Jag har förgäves försökt att spela in streamat ljud via Spotify och med Audacity. Fick det att funka i Mandriva 2010.2 till slut men inte i Ubuntu 10.10.
Har kollat i alsamixer och skjutit upp alla reglage utan att lyckas. Även testat olika inställningar i Audacity.
Vad kan vara felet?
lspci ger följande:
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
00:06.0 System peripheral: Intel Corporation 82865G/PE/P Processor to I/O Memory Interface (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801EB (ICH5) SATA Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: ATI Technologies Inc R420 JI [Radeon X800PRO]
01:00.1 Display controller: ATI Technologies Inc R420 [Radeon X800 PRO/GTO] (Secondary)
02:03.0 SCSI storage controller: Adaptec AIC-7850 (rev 03)
02:04.0 Communication controller: Conexant Systems, Inc. HSF 56k HSFi Modem (rev 01)
02:0a.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 07)
02:0a.1 Input device controller: Creative Labs SB Live! Game Port (rev 07)
02:0b.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
02:0e.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22/A IEEE-1394a-2000 Controller (PHY/Link)
02:0f.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Tacksam för lite hjälp.
Inget ljud vid inspelning
- OS: Xubuntu
Re: Inget ljud vid inspelning
Jag vet inte vad ditt problem är och jag har inte samma ljudkretsar och väldigt lite pulseaudio i min ljudstack. Men, för att inspelning av ljud (capture) ska funka för mej så måste jag sätta "Input Source" till "Stereo Mixer" i det grafiska gränssnittet för alsa-inställningar. För mej funkar det inte att bara göra det med kommandoraden.
I alsamixer i terminalen kan man se "Capture"-kanaler med F4 eller F5. Det kanske du redan vet. Se till att "Capture" är på och inte av (mellanslag). Kolla även "In-gain" och "Digital" om du har såna kanaler. Några tips bara. Vet inte om det hjälper.
- Nicki
Hej David och tack för ditt svar.
Jag har redan testat detta men sedan installerade jag Alsa-mixer (gamix) med grafisk gränssnitt. Alla reglage var uppe och påslagna. Klickade på Front Capture. Helt plötsligt funkade inspelningen. Kollade sedan i gamix igen och då var den avslagen men inspelningen funkar. (Bäst att inte röra den igen.)
