nVidia-tråden
pun
nVidia-tråden
Inlägg av pun »
Nya drivare ute, ver 195.36.08
http://www.nvnews.net/vbulletin/showthread.php?t=122606
Release highlights since 195.36.03:
    * Added support for the following GPUs:
          o Quadro FX 880M
          o GeForce GTS 350M
          o GeForce GTS 360M
    * Fixed a bug that caused screen corruption after an application released a GLX_NV_present_video device.
    * Fixed an X server crash caused by starting nvidia-settings while X was not on the active VT.
    * Fixed brightness control hotkeys on some laptops.
    * Fixed an nvidia-settings bug that produced many "Bad argument" warning messages when running nvidia-settings --query all.
    * Fixed an installer bug that produced the following message:
      Code:
      WARNING: Unable to perform the runtime configuration check for library
      'libGL.so.1' ('/usr/lib/libGL.so.195.36.03'); assuming successful installation.
    * Fixed a bug that caused G-Sync stereo synchronization to fail sometimes when enabling frame lock.
    * Fixed a bug that caused OpenGL applications to occasionally crash with "double free or corruption" messages when exiting.
    * On GPUs with VDPAU feature set A, enhanced VDPAU's handling of some corrupted or incorrectly formatted MPEG-1/2 streams. This solves a reported issue with "0testbad.mpg".
    * Fixed a bug in the VDPAU video mixer that caused chroma aberrations, and corruption in the right-hand few columns of pixels, when post- processing video surfaces with widths not an exact multiple of 4 pixels.
    * Fixed a bug that prevented the GPUFanControlState attribute from being set on the nvidia-settings command line.
Har inte kollat lämpliga ppa,n, Philip 5 ?
philip5
HC-IRCare
Re: nVidia-tråden
Inlägg av philip5 »
Jag drog ner dem igår men har bar inte riktigt haft tid att packa dem. Blir nog ikväll för Karmic. Lucid får vänta vad gäller min repo tills Lucid är i princip final.
pun
Re: nVidia-tråden
Inlägg av pun »
philip5 skrev:Jag drog ner dem igår men har bar inte riktigt haft tid att packa dem. Blir nog ikväll för Karmic. Lucid får vänta vad gäller min repo tills Lucid är i princip final.
Okidok... Lucid kör redan betaversionen av drivaren och final är nog snabbt på plats om jag känner Alberto Milone rätt... ;)
Steg1 är troligen att han uppdaterar sitt eget ppa med den här drivaren, sen test några dagar och sedan in i Lucid.
Info om Albertos ppa:
https://launchpad.net/~albertomilone/+a ... provements
philip5
HC-IRCare
Re: nVidia-tråden
Inlägg av philip5 »
Frågan är om Lucid verkligen kommer få någon uppdatering av drivisarna eftersom hela Lucid gått in i frusen fas där det är buggfixande som gäller fram till final release. Externa PPA:er som min är nog räddningen för de som inte vill mecka själva.
pun
Re: nVidia-tråden
Inlägg av pun »
Nej Lucid är inte fryst förutom på ny funktionalitet.
Vem är Alberto Milone
http://albertomilone.com/wordpress/
Alberto är numera anställd av Canonical och sköter nVidia-drvarna.
Betan åkte in häromveckan, levererad av just Alberto
https://lists.ubuntu.com/archives/lucid ... 05955.html
Så Lucid får den här drivaren med all sannolikhet..... ;) mer oxå....
philip5
HC-IRCare
Re: nVidia-tråden
Inlägg av philip5 »
Nu har jag iaf laddat upp nvidia 195.36.08 drivisarna till min Launchpad PPA för Karmic och de finns tillgängliga så snart de är byggda där.
philip5
HC-IRCare
Re: nVidia-tråden
Inlägg av philip5 »
Såg att Nvidia har tagit bort 195.36.08 och 195.36.03 från sin sajt och avråder folk att använda de drivisarna. Tydligen har det uppstått en bugg för somliga användare där fläkten går på för fullt och inte kommer ner i varv. Jag har själv inte det problemet men om någon använder någon av dessa två versioner av drivisarna så är det ett känt problem som de jobbar på. De som har problemet rekommenderar de rulla tillbaka till version 190.53. Egentligen rekommenderar de alla att göra det tillsvidare men för egen del så kör jag på med 195.36.08 som funkar bra för mig.
