Checking for non power of two texture support : failed
Emil.s
Inlägg av Emil.s »
emil@Megaleif:~$ beryl-manager
emil@Megaleif:~$ Window manager warning: Lost connection to the display ':0.0';
most likely the X server was shut down or you killed/destroyed
the window manager.
* Beryl system compatibility check                           *
Detected xserver                                : AIGLX
Checking Display :0.0 ...
Checking for XComposite extension               : passed (v0.3)
Checking for XDamage extension                  : passed
Checking for RandR extension                    : passed
Checking for XSync extension                    : passed
Checking Screen 0 ...
Checking for GLX_SGIX_fbconfig                  : passed
Checking for GLX_EXT_texture_from_pixmap        : passed
Support for non power of two textures missing
beryl: glXBindTexImageEXT is missing
beryl: Failed to manage screen: 0
beryl: No manageable screens found on display :0.0
Inte roligt alls. :(
Inget bling!  :'( ;)
Någon som vart med om något liknande? Hur löser man det?
Kör beryl svn, revision 4128
Okänd
SV: Checking for non power of two texture support : failed
Inlägg av Okänd »
Byt till XGL...Aigxl har jag aldrig fått o funka... dito med många andra.. ;)
Emil.s
Inlägg av Emil.s »
Ok, ska testa med det. :P
