Hjälp, ubuntu-extras-keyring funkar inte efter uppdatering
eriksson25
Inlägg av eriksson25 »
Hej, Uppdaterade min server från 10.04 till 10.10. Men under instalationen så fick jag nått error medelande om keyring, men instalationen fortsatte. Efter omstart så kan jag dock inte instalera något via apt-get den klagar på min ubuntu-extras-keyring Hittade en bugg om detta som handla om rc versionen från september. Men deras fix va att köra "sudo apt-get --reinstall install ubuntu-extras-keyring"
Men detta ger samma error
eriksson25@eriksson25:~$ sudo apt-get --reinstall install ubuntu-extras-keyring
[sudo] password for eriksson25:
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Setting up ubuntu-keyring (2010.+09.30) ...
gpg: [don't know]: invalid packet (ctb=2e)
gpg: keydb_get_keyblock failed: eof
gpg: /etc/apt/trusted.gpg: copy to `/etc/apt/trusted.gpg.tmp' failed: invalid packet
gpg: error writing keyring `/etc/apt/trusted.gpg': invalid packet
gpg: keydb_search failed: invalid packet
gpg: key 437D05B5: public key "[User ID not found]" imported
gpg: error reading `[stdin]': invalid packet
gpg: import from `[stdin]' failed: invalid packet
gpg: Total number processed: 0
gpg:               imported: 1
dpkg: error processing ubuntu-keyring (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of ubuntu-minimal:
 ubuntu-minimal depends on ubuntu-keyring; however:
  Package ubuntu-keyring is not configured yet.
dpkg: error processing ubuntu-minimal (--configure):
 dependency problems - leaving unconfigured
Setting up ubuntu-extras-keyring (2010.09.27) ...
No apport report written because the error message indicates its a followup error from a previous failure.
                          Importing extras.ubuntu.com keyring
gpg: error reading `/usr/share/keyrings/ubuntu-extras-keyring.gpg': invalid packet
gpg: import from `/usr/share/keyrings/ubuntu-extras-keyring.gpg' failed: invalid packet
dpkg: error processing ubuntu-extras-keyring (--configure):
dpkg: dependency problems prevent configuration of ubuntu-desktop:
 ubuntu-desktop depends on ubuntu-extras-keyring; however:
  Package ubuntu-extras-keyring is not configured yet.
dpkg: error processing ubuntu-desktop (--configure):
No apport report written because MaxReports is reached already
                                                              Errors were encountered while processing:
 ubuntu-keyring
 ubuntu-minimal
 ubuntu-desktop
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hoppas nån kan hjälpa mig, allt rullar på fint förutom att jag inte kan instalera något alls, eller uppdatera eftersom den inte har några public nycklar.
ycc
Re: Hjälp, ubuntu-extras-keyring funkar inte efter uppdateri
Inlägg av ycc »
Du är nog mer insatt än jag. Här är dock en länk som gällde karmic.
http://techpad.co.uk/content.php?sid=84
cd /etc/apt
sudo rm *.gpg
gpg --export -a 437D05B5 | sudo apt-key add -
sudo apt-get update
Jag tror inte det är riskabelt att sudda alla nycklarna, men jag vill i alla fall fästa din uppmärksamhet på det. Jag är inte tillräckligt insatt för att avgöra konsekvenserna av att prova detta.
eriksson25
Tack, jag kom faktiskt på själv i går natt att jag borde prova att bara ta bort nyklarna. Gjorde det och då hitta den nya automatiskt och allt funka. Tack så mkt ialla fall =)
