Men låt säga att jag skaffar en gratis/betal vpn, vad säger att det inte sitter stygga människor som lätt rensar min dator på känslig information medans jag sitter i lugn och ro och tror jag surfar säkert....
eller har jag confat min vpn felkatigt?
ochVNC is a protocol that allows a desktop to be viewed and controlled remotely over the Internet. To use VNC, a VNC server must be run on the computer sharing the desktop, and a VNC client must be run on the computer that will access the shared desktop.
https://help.ubuntu.com/community/VNCAlthough VNC has some optional security features, you should not run VNC directly over an untrusted network like the Internet. Instead, you should set an SSH server up as discussed in the SSH guide and configure a VNC server that you can start in so-called once mode. When you have set up your SSH and VNC servers, you can use SSH to log in to your computer over the Internet, start your VNC server, and use port-forwarding to securely access the VNC server.
