hårdisk kan ej mountas
lasseroth
Inlägg av lasseroth »
ubuntu 14.04
efter omstart får jag nu att sda 1 tb hårddisk ej can mountas.
säger operation already pending
formaterad ext4
operativsystemet ( endast Ubuntu) ligger på sdb
Gömt innehåll: Visa!
[ 1.252513] ata7: SATA link down (SStatus 0 SControl 300)
[ 1.252526] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.252572] ata9: SATA link down (SStatus 0 SControl 300)
[ 1.252595] ata8: SATA link down (SStatus 0 SControl 300)
[ 1.252598] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.253643] ata5.00: ATAPI: TSSTcorp DVDWBD SH-B123L, SB00, max UDMA/100
[ 1.255187] ata5.00: configured for UDMA/100
[ 1.255374] ata6.00: ATA-8: WDC WD10EALS-00Z8A0, 05.01D05, max UDMA/133
[ 1.255378] ata6.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.256218] scsi 4:0:0:0: CD-ROM TSSTcorp DVDWBD SH-B123L SB00 PQ: 0 ANSI: 5
[ 1.257711] ata6.00: configured for UDMA/133
[ 1.258726] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.258729] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.258886] sr 4:0:0:0: Attached scsi CD-ROM sr0
[ 1.258959] sr 4:0:0:0: Attached scsi generic sg0 type 5
[ 1.259130] scsi 5:0:0:0: Direct-Access ATA WDC WD10EALS-00Z 05.0 PQ: 0 ANSI: 5
[ 1.259239] sd 5:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 1.259247] sd 5:0:0:0: Attached scsi generic sg1 type 0
[ 1.259390] sd 5:0:0:0: [sda] Write Protect is off
[ 1.259392] sd 5:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.259420] sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.264692] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.264694] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.264832] hub 1-1:1.0: USB hub found
[ 1.264937] hub 1-1:1.0: 6 ports detected
[ 1.284105] sda: sda1
[ 1.284581] sd 5:0:0:0: [sda] Attached SCSI disk
[ 1.376305] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.424219] ata10: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.424690] ata10.00: ATA-9: SAMSUNG SSD 830 Series, CXM01B1Q, max UDMA/133
[ 1.424693] ata10.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.424949] ata10.00: configured for UDMA/133
[ 1.425182] scsi 9:0:0:0: Direct-Access ATA SAMSUNG SSD 830 CXM0 PQ: 0 ANSI: 5
[ 1.425299] sd 9:0:0:0: Attached scsi generic sg2 type 0
[ 1.425332] sd 9:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 1.425551] sd 9:0:0:0: [sdb] Write Protect is off
[ 1.425555] sd 9:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.425627] sd 9:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.426290] sdb: sdb1 sdb2 sdb3
[ 1.426625] sd 9:0:0:0: [sdb] Attached SCSI disk
[ 1.451574] EXT4-fs (sdb1): INFO: recovery required on readonly filesystem
[ 1.451576] EXT4-fs (sdb1): write access will be enabled during recovery
[ 1.480261] firewire_core 0000:08:02.0: created device fw0: GUID 001fc600001583af, S400
[ 1.508559] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.508564] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.508824] hub 2-1:1.0: USB hub found
[ 1.508918] hub 2-1:1.0: 8 ports detected
[ 1.779827] tsc: Refined TSC clocksource calibration: 3502.641 MHz
[ 1.780066] usb 2-1.2: new low-speed USB device number 3 using ehci-pci
[ 1.868168] EXT4-fs (sdb1): orphan cleanup on readonly fs
[ 1.885863] EXT4-fs (sdb1): 100 orphan inodes deleted
[ 1.885865] EXT4-fs (sdb1): recovery complete
[ 1.897685] usb 2-1.2: New USB device found, idVendor=046d, idProduct=c30e
[ 1.897688] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.897689] usb 2-1.2: Product: HID compliant keyboard
[ 1.897690] usb 2-1.2: Manufacturer: Logitech
[ 1.901288] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.928105] usbcore: registered new interface driver usbhid
[ 1.928106] usbhid: USB HID core driver
[ 1.929262] input: Logitech HID compliant keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input5
