Hej jag installerade Ubuntu 9.10 på denna burk. All hårdvara fungerar direkt efter installation.
Dock var wireless lite segt, lösning (skriver mest för att jag själv ska hitta detta nästa gång).
Re: Atheros AR9285 Wireless
Finally! It works Used the command in the second post here with karmic and it installed fine. after a reboot the wireless was up and running. Thanks a lot
Code:
sudo apt-get install linux-backports-modules-karmic
bjdo-laptop
description: Notebook
product: eMachines E525
vendor: eMachines
version: V1.06
serial: LXN330Y0459450A03C1601
width: 32 bits
capabilities: smbios-2.4 dmi-2.4
configuration: boot=normal chassis=notebook uuid=63386130-3461-6264-6338-002622755463
*-core
description: Motherboard
vendor: eMachines
physical id: 0
version: V1.06
serial: Base Board Serial Number
slot: Base Board Chassis Location
*-firmware
description: BIOS
vendor: eMachines
physical id: 0
version: V1.06 (07/11/2009)
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb
*-memory
description: System Memory
physical id: 14
slot: System board or motherboard
*-bank:0
description: SODIMM DDR2 Synchronous 800 MHz (1.2 ns)
product: C3C3C3C3C3C3C3C3C3C3C3C3C3C3C3C3C3C3
vendor: Transcend
physical id: 0
serial: 000816C3
slot: DIMM0
width: 64 bits
clock: 800MHz (1.2ns)
*-bank:1
description: SODIMM [empty]
physical id: 1
slot: DIMM2
*-cpu
description: CPU
product: Intel(R) Celeron(R) CPU 900 @ 2.20GHz
vendor: Intel Corp.
physical id: 1d
bus info: cpu@0
version: 6.7.10
serial: 0001-067A-0000-0000-0000-0000
slot: uPGA-478
capacity: 2200MHz
width: 64 bits
clock: 200MHz
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss tm pbe nx x86-64 constant_tsc up arch_perfmon pebs bts pni dtes64 monitor ds_cpl tm2 ssse3 cx16 xtpr pdcm xsave lahf_lm
*-cache:0
description: L2 cache
physical id: 1e
slot: L2 Cache
capacity: 1MiB
capabilities: synchronous internal write-back unified
*-cache:1
description: L1 cache
physical id: 20
slot: L1 Cache
capacity: 32KiB
capabilities: synchronous internal write-back data
*-cache
physical id: 1f
slot: L1 Cache
capacity: 32KiB
capabilities: synchronous internal write-back instruction
*-pci
description: Host bridge
product: Mobile 4 Series Chipset Memory Controller Hub
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 09
width: 32 bits
clock: 33MHz
configuration: driver=agpgart-intel
resources: irq:0
*-display:0
description: VGA compatible controller
product: Mobile 4 Series Chipset Integrated Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:28 memory:90000000-903fffff memory:80000000-8fffffff(prefetchable) ioport:50f0(size=8)
*-display:1 UNCLAIMED
description: Display controller
physical id: 2.1
bus info: pci@0000:00:02.1
version: 09
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: latency=0
resources: memory:93400000-934fffff
*-usb:0
description: USB Controller
product: 82801I (ICH9 Family) USB UHCI Controller #4
physical id: 1a
bus info: pci@0000:00:1a.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list
configuration: driver=uhci_hcd latency=0
resources: irq:20 ioport:50c0(size=32)
*-usb:1
product: 82801I (ICH9 Family) USB2 EHCI Controller #2
physical id: 1a.7
bus info: pci@0000:00:1a.7
version: 03
width: 32 bits
clock: 33MHz
capabilities: pm debug bus_master cap_list
configuration: driver=ehci_hcd latency=0
resources: irq:21 memory:96704c00-96704fff
*-multimedia
description: Audio device
product: 82801I (ICH9 Family) HD Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0
resources: irq:22 memory:96700000-96703fff
*-pci:0
description: PCI bridge
product: 82801I (ICH9 Family) PCI Express Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm bus_master cap_list
configuration: driver=pcieport-driver
resources: irq:24 ioport:4000(size=4096) memory:95700000-966fffff ioport:90400000(size=16777216)
*-pci:1
product: 82801I (ICH9 Family) PCI Express Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: 03
width: 32 bits
clock: 33MHz
resources: irq:25 ioport:3000(size=4096) memory:94600000-956fffff ioport:91400000(size=16777216)
*-network
description: Wireless interface
product: AR9285 Wireless Network Adapter (PCI-Express)
vendor: Atheros Communications Inc.
