fast grafikdrivrutinerna vill inte bli installerade...
2010-04-18 19:12:09,975 DEBUG: updating <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c>
2010-04-18 19:12:09,976 DEBUG: reading modalias file /lib/modules/2.6.32-21-generic-pae/modules.alias
2010-04-18 19:12:10,206 DEBUG: reading modalias file /usr/share/jockey/modaliases/bcmwl
2010-04-18 19:12:10,235 DEBUG: reading modalias file /usr/share/jockey/modaliases/disable-upstream-nvidia
2010-04-18 19:12:10,327 DEBUG: reading modalias file /usr/share/jockey/modaliases/fglrx-modules.alias.override
2010-04-18 19:12:10,335 DEBUG: reading modalias file /usr/share/jockey/modaliases/nvidia-173
2010-04-18 19:12:10,411 DEBUG: reading modalias file /usr/share/jockey/modaliases/nvidia-96
2010-04-18 19:12:10,454 DEBUG: reading modalias file /usr/share/jockey/modaliases/nvidia-current
2010-04-18 19:12:10,478 WARNING: Could not open DriverDB cache /var/cache/jockey/driverdb-OpenPrintingDriverDB.cache: [Errno 2] No such file or directory: '/var/cache/jockey/driverdb-OpenPrintingDriverDB.cache'
2010-04-18 19:12:11,007 DEBUG: loading custom handler /usr/share/jockey/handlers/madwifi.py
2010-04-18 19:12:11,047 WARNING: modinfo for module ath_pci failed: ERROR: modinfo: could not find module ath_pci
2010-04-18 19:12:11,048 DEBUG: Instantiated Handler subclass __builtin__.MadwifiHandler from name MadwifiHandler
2010-04-18 19:12:11,048 DEBUG: Alternate Atheros "madwifi" driver availability undetermined, adding to pool
2010-04-18 19:12:11,048 DEBUG: loading custom handler /usr/share/jockey/handlers/sl_modem.py
2010-04-18 19:12:11,086 DEBUG: Instantiated Handler subclass __builtin__.SlModem from name SlModem
2010-04-18 19:12:11,131 DEBUG: Software modem not available
2010-04-18 19:12:11,132 DEBUG: loading custom handler /usr/share/jockey/handlers/nvidia.py
2010-04-18 19:12:11,178 WARNING: modinfo for module nvidia_96 failed: ERROR: modinfo: could not find module nvidia_96
2010-04-18 19:12:11,179 DEBUG: Instantiated Handler subclass __builtin__.NvidiaDriver96 from name NvidiaDriver96
2010-04-18 19:12:11,199 DEBUG: NVIDIA accelerated graphics driver availability undetermined, adding to pool
2010-04-18 19:12:11,204 WARNING: modinfo for module nvidia_current failed: ERROR: modinfo: could not find module nvidia_current
2010-04-18 19:12:11,205 DEBUG: Instantiated Handler subclass __builtin__.NvidiaDriverCurrent from name NvidiaDriverCurrent
2010-04-18 19:12:11,225 DEBUG: NVIDIA accelerated graphics driver availability undetermined, adding to pool
2010-04-18 19:12:11,225 DEBUG: Could not instantiate Handler subclass __builtin__.NvidiaDriverBase from name NvidiaDriverBase
Traceback (most recent call last):
File "/usr/lib/python2.6/dist-packages/jockey/detection.py", line 914, in get_handlers
inst = obj(backend)
TypeError: __init__() takes exactly 3 arguments (2 given)
2010-04-18 19:12:11,241 WARNING: modinfo for module nvidia_173 failed: ERROR: modinfo: could not find module nvidia_173
2010-04-18 19:12:11,242 DEBUG: Instantiated Handler subclass __builtin__.NvidiaDriver173 from name NvidiaDriver173
2010-04-18 19:12:11,258 DEBUG: NVIDIA accelerated graphics driver availability undetermined, adding to pool
2010-04-18 19:12:11,258 DEBUG: loading custom handler /usr/share/jockey/handlers/fglrx.py
2010-04-18 19:12:11,265 WARNING: modinfo for module fglrx failed: ERROR: modinfo: could not find module fglrx
2010-04-18 19:12:11,265 DEBUG: Instantiated Handler subclass __builtin__.FglrxDriver from name FglrxDriver
2010-04-18 19:12:11,279 DEBUG: ATI/AMD proprietary FGLRX graphics driver availability undetermined, adding to pool
2010-04-18 19:12:11,279 DEBUG: loading custom handler /usr/share/jockey/handlers/b43.py
2010-04-18 19:12:11,321 DEBUG: Instantiated Handler subclass __builtin__.B43LegacyHandler from name B43LegacyHandler
2010-04-18 19:12:11,322 DEBUG: Broadcom B43legacy wireless driver availability undetermined, adding to pool
2010-04-18 19:12:11,340 DEBUG: Instantiated Handler subclass __builtin__.B43Handler from name B43Handler
2010-04-18 19:12:11,340 DEBUG: Broadcom B43 wireless driver availability undetermined, adding to pool
2010-04-18 19:12:11,341 DEBUG: loading custom handler /usr/share/jockey/handlers/dvb_usb_firmware.py
2010-04-18 19:12:11,393 DEBUG: Instantiated Handler subclass __builtin__.DvbUsbFirmwareHandler from name DvbUsbFirmwareHandler
2010-04-18 19:12:11,394 DEBUG: Firmware for DVB cards not available
2010-04-18 19:12:11,394 DEBUG: loading custom handler /usr/share/jockey/handlers/broadcom_wl.py
2010-04-18 19:12:11,405 WARNING: modinfo for module wl failed: ERROR: modinfo: could not find module wl
2010-04-18 19:12:11,415 DEBUG: Instantiated Handler subclass __builtin__.BroadcomWLHandler from name BroadcomWLHandler
2010-04-18 19:12:11,416 DEBUG: Broadcom STA wireless driver availability undetermined, adding to pool
2010-04-18 19:12:11,416 DEBUG: all custom handlers loaded
2010-04-18 19:12:11,416 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007CDsv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:12,307 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007FCsv00001043sd000082EAbc04sc03i00')
2010-04-18 19:12:12,504 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'snd_hda_intel', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:12,505 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd0000056Asv00001043sd000082AEbc0Csc03i20')
2010-04-18 19:12:12,517 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:device:')
