Vänteläget slutade fungera i 10.04 [LÖST]
Det har varit lite si och så med vänteläget i tidigare releaser. I 9.10 fungerade det riktigt bra. Efter uppgradering till 10.04 fungerar det inte alls. Laptoppen vaknar aldrig. Någon som kan kasta ljus över detta fenomen?
Re: Vänteläget slutade fungera i 10.04
Med all sannolikhet en knölig kärn bug.....
Posta resultatet av lshw i en kodbox så ser man vad det är för burk
knacke
description: Portable Computer
product: Latitude D600
vendor: Dell Computer Corporation
serial: gcpgt0k
width: 32 bits
capabilities: smbios-2.3 dmi-2.3
configuration: boot=normal chassis=portable uuid=44454C4C-6300-1070-8067-E7C04F74306A
*-core
description: Motherboard
physical id: 0
serial: .gcpgt0j. .
*-firmware
description: BIOS
physical id: 0
version: A16 (06/29/2005)
capacity: 448KiB
capabilities: isa pci pcmcia pnp apm upgrade shadowing cdboot bootselect int13floppy720 int5printscreen int9keyboard int14serial int17printer int10video acpi usb agp smartbattery biosbootspecification netboot
*-cpu
description: CPU
product: Intel(R) Pentium(R) M processor 1400MHz
vendor: Intel Corp.
physical id: 400
bus info: cpu@0
version: 6.9.5
slot: Microprocessor
capacity: 1700MHz
width: 32 bits
clock: 133MHz
capabilities: fpu fpu_exception wp vme de pse tsc msr mce cx8 mtrr pge mca cmov clflush dts acpi mmx fxsr sse sse2 tm pbe up bts est tm2 cpufreq
*-cache:0
description: L1 cache
physical id: 700
capacity: 8KiB
capabilities: internal write-back data
*-cache:1
description: L2 cache
physical id: 701
capacity: 1MiB
clock: 66MHz (15.0ns)
capabilities: pipeline-burst internal varies unified
*-memory
description: System Memory
physical id: 1000
slot: System board or motherboard
capacity: 1GiB
*-bank:0
description: DIMM DDR Synchronous 266 MHz (3.8 ns) [empty]
physical id: 0
slot: DIMM_A
width: 64 bits
clock: 266MHz (3.8ns)
*-bank:1
physical id: 1
slot: DIMM_B
width: 64 bits
*-pci
description: Host bridge
product: 82855PM Processor to I/O Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 03
width: 32 bits
clock: 33MHz
configuration: driver=agpgart-intel
resources: irq:0 memory:e0000000-e7ffffff(prefetchable)
*-pci:0
description: PCI bridge
product: 82855PM Processor to AGP Controller
physical id: 1
bus info: pci@0000:00:01.0
version: 03
width: 32 bits
clock: 66MHz
capabilities: pci bus_master
resources: ioport:c000(size=4096) memory:fc000000-fdffffff memory:e8000000-efffffff(prefetchable)
*-display
description: VGA compatible controller
product: Radeon RV250 [Mobility FireGL 9000]
vendor: ATI Technologies Inc
physical id: 0
bus info: pci@0000:01:00.0
version: 01
width: 32 bits
clock: 66MHz
capabilities: agp agp-2.0 pm bus_master vga_palette cap_list rom
configuration: driver=radeon latency=32 mingnt=8
resources: irq:11 memory:e8000000-efffffff(prefetchable) ioport:c000(size=256) memory:fcff0000-fcffffff memory:fc000000-fc01ffff(prefetchable)
*-usb:0
description: USB Controller
product: 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: bus_master
configuration: driver=uhci_hcd latency=0
resources: irq:11 ioport:bf80(size=32)
*-usb:1
product: 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 01
width: 32 bits
clock: 33MHz
resources: irq:11 ioport:bf40(size=32)
*-usb:2
product: 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 01
width: 32 bits
clock: 33MHz
resources: irq:11 ioport:bf20(size=32)
*-usb:3
product: 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm debug bus_master cap_list
configuration: driver=ehci_hcd latency=0
resources: irq:11 memory:f4fffc00-f4ffffff
*-pci:1
product: 82801 Mobile PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: 81
width: 32 bits
clock: 33MHz
resources: ioport:d000(size=8192) memory:f6000000-fbffffff memory:40000000-47ffffff(prefetchable)
*-network
product: NetXtreme BCM5702X Gigabit Ethernet
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 02
serial: 00:0d:56:75:90:c7
capacity: 1GB/s
width: 64 bits
clock: 66MHz
capabilities: pcix pm vpd msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.102 firmware=5702-v2.25 latency=64 link=no mingnt=64 multicast=yes port=twisted pair
resources: irq:11 memory:faff0000-faffffff
*-pcmcia:0
description: CardBus bridge
product: OZ711EC1 SmartCardBus Controller
vendor: O2 Micro, Inc.