[ 1.929318] hid-generic 0003:046D:C30E.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech HID compliant keyboard] on usb-0000:00:1d.0-1.2/input0
[ 1.933536] input: Logitech HID compliant keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/input/input6
[ 1.933595] hid-generic 0003:046D:C30E.0002: input,hidraw1: USB HID v1.10 Device [Logitech HID compliant keyboard] on usb-0000:00:1d.0-1.2/input1
[ 1.967622] usb 2-1.3: new high-speed USB device number 4 using ehci-pci
[ 2.271677] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.341373] random: init urandom read with 85 bits of entropy available
[ 2.362064] init: plymouth-upstart-bridge main process (230) terminated with status 1
[ 2.362071] init: plymouth-upstart-bridge main process ended, respawning
[ 2.364979] init: plymouth-upstart-bridge main process (239) terminated with status 1
[ 2.364987] init: plymouth-upstart-bridge main process ended, respawning
[ 2.366559] init: plymouth-upstart-bridge main process (243) terminated with status 1
[ 2.366567] init: plymouth-upstart-bridge main process ended, respawning
[ 2.367825] init: plymouth-upstart-bridge main process (245) terminated with status 1
[ 2.367832] init: plymouth-upstart-bridge main process ended, respawning
[ 2.368924] init: plymouth-upstart-bridge main process (247) terminated with status 1
[ 2.368932] init: plymouth-upstart-bridge main process ended, respawning
[ 2.370022] init: plymouth-upstart-bridge main process (248) terminated with status 1
[ 2.370032] init: plymouth-upstart-bridge main process ended, respawning
[ 2.370934] init: plymouth-upstart-bridge main process (251) terminated with status 1
[ 2.370942] init: plymouth-upstart-bridge main process ended, respawning
[ 2.372030] init: plymouth-upstart-bridge main process (252) terminated with status 1
[ 2.372036] init: plymouth-upstart-bridge main process ended, respawning
[ 2.374068] init: plymouth-upstart-bridge main process (254) terminated with status 1
[ 2.374075] init: plymouth-upstart-bridge main process ended, respawning
[ 2.778855] Switched to clocksource tsc
[ 3.168316] usb 2-1.3: New USB device found, idVendor=046d, idProduct=082d
[ 3.168321] usb 2-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 3.168324] usb 2-1.3: Product: HD Pro Webcam C920
[ 3.168326] usb 2-1.3: SerialNumber: A41A02DF
[ 3.238187] usb 2-1.5: new high-speed USB device number 5 using ehci-pci
[ 3.331585] usb 2-1.5: New USB device found, idVendor=05e3, idProduct=0608
[ 3.331589] usb 2-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.331592] usb 2-1.5: Product: USB2.0 Hub
[ 3.331979] hub 2-1.5:1.0: USB hub found
[ 3.332317] hub 2-1.5:1.0: 4 ports detected
[ 3.406003] usb 2-1.7: new full-speed USB device number 6 using ehci-pci
[ 3.462685] random: nonblocking pool is initialized
[ 3.498247] usb 2-1.7: New USB device found, idVendor=0cf3, idProduct=3000
[ 3.498251] usb 2-1.7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.573445] Adding 2929660k swap on /dev/sdb2. Priority:-1 extents:1 across:2929660k SSFS
[ 3.583503] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.599671] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
[ 3.599784] systemd-udevd[366]: starting version 204
[ 3.605865] usb 2-1.5.1: new high-speed USB device number 7 using ehci-pci
[ 3.619013] wmi: Mapper loaded
[ 3.621543] AMD IOMMUv2 driver by Joerg Roedel <joerg.roedel@amd.com>
[ 3.621545] AMD IOMMUv2 functionality not available on this system
[ 3.622498] lp: driver loaded but no devices found
[ 3.623737] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[ 3.623741] Disabling lock debugging due to kernel taint
[ 3.626189] fglrx: module verification failed: signature and/or required key missing - tainting kernel
[ 3.629989] <6>[fglrx] Maximum main memory to use for locked dma buffers: 7729 MBytes.