physical id: 0
bus info: pci@0000:04:00.0
logical name: wmaster0
version: 01
serial: 0c:ee:e6:da:1b:01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list logical ethernet physical wireless
configuration: broadcast=yes driver=ath9k ip=192.168.0.23 latency=0 multicast=yes wireless=IEEE 802.11bgn
resources: irq:17 memory:94600000-9460ffff
*-pci:2
product: 82801I (ICH9 Family) PCI Express Port 3
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: 03
width: 32 bits
clock: 33MHz
resources: irq:26 ioport:1000(size=8192) memory:93500000-945fffff ioport:92400000(size=16777216)
*-network
product: Atheros AR8132 / L1c Gigabit Ethernet Adapter
vendor: Attansic Technology Corp.
physical id: 0
bus info: pci@0000:05:00.0
logical name: eth0
version: c0
serial: 00:26:22:75:54:63
capacity: 100MB/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atl1c driverversion=1.0.0.1-NAPI firmware=N/A latency=0 link=no multicast=yes port=twisted pair
resources: irq:29 memory:93500000-9353ffff ioport:1000(size=128)
*-usb:2
product: 82801I (ICH9 Family) USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 03
width: 32 bits
clock: 33MHz
resources: irq:23 ioport:50a0(size=32)
*-usb:3
product: 82801I (ICH9 Family) USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 03
width: 32 bits
clock: 33MHz
resources: irq:19 ioport:5080(size=32)
*-usb:4
product: 82801I (ICH9 Family) USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 03
width: 32 bits
clock: 33MHz
resources: irq:20 ioport:5060(size=32)
*-usb:5
product: 82801I (ICH9 Family) USB UHCI Controller #6
physical id: 1d.3
bus info: pci@0000:00:1d.3
version: 03
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:5040(size=32)
*-usb:6
product: 82801I (ICH9 Family) USB2 EHCI Controller #1
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 03
width: 32 bits
clock: 33MHz
resources: irq:23 memory:96704800-96704bff
*-pci:3
product: 82801 Mobile PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: 93
width: 32 bits
clock: 33MHz
capabilities: pci bus_master cap_list
*-isa
description: ISA bridge
product: ICH9M LPC Interface Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
*-storage
description: SATA controller
product: ICH9M/M-E SATA AHCI Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi0
logical name: scsi1
version: 03
width: 32 bits
clock: 66MHz
capabilities: storage msi pm bus_master cap_list emulated
configuration: driver=ahci latency=0
resources: irq:27 ioport:50e8(size=8) ioport:50fc(size=4) ioport:50e0(size=8) ioport:50f8(size=4) ioport:5020(size=32) memory:96704000-967047ff
*-disk
description: ATA Disk
product: INTEL SSDSA2M040
physical id: 0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 2CV1
serial: CVGB9494012P040GGN
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=00009e6e
*-volume:0
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /
version: 1.0
serial: ab6ec8cc-82cd-4048-80a7-8cd6e648bbcd
capacity: 35GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2010-03-08 01:41:14 filesystem=ext4 lastmountpoint=/ᅵᅵᅵᅵۥᅵᅵNᅵᅵᅵDᅵᅵ>Cᅵᅵ]ᅵᅵᅵᅵïᅵᅵᅵᅵᅵïᅵᅵᅵۥᅵᅵ>Cï¿œ>Cï¿œU`ᅵᅵۥᅵ`ï¿œ%ᅵᅵ modified=2010-03-07 18:11:29 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,barrier=1,data=ordered mounted=2010-03-08 21:06:37 state=mounted
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
capacity: 1608MiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume
description: Linux swap / Solaris partition
