Ubuntu 10.04.1 uppskjuten
Nyheter i datorvärlden.
pun
Inlägg av pun »
Ubuntu 10.04.1 är tyvärr uppskjuten och nytt måldatum är 12 Augusti.
Just nu saknar man vist en release-manager var nu Steve Langasek tagit vägen ??
Hela meddelandet:
Hello all,
Yesterday the Ubuntu Release team, SRU team, and team tech leads had a
meeting about the first lucid point release preparation.
This is the current list of targeted bugs:
https://launchpad.net/ubuntu/+milestone/ubuntu-10.04.1
We'll most likely drop some more, but by and large 10.04.1 will be
what is currently in -updates and -security, hopefully most of what is
currently in -proposed, and a lot of what is on above milestone list.
Due to not having a full-time release manager (apologies from me on
this), we need to push back the release date from the originally planned
date of July 29th to August 12th. This will give use one more week to
develop bug fixes, one week to test them in -proposed,
and one week to roll and vet images.
Please note that this schedule change *DOES NOT AFFECT 10.10*...we are
firmly committed to delivering Maverick Meerkat on 10.10.10. ;)
-Robbie
Robbie Williamson robbie at ubuntu.com
Ubuntu robbiew[irc.freenode.net]
"You can't be lucky all the time, but you can be smart everyday"
-Mos Def
"Arrogance is thinking you are better than everyone else, while
Confidence is knowing no one else is better than you." -Me ;)
https://lists.ubuntu.com/archives/ubunt ... 31016.html
Länken kan då eventuellt vara viktig för de som bemödar sig med annat än någon fånig Sverige -demokrati.... :P
Swedish Berserk
Re: Ubuntu 10.04.1 uppskjuten
Inlägg av Swedish Berserk »
Nu har ju denna versionen blivit släppt enligt distrowatch:
http://distrowatch.com/?newsid=06234
Kan man installera denna versionen via uppdateringshanteraren? Eller måste man installera den som ett nytt operativ alltså ta bort gamla 10.04? I mina öron låter det som ett service pack ungefär.
Någon som vet?
Har inte orkat läsa på om hur, vad och varför men jag noterar att om man har patchat sin 10.04 klient idag så ser det ut som om man redan har 10.04.1...
johan@hostname:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 10.04.1 LTS
Release:	10.04
Codename:	lucid
P.Forsberg
AVREGISTRERAD
Inlägg av P.Forsberg »
johanre skrev:Har inte orkat läsa på om hur, vad och varför men jag noterar att om man har patchat sin 10.04 klient idag så ser det ut som om man redan har 10.04.1...
Release:	10.04
Codename:	lucid
Kan bekräfta detta. Kördes via automatiska uppdateringar.
LJ
pun
Inlägg av pun »
Swedish Berserk skrev: Kan man installera denna versionen via uppdateringshanteraren? Eller måste man installera den som ett nytt operativ alltså ta bort gamla 10.04? I mina öron låter det som ett service pack ungefär.
Någon som vet?
Kör man redan Ubuntu 10.04 och skött sina uppdateringar så har man då redan 10.04.1.
Vitsen med den nya utgåvan är att nya användare nu slipper att installera en massa uppdateringar efter installtion.
Vidare har några installationsbuggar lösts bla innehåller den en nyare Grub2 som förhoppningsvist hanterar Dualt-Boot helt korrekt.
Samtliga av Ubuntus officiella nedladdningställen har då bytt version. EDIT inte Sveriges i skrivande stund !
De som seedar bör snarast byta torrent till 10.04.1...... så slipper vi också gamla problem som inte finns i nyaste ison.
EDIT Svenska spegeln
http://se.releases.ubuntu.com/10.04.1/
Bowmore
Inlägg av Bowmore »
pun skrev:Vidare har några installationsbuggar lösts bla innehåller den en nyare Grub2 som förhoppningsvist hanterar Dualt-Boot helt korrekt.
Sen en uppdaterad Wubi för de som använder den med förhoppningsvis färre grub-promptar som resultat efter t.ex uppdateringar.
Återgå till "Nyheter"
