
  -Q amount, --flexible-quality=amount
                        allow given quality (as above) to differ by an amount
  --list-quality        list the quality for a video
  -H, --hls             obsolete use -P hls
  -S, --subtitle        download subtitle from the site if available
  --force-subtitle      download only subtitle if its used with -S
  -u USERNAME, --username=USERNAME
                        username
  -p PASSWORD, --password=PASSWORD
                        password
  -t, --thumbnail       download thumbnail from the site if available
  -A, --all-episodes    try to download all episodes
  --all-last=NN         get last NN episodes instead of all episodes
  -P preferred, --preferred=preferred
                        preferred download method (rtmp, hls or hds)
  --exclude=WORD1,WORD2,...
                        exclude videos with the WORD(s) in the filename. comma
                        separated.
  -g, --get-url         do not download any video, but instead print the URL.
lasseroth
Stort tack JoWa
det var alltså meningen att -H =help skulle skrivas i terminal, fattade inte jag, så klart.
Jag sätter detta som löst och ber att få tacka så mycket
lasseroth
Fick ner en fil
den hade filändelsen ts
ändrade filändelse till flv
och den spelas
nämner bara detta om någon annan får samma "problem"
lasseroth
var nog för snabb med grönbocken
fick detta
lasse@lasse-System-Product-Name:~$ svtplay-dl http://www.svtplay.se/video/1680175/fam ... start=auto –list-quality
svtplay-dl: error: Incorrect number of arguments
Även när jag klistrar in din text får jag incorrect number of arguments
ingenvet
OS: Manjaro
Inlägg av ingenvet »
Ursäkta att jag hoppar in i denna, men hur får man ner svenk textning? Dessutom får jag ner filerna direkt som flv utan att behöva döpa om dom.
Avsluta med --list-quality inte –list-quality.
Du bör nog också ta bort ?start=auto i adressen.
Angående ändelsen .ts, är det en MPEG transportström (HLS) som laddas ned som standard. Man kan tvinga svtplay-dl att hämta en Flashfil (HDS) istället.
ingenvet skrev:Ursäkta att jag hoppar in i denna, men hur får man ner svenk textning?
Från hjälpen:
lasseroth
Svar till "ingenvet"
om inte Jowa uppmärksammar din fråga eftersom du (välkommen) hoppar in i en tråd som markerats löst.
Tog bort mitt inlägg såg att JoWa svarat
ingenvet
OS: Manjaro
Tack för era svar det är till stor hjälp.
Edit: tagit ner textfil men hittar den inte i min hemma mapp, vad får den för filändelse? Om det är .srt så stämmer det inte för jag har ställt in så att jag kan se dolda filerna i mappen.
lasseroth
Förstod av senare svar att det menades undertextfil, stryker därför mitt svar
eftersom det som bäst kan förvilla
Har begärt att Xenial-versionen av svtplay-dl backportas till trusty-förrådet.
https://launchpad.net/bugs/1539885
lasseroth
Tackar