2010-04-18 19:12:12,517 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0000:')
2010-04-18 19:12:12,517 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007CEsv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:12,528 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'platform:pcspkr')
2010-04-18 19:12:12,529 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'pcspkr', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:12,529 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'snd_pcsp', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:12,529 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'usb:v1D6Bp0001d0206dc09dsc00dp00ic09isc00ip00')
2010-04-18 19:12:12,578 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd0000056Dsv00000000sd00000000bc06sc04i01')
2010-04-18 19:12:12,589 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'input:b0019v0000p0001e0000-e0,1,k74,ramlsfw')
2010-04-18 19:12:12,595 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'evbug', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:12,596 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0100:')
2010-04-18 19:12:12,596 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd00000640sv00001043sd000082A5bc03sc00i00')
2010-04-18 19:12:12,611 WARNING: modinfo for module nvidia_173 failed: ERROR: modinfo: could not find module nvidia_173
2010-04-18 19:12:12,612 DEBUG: got handler xorg:nvidia_173([NvidiaDriver173, nonfree, disabled] NVIDIA accelerated graphics driver)
2010-04-18 19:12:13,016 WARNING: modinfo for module nvidia_current failed: ERROR: modinfo: could not find module nvidia_current
2010-04-18 19:12:13,017 DEBUG: got handler xorg:nvidia_current([NvidiaDriverCurrent, nonfree, disabled] NVIDIA accelerated graphics driver)
2010-04-18 19:12:13,159 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'nouveau', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,159 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'nvidiafb', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,159 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'vga16fb', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,159 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'platform:eisa')
2010-04-18 19:12:13,160 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007D6sv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:13,173 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'platform:Fixed MDIO bus')
2010-04-18 19:12:13,174 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd0000056Csv00001043sd000082AEbc01sc01i8a')
2010-04-18 19:12:13,185 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'pata_amd', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,185 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007C3sv00000000sd00000000bc06sc00i00')
2010-04-18 19:12:13,194 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0B00:')
2010-04-18 19:12:13,194 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0C02:')
2010-04-18 19:12:13,194 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007CBsv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:13,203 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0103:')
2010-04-18 19:12:13,203 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0C01:')
2010-04-18 19:12:13,204 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0200:')
2010-04-18 19:12:13,204 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:LNXSYSTM:')
2010-04-18 19:12:13,204 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007DCsv00001043sd0000816Abc02sc00i00')
2010-04-18 19:12:13,214 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'forcedeth', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,214 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007D1sv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:13,223 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'serio:ty06pr00id00ex00')
2010-04-18 19:12:13,238 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'serio_raw', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,238 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007C8sv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:13,246 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'input:b0003v04B3p3025e0110-e0,1,4,11,14,k71,72,73,74,75,77,79,7A,7B,7C,7D,7E,7F,80,81,82,83,84,85,86,87,88,89,8A,8C,8E,96,98,9E,9F,A1,A3,A4,A5,A6,AD,B0,B1,B2,B3,B4,B7,B8,B9,BA,BB,BC,BD,BE,BF,C0,C1,C2,F0,ram4,l0,1,2,sfw')
2010-04-18 19:12:13,247 DEBUG: no corresponding handler available for {'driver_type': 'kernel_module', 'kernel_module': 'evbug', 'jockey_handler': 'KernelModuleHandler'}
2010-04-18 19:12:13,247 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'pci:v000010DEd000007D0sv00000000sd00000000bc05sc00i00')
2010-04-18 19:12:13,255 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:LNXTHERM:')
2010-04-18 19:12:13,255 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'dmi:bvnPhoenixTechnologies,LTD:bvrASUSP5N73-AMACPIBIOSRevision0501:bd11/28/2008:svnSystemmanufacturer:pnSystemProductName:pvrSystemVersion:rvnASUSTeKComputerINC.:rnP5N73-AM:rvr2.XX:cvnChassisManufacture:ct3:cvrChassisVersion:')
2010-04-18 19:12:13,276 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'acpi:PNP0501:')
2010-04-18 19:12:13,276 DEBUG: querying driver db <jockey.detection.LocalKernelModulesDriverDB instance at 0x8db0a2c> about HardwareID('modalias', 'usb:v04B3p310Cd0200dc00dsc00dp00ic03isc01ip02')