[ 3.630088] <6>[fglrx] vendor: 1002 device: 6738 count: 1
[ 3.630304] <6>[fglrx] ioport: bar 4, base 0xe000, size: 0x100
[ 3.630474] <6>[fglrx] Kernel PAT support is enabled
[ 3.630485] <6>[fglrx] module loaded - fglrx 13.35.5 [Mar 12 2014] with 1 minors
[ 3.631634] nct6775: Found NCT6776D/F or compatible chip at 0x2e:0x290
[ 3.632424] mei_me 0000:00:16.0: irq 66 for MSI/MSI-X
[ 3.640612] ppdev: user-space parallel port driver
[ 3.655500] snd_hda_intel 0000:00:1b.0: irq 67 for MSI/MSI-X
[ 3.660642] type=1400 audit(1412272655.271:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=468 comm="apparmor_parser"
[ 3.660661] type=1400 audit(1412272655.271:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=468 comm="apparmor_parser"
[ 3.660666] type=1400 audit(1412272655.271:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=468 comm="apparmor_parser"
[ 3.661043] type=1400 audit(1412272655.271:5): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=468 comm="apparmor_parser"
[ 3.661048] type=1400 audit(1412272655.271:6): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=468 comm="apparmor_parser"
[ 3.661240] type=1400 audit(1412272655.271:7): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=468 comm="apparmor_parser"
[ 3.666667] Bluetooth: Core ver 2.17
[ 3.666679] NET: Registered protocol family 31
[ 3.666680] Bluetooth: HCI device and connection manager initialized
[ 3.666686] Bluetooth: HCI socket layer initialized
[ 3.666688] Bluetooth: L2CAP socket layer initialized
[ 3.666691] Bluetooth: SCO socket layer initialized
[ 3.667358] SKU: Nid=0x1d sku_cfg=0x4005e601
[ 3.667360] SKU: port_connectivity=0x1
[ 3.667361] SKU: enable_pcbeep=0x0
[ 3.667362] SKU: check_sum=0x00000005
[ 3.667363] SKU: customization=0x000000e6
[ 3.667364] SKU: external_amp=0x0
[ 3.667365] SKU: platform_type=0x0
[ 3.667366] SKU: swap=0x0
[ 3.667367] SKU: override=0x1
[ 3.667806] autoconfig: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 3.667808] speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.667809] hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 3.667810] mono: mono_out=0x0
[ 3.667811] dig-out=0x11/0x1e
[ 3.667813] inputs:
[ 3.667814] Front Mic=0x19
[ 3.667816] Rear Mic=0x18
[ 3.667817] Line=0x1a
[ 3.667818] realtek: No valid SSID, checking pincfg 0x4005e601 for NID 0x1d
[ 3.667820] realtek: Enabling init ASM_ID=0xe601 CODEC_ID=10ec0892
[ 3.679525] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 3.679593] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 3.679691] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 3.679747] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 3.679804] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 3.679861] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 3.679916] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 3.679988] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 3.680277] ACPI Warning: 0x0000000000000540-0x000000000000054f SystemIO conflicts with Region \_SB_.PCI0.SBRG.GPBX 1 (20131115/utaddress-251)
[ 3.680281] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.680282] ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \_SB_.PCI0.SBRG.GPBX 1 (20131115/utaddress-251)
[ 3.680284] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.680285] ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \_SB_.PCI0.SBRG.GPBX 1 (20131115/utaddress-251)
[ 3.680287] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.680287] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 3.680415] hda-intel 0000:01:00.1: Handle VGA-switcheroo audio client
