Jag har skrivit ett Pythonskript för att göra ungefär samma sak, men som istället skickar e-post till mig när IP-adressen ändrats.
#!/usr/bin/env python3
IP Monitor
version 1
Sends an e-mail if the network's external IP address has changed since last run.
def get_ip():
import urllib.request
import re
with urllib.request.urlopen('http://dns.loopia.se/checkip/checkip.php') as f:
html = f.read().decode('utf-8')
ip = re.findall('[0-9]+.[0-9]+.[0-9]+.[0-9]+', html)[0]
return ip
def compare(ip):
from os.path import expanduser
home = expanduser("~")
try:
file = open(home + '/.ipmonitor', 'r')
return file.read() == ip
except IOError as e:
return False
def update(ip):
try:
file = open(home + '/.ipmonitor', 'w')
file.write(ip)
return True
return False
def compose(ip, wrote, poster, recipient):
from email.mime.text import MIMEText
from email.utils import formatdate
msg = MIMEText('')
if wrote:
msg.set_payload('New IP address: %s.' % ip)
else:
msg.set_payload('New IP address: %s.\n\nUnable to create config file!' % ip)
msg['Subject'] = 'IP address change: %s' % ip
msg['From'] = poster
msg['To'] = recipient
# RFC 2822: "Use local time". Anton: "Use UTC".
msg['Date'] = formatdate(localtime = False)
return msg
def send(msg, server, port):
from netrc import netrc
from smtplib import SMTP
username, _, password = netrc().authenticators(server)
smtp = SMTP(server, port)
smtp.starttls()
smtp.login(username, password)
# smtp.send_message(msg) # Python 3.2
smtp.sendmail(msg['From'], msg['To'], str(msg)) # Python 3.1
smtp.quit()
def main():
ip = get_ip()
if compare(ip):
pass
# print('No change')
else:
print('New IP: %s' % ip)
wrote = update(ip)
if wrote:
print('Wrote config')
else:
print('Failed to write config')
msg = compose(ip, wrote, 'frånadress@example.com', 'tilladress@example.com')
send(msg, 'smtp.example.com', 587)
print('Sent e-mail')
if __name__ == '__main__':
main()
Ändra frå
nadress@example.com,
tilladress@example.com och smtp.example.com till lämpliga värden. Inloggningsuppgifter läses från ens .netrc-fil på ungefär det här formatet:
machine smtp.example.com
login frånadress@example.com
password lösenord
Jag låter cron köra skriptet på en server var sjätte timme med den här raden i min crontab:
