grafik fungerar inte efter uppdatering
Ainigma
Inlägg av Ainigma »
Efter en vanlig uppdatering med omstart så får jag felmeddelande angående grafiken. ??? Kommer inte in i datorn utan det blir failsafe mode. Efter flera omstarter kommer jag dock in i datorn.
När jag kollar i /var/log/Xorg.1.log så finns det error meddelanden.
Ger en kopia av /var/log/Xorg.1.log:
[ 22.546]
X.Org X Server 1.11.3
Release Date: 2011-12-16
[ 22.546] X Protocol Version 11, Revision 0
[ 22.546] Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
[ 22.546] Current Operating System: Linux Megatron 3.2.0-48-generic #74-Ubuntu SMP Thu Jun 6 19:43:26 UTC 2013 x86_64
[ 22.546] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-48-generic root=UUID=971122d1-0e95-4762-945d-efb697d3adee ro quiet splash vt.handoff=7
[ 22.546] Build Date: 11 April 2013 01:05:39PM
[ 22.546] xorg-server 2:1.11.4-0ubuntu10.13 (For technical support please see http://www.ubuntu.com/support)
[ 22.546] Current version of pixman: 0.24.4
[ 22.546] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 22.546] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 22.546] (==) Log file: "/var/log/Xorg.1.log", Time: Wed Jun 19 06:22:58 2013
[ 22.546] (==) Using config file: "/etc/X11/xorg.conf.failsafe"
[ 22.546] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 22.546] (==) No Layout section. Using the first Screen section.
[ 22.546] (**) |-->Screen "Default Screen" (0)
[ 22.546] (**) | |-->Monitor "Configured Monitor"
[ 22.547] (**) | |-->Device "Configured Video Device"
[ 22.547] (==) Automatically adding devices
[ 22.547] (==) Automatically enabling devices
[ 22.547] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 22.547] Entry deleted from font path.
[ 22.547] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 22.547] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 22.547] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 22.547] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 22.547] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 22.547] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 22.547] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 22.547] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 22.547] (II) Loader magic: 0x7fd05fbc9b00
[ 22.547] (II) Module ABI versions:
[ 22.547] X.Org ANSI C Emulation: 0.4
[ 22.547] X.Org Video Driver: 11.0
[ 22.547] X.Org XInput driver : 16.0
[ 22.547] X.Org Server Extension : 6.0
[ 22.548] (--) PCI:*(0:0:16:0) 10de:07e1:1458:d000 rev 162, Mem @ 0xe2000000/16777216, 0xd0000000/268435456, 0xe3000000/16777216, BIOS @ 0x????????/131072
[ 22.548] (II) Open ACPI successful (/var/run/acpid.socket)
[ 22.548] (II) LoadModule: "extmod"
[ 22.548] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 22.548] (II) Module extmod: vendor="X.Org Foundation"
[ 22.548] compiled for 1.11.3, module version = 1.0.0
[ 22.548] Module class: X.Org Server Extension
[ 22.548] ABI class: X.Org Server Extension, version 6.0
[ 22.548] (II) Loading extension MIT-SCREEN-SAVER
[ 22.548] (II) Loading extension XFree86-VidModeExtension
[ 22.548] (II) Loading extension XFree86-DGA
[ 22.548] (II) Loading extension DPMS
[ 22.548] (II) Loading extension XVideo
[ 22.548] (II) Loading extension XVideo-MotionCompensation
[ 22.548] (II) Loading extension X-Resource
[ 22.548] (II) LoadModule: "dbe"
[ 22.549] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 22.549] (II) Module dbe: vendor="X.Org Foundation"
[ 22.549] compiled for 1.11.3, module version = 1.0.0
[ 22.549] Module class: X.Org Server Extension
[ 22.549] ABI class: X.Org Server Extension, version 6.0
[ 22.549] (II) Loading extension DOUBLE-BUFFER
[ 22.549] (II) LoadModule: "glx"
[ 22.549] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 22.557] (II) Module glx: vendor="NVIDIA Corporation"
[ 22.557] compiled for 4.0.2, module version = 1.0.0
[ 22.557] Module class: X.Org Server Extension
[ 22.557] (II) NVIDIA GLX Module 173.14.35 Fri Jun 8 00:57:06 PDT 2012
[ 22.557] (II) Loading extension GLX
[ 22.557] (II) LoadModule: "record"
[ 22.557] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 22.557] (II) Module record: vendor="X.Org Foundation"
[ 22.557] compiled for 1.11.3, module version = 1.13.0
[ 22.557] ABI class: X.Org Server Extension, version 6.0
[ 22.557] (II) Loading extension RECORD
[ 22.557] (II) LoadModule: "dri"
[ 22.557] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 22.558] (II) Module dri: vendor="X.Org Foundation"
[ 22.558] compiled for 1.11.3, module version = 1.0.0
[ 22.558] ABI class: X.Org Server Extension, version 6.0
[ 22.558] (II) Loading extension XFree86-DRI
[ 22.558] (II) LoadModule: "dri2"
[ 22.558] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 22.558] (II) Module dri2: vendor="X.Org Foundation"
[ 22.558] compiled for 1.11.3, module version = 1.2.0
[ 22.558] (II) Loading extension DRI2
[ 22.558] (II) LoadModule: "vesa"
[ 22.558] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 22.558] (II) Module vesa: vendor="X.Org Foundation"
[ 22.558] compiled for 1.11.3, module version = 2.3.0
[ 22.558] Module class: X.Org Video Driver
[ 22.558] ABI class: X.Org Video Driver, version 11.0
[ 22.558] (II) VESA: driver for VESA chipsets: vesa
[ 22.558] (--) using VT number 7
[ 22.890] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 22.890] vesa: Ignoring device with a bound kernel driver
[ 22.890] (WW) Falling back to old probe method for vesa
[ 22.890] (II) UnloadModule: "vesa"
[ 22.890] (II) Unloading vesa
[ 22.890] (EE) Screen(s) found, but none have a usable configuration.
[ 22.890]
Fatal server error:
[ 22.890] no screens found
[ 22.890]
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 22.890] Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[ 22.890]
[ 22.891] ddxSigGiveUp: Closing log
[ 22.891] Server terminated with error (1). Closing log file.
Finns det någon som kan hjälpa? ???
Återgå till "Terminalforum"
