No, Windows is not a virus. Here's what viruses do:
1. They replicate quickly. ... Okay, Windows does that.
2. Viruses use up valuable system resources, slowing down the system as they do so. ... Okay, Windows does that.
3. Viruses will, from time to time, trash your hard disk. ... Okay, Windows does that too.
4. Viruses are usually carried, unknown to the user, along with valuable programs and systems. ... Sigh.. Windows does that, too.
5. Viruses will occasionally make the user suspect their system is too slow (see 2) and the user will buy new hardware. ... Yup, Windows does that, too.
Until now it seems Windows is a virus but there are fundamental differences: Viruses are well supported by their authors, are running on most systems, their program code is fast, compact and efficient and they tend to become more sophisticated as they mature.
So Windows is not a virus. ... It's a bug.
windows...
SV: windows...
Du har väl inte missat denna tråd: http://ubuntu-se.org/smf/index.php/topic,5194.0.html
Den handlar om Storbuggen #1
SV: windows...
tills nu trodde jag faktisk att windows var ett operativ system, men nu vet man att den är en bugg
Aj, det bränns riktigt rejält, Jag är nära lösningen och MVG i skolan
SV: windows...
>> So Windows is not a virus. ... It's a bug. <<
FEL FEL FEL
Efter att ha sett videon så vet vi sanningen.......
Windows är ett plagiat. (ett buggigt sådant) Så HELT fel var det inte.
FEL FEL FEL
SV: windows...
Hmmm jag har fått lära mig att den enda skillnaden mellan Windows och ett virus är att viruset är gratis
Powered by caffeine