physical id: 1
bus info: pci@0000:02:01.0
version: 20
width: 32 bits
clock: 33MHz
capabilities: pcmcia bus_master cap_list
configuration: driver=yenta_cardbus latency=176 maxlatency=5
resources: irq:11 memory:f6000000-f6000fff ioport:d000(size=256) ioport:d400(size=256) memory:40000000-43ffffff(prefetchable) memory:4c000000-4fffffff
*-network
description: AR5001-0000-0000
product: Wireless LAN Reference Card
vendor: Atheros Communications, Inc.
physical id: 0
version: 00
slot: Socket 0
resources: irq:11
*-pcmcia:1
physical id: 1.1
bus info: pci@0000:02:01.1
version: 20
width: 32 bits
clock: 33MHz
configuration: driver=yenta_cardbus latency=176 maxlatency=5 mingnt=128
resources: irq:11 memory:f6001000-f6001fff ioport:d800(size=256) ioport:dc00(size=256) memory:44000000-47ffffff(prefetchable) memory:50000000-53ffffff
*-pccard UNCLAIMED
description: SmartCardBus Reader
vendor: O2Micro
physical id: 0
version: V1.0
slot: Socket 1
*-isa
description: ISA bridge
product: 82801DBM (ICH4-M) LPC Interface Bridge
physical id: 1f
bus info: pci@0000:00:1f.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
configuration: latency=0
*-ide
description: IDE interface
product: 82801DBM (ICH4-M) IDE Controller
physical id: 1f.1
bus info: pci@0000:00:1f.1
logical name: scsi0
logical name: scsi1
version: 01
width: 32 bits
clock: 33MHz
capabilities: ide bus_master emulated
configuration: driver=ata_piix latency=0
resources: irq:11 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:bfa0(size=16) memory:48000000-480003ff
*-disk
description: ATA Disk
product: SAMSUNG HM160HC
physical id: 0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: LQ10
serial: S12TJD0Q606406
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=0008c4b2
*-volume:0
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /
version: 1.0
serial: 5a54cdf4-13e2-483c-bb80-21422c8424c6
capacity: 146GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2009-10-30 19:47:59 filesystem=ext4 lastmountpoint=/ᅵᅵF^0ï¿œ(ᅵᅵᅵᅵᅵᅵᅵᅵᅵᅵu^ ᅵᅵᅵhï¿œW/ᅵᅵᅵïᅵᅵᅵᅵᅵᅵᅵ^0ᅵᅵᅵïᅵᅵᅵïᅵᅵa modified=2010-05-01 13:12:22 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,barrier=1,data=ordered mounted=2010-05-02 17:09:19 state=mounted
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
capacity: 2933MiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume
description: Linux swap / Solaris partition
physical id: 5
logical name: /dev/sda5
capacity: 2933MiB
capabilities: nofs
*-cdrom
description: DVD reader
product: DVD-ROM SD-C2612
vendor: TOSHIBA
physical id: 1
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/dvd
logical name: /dev/scd0
logical name: /dev/sr0
version: 1D21
capabilities: removable audio dvd
configuration: ansiversion=5 status=nodisc
*-multimedia
description: Multimedia audio controller
product: 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller
physical id: 1f.5
bus info: pci@0000:00:1f.5
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=Intel ICH latency=0
resources: irq:7 ioport:b800(size=256) ioport:bc40(size=64) memory:f4fff800-f4fff9ff memory:f4fff400-f4fff4ff
*-network
description: Wireless interface
product: Atheros AR5001X+ Wireless Network Adapter
vendor: Atheros Communications Inc.
physical id: 1
bus info: pci@0000:03:00.0
logical name: wlan0
version: 01
serial: 00:1b:2f:4e:44:ac
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath5k ip=192.168.1.14 latency=168 maxlatency=28 mingnt=10 multicast=yes wireless=IEEE 802.11bg
resources: irq:11 memory:4c000000-4c00ffff
*-battery
product: DELL 4M01068
vendor: Panasonic
physical id: 1
slot: Sys. Battery Bay
capacity: 52170mWh
configuration: voltage=11.1V
serial: gcpgt0k
width: 32 bits
*-core
physical id: 0
serial: .gcpgt0j. .
