Har monterat den i en docking station.
Får detta meddelande:
Kunde inte montera 305 GB-filsystem
Error mounting: mount: wrong fs type, bad option, bad superblock on /dev/sdc3,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
abyssws@servern:~$ dmesg | tail
[218041.305644] EXT4-fs (sdc1): mounted filesystem with ordered data mode
[218043.796538] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218051.566937] EXT4-fs (sdc3): bad geometry: block count 74341376 exceeds size of device (74341197 blocks)
[218055.800584] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218074.802690] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218085.801387] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218105.802134] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218126.811348] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218136.797865] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
[218154.808501] Outbound IN= OUT=eth0 SRC=192.168.1.2 DST=192.168.1.1 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=308
