Hur svårt kan det vara?
När jag kopplar in min vanliga stillbildskamera (canon) så hittas den direkt.
GoPRO-inget
Tips på vad göra?
lasse@lasse:~$ dmesg | tail
[434259.099229] usb 1-1.6: device descriptor read/64, error -32
[434259.274986] usb 1-1.6: new full-speed USB device number 10 using ehci_hcd
[434259.682400] usb 1-1.6: device not accepting address 10, error -32
[434259.754407] usb 1-1.6: new full-speed USB device number 11 using ehci_hcd
[434260.161831] usb 1-1.6: device not accepting address 11, error -32
[434260.161924] hub 1-1:1.0: unable to enumerate USB device on port 6
[434758.017447] usb 2-1.5.3: USB disconnect, device number 12
[434758.371648] usb 2-1.5.3: new low-speed USB device number 13 using ehci_hcd
[434758.489781] input: Ullman Technology Ullman PenClic Mouse (tm) as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.0/input/input19
[434758.489945] generic-usb 0003
lasse@lasse:~$ sudo fdisk -lu
[sudo] password for lasse:
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0fb8c46f
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 1953521663 976759808 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 128.0 GB, 128035676160 bytes
255 heads, 63 sectors/track, 15566 cylinders, total 250069680 sectors
Disk identifier: 0x0000fff3
/dev/sdb1 * 2048 233340927 116669440 83 Linux
/dev/sdb2 233342974 250068991 8363009 5 Extended
/dev/sdb5 233342976 250068991 8363008 82 Linux swap / Solaris
lasse@lasse:~$
