e4rat
Kurdistan
e4rat
Inlägg av Kurdistan »
e4rat ("Ext4 - Reducing Access Times") is a toolset to accelerate the boot process as well as application startups. Through physical file realloction e4rat eliminates both seek times and rotational delays. This leads to a high disk transfer rate.
Placing files on disk in a sequentially ordered way allows to efficiently read-ahead files in parallel to the program startup. The combination of sequentially reading and a high cache hit rate may reduce the boot time by a factor of three, as the example below shows.
e4rat is based on the online defragmentation ioctl EXT4_IOC_MOVE_EXT from the Ext4 filesystem, which was introduced in Linux Kernel 2.6.31. Other filesystem types and/or earlier versions of extended filesystems are not supported.
Läs fortsättningen:
http://e4rat.sourceforge.net/
Påvels blogg:
http://pavel.frimix.se/
http://mageiasv.blogspot.se/
Återgå till "Guider"
