svn post-commit email problem
hub
Inlägg av hub »
Jag har satt upp en svn så att den skickar mail när något har "committats" genom att kopiera filen post-commit-tmpl till post-commit och den ser så här nu:
#!/bin/sh
# POST-COMMIT HOOK
# The post-commit hook is invoked after a commit.  Subversion runs
# this hook by invoking a program (script, executable, binary, etc.)
# named 'post-commit' (for which this file is a template) with the
# following ordered arguments:
#   [1] REPOS-PATH   (the path to this repository)
#   [2] REV          (the number of the revision just committed)
# The default working directory for the invocation is undefined, so
# the program should set one explicitly if it cares.
# Because the commit has already completed and cannot be undone,
# the exit code of the hook program is ignored.  The hook program
# can use the 'svnlook' utility to help it examine the
# newly-committed tree.
# On a Unix system, the normal procedure is to have 'post-commit'
# invoke other programs to do the real work, though it may do the
# work itself too.
# Note that 'post-commit' must be executable by the user(s) who will
# invoke it (typically the user httpd runs as), and that user must
# have filesystem-level permission to access the repository.
# On a Windows system, you should name the hook program
# 'post-commit.bat' or 'post-commit.exe',
# but the basic idea is the same.
# The hook program typically does not inherit the environment of
# its parent process.  For example, a common problem is for the
# PATH environment variable to not be set to its usual value, so
# that subprograms fail to launch unless invoked via absolute path.
# If you're having unexpected problems with a hook program, the
# culprit may be unusual (or missing) environment variables.
# Here is an example hook script, for a Unix /bin/sh interpreter.
# For more examples and pre-written hooks, see those in
# the Subversion repository at
# http://svn.collab.net/repos/svn/trunk/tools/hook-scripts/ and
# http://svn.collab.net/repos/svn/trunk/contrib/hook-scripts/
REPOS="$1"
REV="$2"
/usr/share/subversion/hook-scripts/commit-email.pl \
  "$REPOS" "$REV" email@gmail.com --from svn@xxx.com --diff n
Om jag anropar commit-email.pl direkt så kommer det med ÅÄÖ i mailet, men när svn kör det med post-commit scriptet så blir det inte åäö utan
testar ?\195?\165?\195?\164?\195?\182
(det ska stå testar åäö)
Hur ska jag göra för att svenska tecken ska följa med? I vad ska jag ändra? Jag förstår ingenting! ???
