Startproblem Jack
perab
Startproblem Jack
Inlägg av perab »
Jag har lagt in Jack för att kunna köra programmet Djplay. Men jag får inte Jack att fungera. Om jag försöker starta Jack, får jag felmeddelandet
21:46:12.575 Patchbay deactivated.
21:46:12.586 Statistics reset.
21:46:12.636 ALSA connection graph change.
21:46:12.833 ALSA connection change.
21:46:21.699 Startup script...
21:46:21.700 artsshell -q terminate
sh: artsshell: not found
21:46:22.103 Startup script terminated with exit status=32512.
21:46:22.103 JACK is starting...
21:46:22.104 /usr/bin/jackd -dalsa -dhw:0 -r44100 -p1024 -n2
21:46:22.108 JACK was started with PID=6178.
jackd 0.118.0
Copyright 2001-2009 Paul Davis, Stephane Letz, Jack O'Quinn, Torben Hohn and others.
jackd comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK is running in realtime mode, but you are not allowed to use realtime scheduling.
Your system has an audio group, but you are not a member of it.
Please add yourself to the audio group by executing (as root):
  usermod -a -G audio (null)
After applying these changes, please re-login in order for them to take effect.
You don't appear to have a sane system configuration. It is very likely that you
encounter xruns. Please apply all the above mentioned changes and start jack again!
21:46:22.167 JACK was stopped with exit status=255.
21:46:22.168 Post-shutdown script...
[color=#BF00FF]21:46:22.169 killall jackd[/color]
jackd: no process found
21:46:22.585 Post-shutdown script terminated with exit status=256.
[color=#FF0000]21:46:24.297 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
från meddelandefönstret i Jack Controls.
Någon därute som har en idé om vad som är felet.[/color]
PS Jag försökte köra det föreslagna kommandot "usermod -a -G audio (null)" - med sudo före - men får då felmeddelande att syntaxen inte är korrekt. DS
Per
Det enda säkra sättet att aldrig misslyckas - det är att inte göra någonting alls!
pun
Re: Startproblem Jack
Inlägg av pun »
Så här får du nog fart på Jack
http://ubuntuforums.org/showthread.php?t=1307149
gksudo gedit /etc/security/limits.conf
Lägg till längst ner:
@audio - rtprio 99
@audio - nice -10
@audio - memlock unlimited
Also, as stated above, your username needs to be a member of the audio group.
dvs din användare måste vara medlem i audio-gruppen, Meny System > Administration > Användare & Grupper