[ 3.680416] hda-intel 0000:01:00.1: Using LPIB position fix
[ 3.680442] snd_hda_intel 0000:01:00.1: irq 68 for MSI/MSI-X
[ 3.685819] hda-intel 0000:01:00.1: Enable sync_write for stable communication
[ 3.691417] Linux video capture interface: v2.00
[ 3.696756] kvm: disabled by bios
[ 3.699248] usb 2-1.5.1: New USB device found, idVendor=03f0, idProduct=2b17
[ 3.699250] usb 2-1.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.699252] usb 2-1.5.1: Product: HP LaserJet 1020
[ 3.699253] usb 2-1.5.1: Manufacturer: Hewlett-Packard
[ 3.699254] usb 2-1.5.1: SerialNumber: FN00BD2
[ 3.703019] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 3.736088] asus_wmi: ASUS WMI generic driver loaded
[ 3.737310] asus_wmi: Initialization: 0x0
[ 3.737335] asus_wmi: BIOS WMI version: 0.9
[ 3.737373] asus_wmi: SFUN value: 0x0
[ 3.737847] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input16
[ 3.738586] asus_wmi: Disabling ACPI video driver
[ 3.769796] usb 2-1.5.2: new full-speed USB device number 8 using ehci-pci
[ 3.864830] usb 2-1.5.2: New USB device found, idVendor=046d, idProduct=c52b
[ 3.864836] usb 2-1.5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.864838] usb 2-1.5.2: Product: USB Receiver
[ 3.864841] usb 2-1.5.2: Manufacturer: Logitech
[ 3.880183] uvcvideo: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[ 3.880189] usbcore: registered new interface driver snd-usb-audio
[ 3.880852] input: HD Pro Webcam C920 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/input/input17
[ 3.880917] usbcore: registered new interface driver uvcvideo
[ 3.880918] USB Video Class driver (1.1.1)
[ 3.924656] usbcore: registered new interface driver ath3k
[ 3.949479] usb 2-1.5.3: new low-speed USB device number 9 using ehci-pci
[ 4.056190] usb 2-1.5.3: New USB device found, idVendor=0957, idProduct=0600
[ 4.056193] usb 2-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.056194] usb 2-1.5.3: Product: Ullman PenClic Mouse (tm)
[ 4.056195] usb 2-1.5.3: Manufacturer: Ullman Technology
[ 4.059469] EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null)
[ 4.067568] input: Ullman Technology Ullman PenClic Mouse (tm) as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.0/input/input18
[ 4.067646] hid-generic 0003:0957:0600.0006: input,hidraw2: USB HID v1.10 Mouse [Ullman Technology Ullman PenClic Mouse (tm) ] on usb-0000:00:1d.0-1.5.3/input0
[ 4.079617] WARNING! power/level is deprecated; use power/control instead
[ 4.079847] logitech-djreceiver 0003:046D:C52B.0005: hiddev0,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.0-1.5.2/input2
[ 4.082010] input: Logitech Unifying Device. Wireless PID:101d as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.2/2-1.5.2:1.2/0003:046D:C52B.0005/input/input19
[ 4.082097] logitech-djdevice 0003:046D:C52B.0007: input,hidraw4: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:101d] on usb-0000:00:1d.0-1.5.2:1
[ 4.150828] usb 2-1.7: USB disconnect, device number 6
[ 4.158445] init: failsafe main process (671) killed by TERM signal
[ 4.193088] Bluetooth: RFCOMM TTY layer initialized
[ 4.193097] Bluetooth: RFCOMM socket layer initialized
[ 4.193102] Bluetooth: RFCOMM ver 1.11
[ 4.193300] type=1400 audit(1412272655.807:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=741 comm="apparmor_parser"
[ 4.193306] type=1400 audit(1412272655.807:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=741 comm="apparmor_parser"
[ 4.193698] type=1400 audit(1412272655.807:10): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=741 comm="apparmor_parser"
[ 4.194979] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.194983] Bluetooth: BNEP filters: protocol multicast
[ 4.194992] Bluetooth: BNEP socket layer initialized
[ 4.229508] init: cups main process (753) killed by HUP signal
[ 4.229516] init: cups main process ended, respawning
[ 4.246885] init: samba-ad-dc main process (786) terminated with status 1
[ 4.416654] e1000e 0000:00:19.0: irq 64 for MSI/MSI-X
[ 4.520544] e1000e 0000:00:19.0: irq 64 for MSI/MSI-X
[ 4.520642] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.520892] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.598107] init: plymouth-upstart-bridge main process ended, respawning
[ 5.115939] usb 2-1.7: new full-speed USB device number 10 using ehci-pci
[ 5.208575] usb 2-1.7: New USB device found, idVendor=0cf3, idProduct=3005
[ 5.208578] usb 2-1.7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.211500] usbcore: registered new interface driver btusb
[ 6.052469] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 6.052474] e1000e 0000:00:19.0 eth0: 10/100 speed: disabling TSO
[ 6.052504] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.072300] usblp 2-1.5.1:1.0: usblp1: USB Bidirectional printer dev 7 if 0 alt 0 proto 2 vid 0x03F0 pid 0x2B17
[ 15.072315] usbcore: registered new interface driver usblp
[ 21.075959] init: udev-fallback-graphics main process (1261) terminated with status 1
[ 21.099047] init: plymouth-splash main process (1279) terminated with status 1
[ 21.422167] fglrx_pci 0000:01:00.0: irq 69 for MSI/MSI-X
[ 21.422725] <6>[fglrx] Firegl kernel thread PID: 1337
[ 21.422821] <6>[fglrx] Firegl kernel thread PID: 1338
[ 21.422915] <6>[fglrx] Firegl kernel thread PID: 1339
[ 21.422997] <6>[fglrx] IRQ 69 Enabled
[ 21.508133] <6>[fglrx] Reserved FB block: Shared offset:0, size:1000000
[ 21.508135] <6>[fglrx] Reserved FB block: Unshared offset:fb78000, size:4000
[ 21.508136] <6>[fglrx] Reserved FB block: Unshared offset:fb7c000, size:484000
[ 21.508137] <6>[fglrx] Reserved FB block: Unshared offset:3fff4000, size:c000
[ 34.209716] audit_printk_skb: 153 callbacks suppressed
[ 34.209719] type=1400 audit(1412272685.859:62): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=2127 comm="apparmor_parser"
[ 34.209723] type=1400 audit(1412272685.859:63): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=2127 comm="apparmor_parser"
[ 34.210007] type=1400 audit(1412272685.859:64): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=2127 comm="apparmor_parser"
[ 38.516152] e1000e: eth0 NIC Link is Down
[ 43.255670] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 69.284854] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 69.284861] e1000e 0000:00:19.0 eth0: 10/100 speed: disabling TSO
[ 69.284896] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 873.001239] ata6.00: exception Emask 0x0 SAct 0x7fffe1ff SErr 0x0 action 0x0
[ 873.001241] ata6.00: irq_stat 0x40000008
[ 873.001243] ata6.00: failed command: READ FPDMA QUEUED
[ 873.001245] ata6.00: cmd 60/08:68:90:38:05/00:00:3a:00:00/40 tag 13 ncq 4096 in
[ 873.001245] res 41/40:00:90:38:05/00:00:3a:00:00/40 Emask 0x409 (media error) <F>
[ 873.001246] ata6.00: status: { DRDY ERR }
[ 873.001247] ata6.00: error: { UNC }
[ 873.006488] ata6.00: configured for UDMA/133
[ 873.006510] sd 5:0:0:0: [sda] Unhandled sense code
[ 873.006513] sd 5:0:0:0: [sda]
[ 873.006515] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 873.006517] sd 5:0:0:0: [sda]
[ 873.006519] Sense Key : Medium Error [current] [descriptor]
[ 873.006522] Descriptor sense data with sense descriptors (in hex):
[ 873.006524] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 873.006533] 3a 05 38 90
