Tji flyttbar enhet eller mp 3
- mcNisse
- OS: Debian
Re: Tji flyttbar enhet eller mp 3
Till att börga med så måste felet undersökas.
Ta ut enheten ur daton
starta en terminal,
skriv in följande kommando
tryck enter några gånger och stoppa i enheten.
för mig när jag trycker in en jos mp-110 kommer detta i terminalen
Det fungerade bra den fick ett device /dev/sdb och filsystemet blidde /dev/sdb1....
starta en terminal,
tail -f /var/log/syslog
Oct 29 14:52:07 lemmy kernel: [70570.792102] usb 6-1: new full speed USB device number 4 using uhci_hcd
Oct 29 14:52:08 lemmy mtp-probe: checking bus 6, device 4: "/sys/devices/pci0000:00/0000:00:1d.1/usb6/6-1"
Oct 29 14:52:08 lemmy kernel: [70570.961729] scsi6 : usb-storage 6-1:1.0
Oct 29 14:52:08 lemmy mtp-probe: bus: 6, device: 4 was not an MTP device
Oct 29 14:52:09 lemmy kernel: [70571.964452] scsi 6:0:0:0: Direct-Access IBEAD Multi Player 0100 PQ: 0 ANSI: 4
Oct 29 14:52:09 lemmy kernel: [70572.016557] sd 6:0:0:0: Attached scsi generic sg2 type 0
Oct 29 14:52:09 lemmy kernel: [70572.024322] sd 6:0:0:0: [sdb] 1009152 512-byte logical blocks: (516 MB/492 MiB)
Oct 29 14:52:09 lemmy kernel: [70572.029459] sd 6:0:0:0: [sdb] Write Protect is off
Oct 29 14:52:09 lemmy kernel: [70572.029470] sd 6:0:0:0: [sdb] Mode Sense: 03 00 00 00
Oct 29 14:52:09 lemmy kernel: [70572.032543] sd 6:0:0:0: [sdb] No Caching mode page present
Oct 29 14:52:09 lemmy kernel: [70572.032555] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Oct 29 14:52:09 lemmy kernel: [70572.049540] sd 6:0:0:0: [sdb] No Caching mode page present
Oct 29 14:52:09 lemmy kernel: [70572.049558] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Oct 29 14:52:09 lemmy kernel: [70572.056637] sdb: sdb1
Oct 29 14:52:09 lemmy kernel: [70572.069443] sd 6:0:0:0: [sdb] No Caching mode page present
Oct 29 14:52:09 lemmy kernel: [70572.069449] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Oct 29 14:52:09 lemmy kernel: [70572.069454] sd 6:0:0:0: [sdb] Attached SCSI removable disk
Jag följde ditt råd och fick upp följande ;unable to enumerate USB device on port 1; jag provade även den andra porten och det stod samma sak där
- mcNisse
- OS: Debian
Det är tydligen inte ett helt ovanligt fel
Testa det här
http://www.absolutelytech.com/2010/04/1 ... -ehci_hcd/
Testa det här
