Undrar hur man får klockan att ställa in sig riktigt om man inte har ett batteri som funkar till bios?
Får lov att ändra manuellt varje gång jag startat om.
Har sökt men inte hittat nått. Kan vara jag som är blind
Sökte efter ntpd och hittade denna: https://wiki.archlinux.org/index.php/Ne ... col_daemoncowboy skrev:Är det nåt typ NTPD du söker? Se
http://www.cyberciti.biz/faq/debian-ubu ... tall-ntpd/
(Debian/Ubuntu-specifik info iofs, men det borde ju vara någorlunda likt...)
# NOTES:
# - you should only have to update the server line below
# - if you start getting lines like 'restrict' and 'fudge'
# and you didnt add them, AND you run dhcpcd on your
# network interfaces, be sure to add '-Y -N' to the
# dhcpcd_ethX variables in /etc/conf.d/net
# Name of the servers ntpd should sync with
# Please respect the access policy as stated by the responsible person.
#server ntp.example.tld iburst
server 0.pool.ntp.org iburst
server 1.pool.ntp.org iburst
server 2.pool.ntp.org iburst
server 3.pool.ntp.org iburst
server 127.127.1.0
fudge 127.127.1.0 stratum 10
restrict default kod nomodify notrap nopeer noquery
restrict -6 default kod nomodify notrap nopeer noquery
# A list of available servers can be found here:
# http://www.pool.ntp.org/
# http://www.pool.ntp.org/#use
# A good way to get servers for your machine is:
# netselect -s 3 pool.ntp.org
#server ntplocal.example.com prefer
#server timeserver.example.org
# Warning: Using default NTP settings will leave your NTP
# server accessible to all hosts on the Internet.
# A default deny all (including localhost) policy
# To use this define restrictions for all servers and clients
#restrict default ignore
#restrict -6 default ignore
# A more open policy, allow access but deny changing the configuration
restrict default nomodify nopeer
#restrict -6 default nomodify nopeer
# Allow localhost
restrict 127.0.0.1
restrict -6 ::1
# To allow machines within your network to synchronize
# their clocks with your server, but ensure they are
# not allowed to configure the server or used as peers
# to synchronize against, uncomment this line.
#restrict 192.168.0.0 mask 255.255.255.0 nomodify nopeer notrap
# you should not need to modify the following paths
driftfile /var/lib/ntp/ntp.drift
logfile /var/log/ntp.log
# DAEMONS
# Daemons to start at boot-up (in this order)
# - prefix a daemon with a ! to disable it
# - prefix a daemon with a @ to start it up in the background
DAEMONS=(syslog-ng dbus network netfs crond !hwclock ntpd)
