ubuntu
natalie
OS: Crunchbang
Utgåva: 6.06 Dapper LTS
ubuntu
Inlägg av natalie »
Ubuntu Loud Static Noise? I recently installed Ubuntu v9.10. Even if the sound is mute, a constant static beep would occur. This is very irritating and I was wondering if anyone know a way to fix this. Thanks so much!
___________________________
affiliateelite ~ affiliateelite.com ~ adgooroo ~ adgooroo.com
Re: ubuntu
Open up the "Terminal" via the menu Applications / Accessories and run the command "alsamixer", try to lower the value of "Master" to about 90-70%. Press the key <Esc> when youre done.
Or simply use the volume icon in the system tray and lower the volume there. :P
