Oljud, ingen bild och en crash-rapport. Går det inte att spela det i smplayer? Filen är på ca 23gb.
/usr/bin/mplayer -noquiet -nofs -nomouseinput -vc ffh264vdpau,ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau, -sub-fuzziness 1 -identify -slave -vo vdpau -ao pulse -nokeepaspect -framedrop -nodr -double -input nodefault-bindings:conf=/dev/null -stop-xscreensaver -wid 46137687 -monitorpixelaspect 1 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -ass-styles /home/xtr3m3/.config/smplayer/styles.ass -fontconfig -font Arial -subfont-autoscale 0 -subfont-osd-scale 20 -subfont-text-scale 20 -subcp ISO-8859-1 -subpos 100 -volume 48 -nocache -osdlevel 0 -slices -channels 2 -af volnorm=1,scaletempo,equalizer=0:0:0:0:0:0:0:0:0:0 -softvol -softvol-max 110 /home/xtr3m3/torrents/downloads/Zombieland.2009.BDr-ODOP/ZOMBIELAND.img
bt_audio_service_open: connect() failed: Connection refused (111)
MPlayer SVN-r31042-Ubuntu-RVM (C) 2000-2010 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Terminal type `unknown' is not defined.
Playing /home/xtr3m3/torrents/downloads/Zombieland.2009.BDr-ODOP/ZOMBIELAND.img.
Seek failed
libavformat file format detected.
[mp3 @ 0x278d180]Header missing
Last message repeated 964 times
[mp3 @ 0x278bf20]MAX_READ_SIZE:5000000 reached
[mp3 @ 0x278bf20]Estimating duration from bitrate, this may be inaccurate
ID_AUDIO_ID=0
[lavf] Audio stream found, -aid 0
ID_FILENAME=/home/xtr3m3/torrents/downloads/Zombieland.2009.BDr-ODOP/ZOMBIELAND.img
ID_DEMUXER=lavf
ID_AUDIO_FORMAT=80
ID_AUDIO_BITRATE=160000
ID_AUDIO_RATE=44100
ID_AUDIO_NCH=2
ID_LENGTH=1248352.67
ID_SEEKABLE=1
ID_CHAPTERS=0
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16le, 160.0 kbit/11.34% (ratio: 20000->176400)
ID_AUDIO_RATE=44100
ID_AUDIO_NCH=2
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
AO: [pulse] 44100Hz 2ch floatle (4 bytes per sample)
ID_AUDIO_CODEC=mp3
[Mixer] No hardware mixing, inserting volume filter.
Video: no video
Starting playback...
big_values too large!
mpg123: Can't rewind stream by 309 bits!
Blocktype == 0 and window-switching == 1 not allowed.
mpg123: Can't rewind stream by 742 bits!
mpg123: Can't rewind stream by 1425 bits!
ID_AUDIO_TRACK=0
mpg123: Can't rewind stream by 1351 bits!
mpg123: Can't rewind stream by 25 bits!
mpg123: Can't rewind stream by 1466 bits!
mpg123: Can't rewind stream by 26 bits!
mpg123: Can't rewind stream by 642 bits!
mpg123: Can't rewind stream by 1598 bits!
MPlayer interrupted by signal 11 in module: decode_audio
ID_SIGNAL=11
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