[ 873.006537] sd 5:0:0:0: [sda]
[ 873.006539] Add. Sense: Unrecovered read error - auto reallocate failed
[ 873.006542] sd 5:0:0:0: [sda] CDB:
[ 873.006543] Read(10): 28 00 3a 05 38 90 00 00 08 00
[ 873.006551] end_request: I/O error, dev sda, sector 973420688
[ 873.006566] ata6: EH complete
[ 873.006630] JBD2: Failed to read block at offset 9746
[ 874.147284] JBD2: recovery failed
[ 874.147292] EXT4-fs (sda1): error loading journal
[ 902.598698] ata6.00: exception Emask 0x0 SAct 0x70007fff SErr 0x0 action 0x0
[ 902.598703] ata6.00: irq_stat 0x40000008
[ 902.598707] ata6.00: failed command: READ FPDMA QUEUED
[ 902.598713] ata6.00: cmd 60/08:e0:90:38:05/00:00:3a:00:00/40 tag 28 ncq 4096 in
[ 902.598713] res 41/40:00:90:38:05/00:00:3a:00:00/40 Emask 0x409 (media error) <F>
[ 902.598716] ata6.00: status: { DRDY ERR }
[ 902.598718] ata6.00: error: { UNC }
[ 902.603911] ata6.00: configured for UDMA/133
[ 902.603922] sd 5:0:0:0: [sda] Unhandled sense code
[ 902.603923] sd 5:0:0:0: [sda]
[ 902.603924] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 902.603925] sd 5:0:0:0: [sda]
[ 902.603926] Sense Key : Medium Error [current] [descriptor]
[ 902.603927] Descriptor sense data with sense descriptors (in hex):
[ 902.603928] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 902.603931] 3a 05 38 90
[ 902.603933] sd 5:0:0:0: [sda]
[ 902.603934] Add. Sense: Unrecovered read error - auto reallocate failed
[ 902.603935] sd 5:0:0:0: [sda] CDB:
[ 902.603936] Read(10): 28 00 3a 05 38 90 00 00 08 00
[ 902.603939] end_request: I/O error, dev sda, sector 973420688
[ 902.603946] ata6: EH complete
[ 902.603972] JBD2: Failed to read block at offset 9746
[ 904.612813] ata6.00: exception Emask 0x0 SAct 0x7d0003ff SErr 0x0 action 0x0
[ 904.612823] ata6.00: irq_stat 0x40000008
[ 904.612827] ata6.00: failed command: READ FPDMA QUEUED
[ 904.612833] ata6.00: cmd 60/08:c0:a0:38:05/00:00:3a:00:00/40 tag 24 ncq 4096 in
[ 904.612833] res 41/40:00:a1:38:05/00:00:3a:00:00/40 Emask 0x409 (media error) <F>
[ 904.612836] ata6.00: status: { DRDY ERR }
[ 904.612838] ata6.00: error: { UNC }
[ 904.617599] ata6.00: configured for UDMA/133
[ 904.617625] sd 5:0:0:0: [sda] Unhandled sense code
[ 904.617628] sd 5:0:0:0: [sda]
[ 904.617630] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 904.617632] sd 5:0:0:0: [sda]
[ 904.617634] Sense Key : Medium Error [current] [descriptor]
[ 904.617637] Descriptor sense data with sense descriptors (in hex):
[ 904.617639] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 904.617648] 3a 05 38 a1
[ 904.617652] sd 5:0:0:0: [sda]
[ 904.617654] Add. Sense: Unrecovered read error - auto reallocate failed
[ 904.617657] sd 5:0:0:0: [sda] CDB:
[ 904.617658] Read(10): 28 00 3a 05 38 a0 00 00 08 00
[ 904.617666] end_request: I/O error, dev sda, sector 973420705
[ 904.617679] ata6: EH complete
[ 905.761042] JBD2: recovery failed
[ 905.761050] EXT4-fs (sda1): error loading journal
[ 1018.707427] ata6.00: exception Emask 0x0 SAct 0x70ff80 SErr 0x0 action 0x0
[ 1018.707430] ata6.00: irq_stat 0x40000008
Re: hårdisk kan ej mountas
Ursäkta min nyfikenhet; men hur många hårddiskar har du egentligen i maskinen?
Felen från loggen antyder antingen (a) diskarna är hela, kablarna är lösa och behöver "tryckas till" (b) någon av diskarna visar tecken på ålder, i sa fall byt (c) något annat...
Ja, det var ett luddigt svar men det kan faktisk vara många olika saker som är orsaken. Mitt råd: börja med (a)
lasseroth
sdb = ssd disc
sda 1 terrabite vanlig
skall kolla, när ryggskotten släppt, om sladd lös
