Jag lyckas inte få Ubuntu att använda hela min skärm. Maximal upplösning blir 800x600 (dvs en liten yta mitt i skärmen) trots att skärmen erbjuder 1024x768.
Dator: TOSHIBA Satellite 1805-S207
Grafik: Trident CyberALADDiN-T
Skärm: 14.1”, internal display supports up to 16M colors at 1024 x 768
Enligt grafikdrivrutin-tillverkaren (http://www.tridentmicro.com) verkar det som om de endast supportar Windoze... innebär det att jag är rökt på denna laptop eller finns det något fiffigt för en Ubuntu-användare?
Det här fick jag ut av lspci:
00:00.0 Host bridge: ALi Corporation M1644/M1644T Northbridge+Trident (rev 01)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR+ INTx-
Latency: 0
Region 0: Memory at f0000000 (32-bit, prefetchable) [size=64M]
Capabilities: <access denied>
Kernel driver in use: agpgart-ali
Kernel modules: ali-agp
00: b9 10 44 16 07 00 10 a2 01 00 00 06 00 00 00 00
10: 08 00 00 f0 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 b0 00 00 00 00 00 00 00 00 00 00 00
01:00.0 VGA compatible controller: Trident Microsystems CyberBlade XPAi1 (rev 82)
Subsystem: Toshiba America Info Systems Device 0001
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 8
Interrupt: pin A routed to IRQ 11
Region 0: Memory at fc000000 (32-bit, non-prefetchable) [size=32M]
Region 1: Memory at fbc00000 (32-bit, non-prefetchable) [size=4M]
Region 2: Memory at f8000000 (32-bit, non-prefetchable) [size=32M]
Region 3: Memory at f7ff8000 (32-bit, non-prefetchable) [size=32K]
[virtual] Expansion ROM at 20000000 [disabled] [size=64K]
Kernel modules: tridentfb
00: 23 10 20 88 07 00 30 02 82 00 00 03 00 08 00 00
10: 00 00 00 fc 00 00 c0 fb 00 00 00 f8 00 80 ff f7
20: 00 00 00 00 00 00 00 00 00 00 00 00 79 11 01 00
30: 00 00 00 00 80 00 00 00 00 00 00 00 0b 01 00 00
Någon idé?
Upplösning, Laptop, Toshiba
- Osprey
Re: Upplösning, Laptop, Toshiba
Det enda du kan göra är förmodligen att kontakta Trident och fråga om de har något på gång och om de svarar att de inte har det så är det bara att säga till dem att du aldrig mer kommer att köpa något som de har tillverkat...