physical id: 5
logical name: /dev/sda5
capacity: 1608MiB
capabilities: nofs
*-cdrom
description: DVD-RAM writer
product: DVDRAM GT30N
vendor: HL-DT-ST
physical id: 1
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/scd0
logical name: /dev/sr0
version: 1.01
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-serial UNCLAIMED
description: SMBus
product: 82801I (ICH9 Family) SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 03
width: 64 bits
clock: 33MHz
resources: memory:96705000-967050ff ioport:5000(size=32)
*-scsi
physical id: 1
bus info: usb@1:1
logical name: scsi6
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
product: iPod
vendor: Apple
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdb
logical name: /media/ADMINISTRAT
version: 2.70
serial: 5C938442ALGᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵᅵïᅵᅵ0
configuration: ansiversion=2 mount.fstype=vfat mount.options=rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0077,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,flush,errors=remount-ro state=mounted
*-medium
description: Windows FAT volume
vendor: *UOKJIHC
physical id: 0
version: FAT32
serial: 6bb8-0bfa
capacity: 1931MiB
capabilities: fat initialized
configuration: FATs=2 filesystem=fat label=IPOD mount.fstype=vfat mount.options=rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0077,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,flush,errors=remount-ro state=mounted
*-battery
description: Lithium Ion Battery
product: Li-lon Battery
vendor: -Virtual Battery 0-
physical id: 1
version: 10/12/2007
serial: Battery 0
slot: Fake
*-power UNCLAIMED
description: OEM_Define1
product: OEM_Define4
vendor: OEM_Define2
physical id: 2
version: OEM_Define5
serial: OEM_Define2
capacity: 75mWh
eMachines E525
Hoppa till
- Hjälp med Ubuntu
- ↳ För nybörjaren
- ↳ Skaffa en fadder
- ↳ Komma igång med Ubuntu
- ↳ Installation och uppgradering
- ↳ Hårdvara och drivrutiner
- ↳ Bild
- ↳ Internet
- ↳ Inmatning
- ↳ Lagring
- ↳ Ljud
- ↳ Prylar
- ↳ Kontor
- ↳ Recensioner: Hårdvaruregistret - HVR
- ↳ Bärbara datorer
- ↳ Moderkort
- ↳ Instickskort
- ↳ Trådlösa nätverkskort
- ↳ Kringutrustning
- ↳ Använda Ubuntu
- ↳ Skrivbordet
- ↳ Gnome (Ubuntu)
- ↳ KDE (Kubuntu)
- ↳ Xfce (Xubuntu)
- ↳ Lxde (Lubuntu)
- ↳ Program
- ↳ Bildhantering
- ↳ Internet
- ↳ Kontor
- ↳ Ljud och video
- ↳ Spel
- ↳ Ubuntu för telefon och surfplatta
- ↳ Guider
- ↳ Inaktuella guider
- ↳ Avancerat bruk
- ↳ Terminalforum
- ↳ Nätverk, säkerhet och servrar
- ↳ Programmering och webbdesign
- ↳ Experimentverkstad
- ↳ Ubuntus senaste utvecklingsversion
- Allt annat
- ↳ Ubuntu Sverige
- ↳ Information
- ↳ Administrationen informerar
- ↳ Varningar och avstängningar
- ↳ Rekrytering
- ↳ Omröstningar
- ↳ Översättare
- ↳ Forum
- ↳ Gammal hjälp med Ubuntu
- ↳ För nybörjaren - inaktuell
- ↳ Installation/Uppgradering/Drivrutiner - inaktuell
- ↳ Använda X/K/Ubuntu - inaktuell
- ↳ Skrivbordet - inaktuell
- ↳ Program - inaktuell
- ↳ Ljud/Video/Multimedia - inaktuell
- ↳ Ubuntus utvecklingsversion - inaktuell
- ↳ Ubuntus senaste utvecklingsversion Precise Pangolin
- ↳ Ubuntus senaste utvecklingsversion Quantal Quetzal
- ↳ Felrapportering
- ↳ Lokala användargrupper | Möten | LoCo träffar
- ↳ LoCo Sverige
- ↳ Ubuntu Café
- ↳ Nyheter
- ↳ Surftips
- ↳ Övrig hjälp
- ↳ Hårdvara som hårdvara
- ↳ Andra öppna och fria operativsystem
- ↳ Proprietära operativsystem