*-firmware
description: BIOS
physical id: 0
capacity: 448KiB
*-cpu
description: CPU
vendor: Intel Corp.
physical id: 400
bus info: cpu@0
version: 6.9.5
capacity: 1700MHz
width: 32 bits
clock: 133MHz
*-cache:0
physical id: 700
capacity: 8KiB
*-cache:1
physical id: 701
capacity: 1MiB
*-memory
physical id: 1000
capacity: 1GiB
*-bank:0
physical id: 0
slot: DIMM_A
width: 64 bits
*-bank:1
physical id: 1
slot: DIMM_B
width: 64 bits
*-pci
physical id: 100
version: 03
width: 32 bits
clock: 33MHz
*-pci:0
physical id: 1
version: 03
width: 32 bits
clock: 66MHz
*-display
physical id: 0
version: 01
width: 32 bits
clock: 66MHz
*-usb:0
physical id: 1d
version: 01
width: 32 bits
clock: 33MHz
*-usb:1
physical id: 1d.1
version: 01
width: 32 bits
clock: 33MHz
*-usb:2
physical id: 1d.2
version: 01
width: 32 bits
clock: 33MHz
*-usb:3
physical id: 1d.7
version: 01
width: 32 bits
clock: 33MHz
*-pci:1
physical id: 1e
version: 81
width: 32 bits
clock: 33MHz
*-network
physical id: 0
logical name: eth0
version: 02
capacity: 1GB/s
width: 64 bits
clock: 66MHz
*-pcmcia:0
physical id: 1
version: 20
width: 32 bits
clock: 33MHz
*-network
physical id: 0
version: 00
slot: Socket 0
resources: irq:11
*-pcmcia:1
physical id: 1.1
version: 20
width: 32 bits
clock: 33MHz
*-pccard UNCLAIMED
vendor: O2Micro
physical id: 0
version: V1.0
slot: Socket 1
*-isa
physical id: 1f
version: 01
width: 32 bits
clock: 33MHz
*-ide
physical id: 1f.1
logical name: scsi0
logical name: scsi1
version: 01
width: 32 bits
clock: 33MHz
*-disk
physical id: 0
version: LQ10
*-volume:0
vendor: Linux
physical id: 1
logical name: /
version: 1.0
capacity: 146GiB
*-volume:1
physical id: 2
capacity: 2933MiB
*-logicalvolume
physical id: 5
capacity: 2933MiB
capabilities: nofs
*-cdrom
vendor: TOSHIBA
physical id: 1
version: 1D21
*-multimedia
physical id: 1f.5
version: 01
width: 32 bits
clock: 33MHz
*-network
physical id: 1
logical name: wlan0
version: 01
width: 32 bits
clock: 33MHz
*-battery
vendor: Panasonic
physical id: 1
capacity: 52170mWh
Okidok.......
Jag hittade snabbt en olöst ny bugrapport över den här utmaningen:
https://bugs.launchpad.net/ubuntu/+sour ... bug/559163
Precis som man gör i tråden så skulle jag byta kärna men inte till Karmics utan till den senaste stabila.
Ubuntu Mainline
http://kernel.ubuntu.com/~kernel-ppa/mainline/v2.6.33/
Du behöver TRE filer, image samt header för vad du kör 32 bitar eller 64 bitar samt headers all.deb filen
Dubbelklicka på filen efter nedladdning så startar installationen, all.deb filen först, image sist.
Starta om och välj nya kärnan.
Ubuntu Mainline
Re: Vänteläget slutade fungera i 10.04 [LÖST]
Se inlägg #47 för lösning. Fungerar i 10.10 https://bugs.launchpad.net/ubuntu/+sour ... bug/559163
