Här behandlar vi ritprogram, program för fotoretuschering, bildhantering och liknande. Vänligen observera att trådar rörande grafikkort hör hemma i
Hårdvara och drivrutiner !
mrfab
AVREGISTRERAD
Inlägg: 922 Blev medlem: 16 maj 2007, 22:30
Inlägg
av mrfab » 28 feb 2010, 18:10
Har provat detta vet inte hur många gånger nu och något fel gör jag någonstans.Det jag vill göra är föra in det här i min xorg.conf
Section "Monitor"
Identifier "SyncMaster 225BW"
Option "DPMS"
DisplaySize 474 296
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 75.0
Modeline "1680x1050" 146.2 1680 1784 1960 2240 1050 1053 1059 1089
EndSection
Section "Screen"
Identifier "Default Screen"
Device ""
Monitor "SyncMaster 225BW"
Option "MonitorLayout" "CRT"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1680x1050" "1280x1024" "1024x768"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
ViewPort 0 0
EndSubSection
EndSection
Min xorg.conf ser ut så här
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "ServerFlags"
Option "Xinerama" "off"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Monitor"
Identifier "0-DFP1"
Option "Disable" "true"
EndSection
Section "Monitor"
Option "PreferredMode" "1400x1050"
Option "TargetRefresh" "60"
Option "Position" "0 0"
Option "Rotate" "normal"
Option "Disable" "false"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
Option "Monitor-DFP1" "0-DFP1"
Option "Monitor-CRT1" "0-CRT1"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Configured Screen Device"
Device "Configured Video Device"
Virtual 2048 2048
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Vad skall jag skriva under device i section screen menyen ?
Och vilka delar skall jag byta ut?
mrfab , redigerad totalt 27 gånger.
Katt
AVREGISTRERAD
Inlägg: 625 Blev medlem: 19 nov 2009, 11:04
Inlägg
av Katt » 06 mar 2010, 11:48
Alltid xorg problem som ställer till det
och speciellt i kombination med ATI
Testa först att göra en backup av xorg.conf filen och sen ta bort den helt. Starta om X och se om den automatiskt klarar av att hantera din skärm med rätt upplösning. Om inte så borde den generera en lite enklare fil som du kan modifiera. Som referens postar jag delar av min xorg.conf, kanske kan ge dig ledtrådar om vart saker hamnar.
Identifier "Layout0"
Screen 0 "Screen0" 0 720
Option "Xinerama" "0"
EndSection
Section "Monitor"
# HorizSync source: xconfig, VertRefresh source: xconfig
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-0"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 76.0
ModeLine "1680x1050_60.00" 147.140 1680 1784 1968 2256 1050 1051 1054 1087 -hsync +vsync
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce 9400"
BusID "PCI:2:0:0"
Screen 0
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinView" "0"
Option "TwinViewXineramaInfoOrder" "CRT-0"
Option "metamodes" "CRT: 1680x1050_60.00 +0+0"
Depth 24
EndSubSection
EndSection
Det är inte lätt när det är svårt!
mrfab
AVREGISTRERAD
Inlägg
av mrfab » 06 mar 2010, 12:32
Hur tar jag bort xorg.conf lättast
barzam
Inlägg: 504 Blev medlem: 14 feb 2009, 09:36
Inlägg
av barzam » 06 mar 2010, 12:37
Såhär tar du bort och säkerhetskopierar du xorg.conf till xorg.conf.bak
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
För att återställa
sudo mv /etc/X11/xorg.conf.bak /etc/X11/xorg.conf
Katt
AVREGISTRERAD
Inlägg
av Katt » 06 mar 2010, 12:43
mrfab skrev: Hur tar jag bort xorg.conf lättast
sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.backup
sudo rm /etc/X11/xorg.conf
mrfab
AVREGISTRERAD
Inlägg
av mrfab » 06 mar 2010, 13:10
När jag inaktiverar min ena skärm via ccc så blir xrandr 1.2 enablad utav någon anledning har försökt att unabla den men ej lyckats .
$ --query-monitor
--query-monitor: command not found
_____@c-8ff370d5:~$ aticonfig --query-monitor
Error: option --query-monitor is not supported when RandR 1.2 is enabled!
_____@c-8ff370d5:~$
Katt
AVREGISTRERAD
Inlägg
av Katt » 06 mar 2010, 13:16
mrfab skrev: När jag inaktiverar min ena skärm via ccc så blir xrandr 1.2 enablad utav någon anledning har försökt att unabla den men ej lyckats .
$ --query-monitor
_____@c-8ff370d5:~$
Nu hängde jag inte alls med på vad du gjorde, men sitter o andra sidan inte med ATI kort. Kan du inte plugga ur den andra skärmen tills vidare så vi får fixat den ena först?
mrfab
AVREGISTRERAD
Inlägg
av mrfab » 06 mar 2010, 14:53
Inget fel på ati-drivern problemet är randr1.2 som helt plötsligt bestämmer sig för att vara enablad bara för att man disablar en monitor i ccc
och att det tydligen är omöjligt att disabla xrandr1.2 nu gör ju inte saken bättre.
mrfab
AVREGISTRERAD
Inlägg
av mrfab » 27 mar 2010, 17:52
Efter att ha försökt med
och fått svaret Error: option --query-monitor is not supported when RandR 1.2 is enabled!
Så använde jag xrandr för att ändra inställningsalternativen i catalyst control center så här
cvt 1680 1050
# 168x1050 59.52 Hz (CVT) hsync: 64.81 kHz; pclk: 14.00 MHz
Modeline "1680x1050_60.00" 14.00 168 176 192 216 1050 1053 1063 1089 -hsync +vsync
xrandr --newmode "1680x1050_60.00" 14.00 168 176 192 216 1050 1053 1063 1089 -hsync +vsync
xrandr --addmode CRT1 "1680x1050_60.00"
Körde även
i sectionen screen la jag till
efter depth linjen
Och det funkade för mig alternativet 1680 1050 finns nu i catalyst
Xorgen
Identifier "amdcccle Layout"
Screen 0 "aticonfig-Screen[0]-0" 1680 0
Screen "amdcccle-Screen[1]-1" 0 24
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
EndSection
EndSection
Section "Monitor"
EndSection
Section "Monitor"
Identifier "0-CRT1"
Option "PreferredMode" "1680x1050"
EndSection
Section "Monitor"
Identifier "0-DFP1"
Option "PreferredMode" "1024x768"
EndSection
Section "Device"
Driver "fglrx"
Option "UseFastTLS" "1"
Option "EnableRandR12" "false"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "amdcccle-Device[1]-1"
Driver "fglrx"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "amdcccle-Screen[1]-1"
Device "amdcccle-Device[1]-1"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