Det är tydligen inte heller helt linuxspecifikt det här problemet utan ska tydligen även drabba vissa som kör nvidias windowsdrivisar av version 196.75 på samma sätt. De rekommenderas också att rulla tillbaka till äldre version.
ZX Spectrum
Re: nVidia-tråden
Inlägg av ZX Spectrum »
Idag fick jag uppdaterat till senaste nvidia-drivrutin och det fungerar bra för mig också.
Var lite skumt första gången jag startade om datorn för då kom jag in i lågupplösningsläge men det räckte att starta om ytterligare en gång så blev allt som vanligt. Kan tillägga att det var både nvidias drivrutin och linuxkärnan som uppdaterades.
pun
Re: nVidia-tråden
Inlägg av pun »
Alberto har lagt ut ett meddelande på Ubuntus mailinglist och bloggar även om detta:
http://albertomilone.com/wordpress/?p=482
Har själv inte märkt något med mitt 8600 kort, varken förhöjd temperatur eller att fläkten löpt amok....
pun
Re: nVidia-tråden
Inlägg av pun »
nVidia har nu lagt ut en fixad pre-release
* Fixed a bug that caused the X server to crash when rendering occurred while the X server was not on the active VT.
* Fixed a regression that caused the driver to fail to properly adjust the GPU fan speed on some GPUs.
* Fixed a bug that prevented performance level transitions on recent GPUs with SDDR3 and GDDR5 memory.
http://www.nvnews.net/vbulletin/showthr ... ?p=2209577
philip5
HC-IRCare
Re: nVidia-tråden
Inlägg av philip5 »
pun skrev:nVidia har nu lagt ut en fixad pre-release
jobbar nu på att slänga upp en update med de här nya drivisarna på min repo för karmic...
ZX Spectrum
Re: nVidia-tråden
Någon som vet om detta har med problemet med uppstarten av Lucid att göra? Just nu kan jag inte ens boota från en live-cd med Ubuntu 10.04 utan att datorn hänger sig efter ett tag när det grafiska kommer
pun
Re: nVidia-tråden
Inlägg av pun »
ZX Spectrum skrev:Någon som vet om detta har med problemet med uppstarten av Lucid att göra? Just nu kan jag inte ens boota från en live-cd med Ubuntu 10.04 utan att datorn hänger sig efter ett tag när det grafiska kommer
Den första lösta buggen i listan kan spöka till det och Ubuntu har bökat med tty1 o tty 7 pga Plymouthstrul.
Det syns hursomhelst inte till någon uppdatering än när jag skriver det här:
https://lists.ubuntu.com/archives/lucid ... hread.html
Tyvärr är man också i en "betafrys" just nu..... vet inte hur man gör förhoppningsvist så blir det pannkaka under ISO testningen av beta-isos så man är tvungen att ändra.
Vill du prova själv så ladda ner dagens bygge:
http://cdimage.ubuntu.com/daily/current/
philip5
HC-IRCare
Re: nVidia-tråden
Inlägg av philip5 »
Nu är iaf nvidia 195.36.15 beta drivers uppe på min PPA på Launchpad för Karmic.
Enjoy!
pun
Re: nVidia-tråden
Inlägg av pun »
nVidia har även gett ut en ny drivare som fullt stödjer OpenGL 3.3
Info:
http://www.phoronix.com/scan.php?page=n ... &px=ODA3Nw
Till drivaren:
http://www.nvnews.net/vbulletin/showthr ... ?p=2212330
Nu finns det sedan inte vad jag känner till något som kan köras under Linux med OpenGL 3.3.... :P
Katt
AVREGISTRERAD
Re: nVidia-tråden
Inlägg av Katt »
Jag säger det, nVidia har vart väldigt stabilt sen mitt första kort. Riktigt skoj att se de följer OpenGL utvecklingen seriöst dessutom =)
Det är inte lätt när det är svårt!
pun
Re: nVidia-tråden
Inlägg av pun »
Lucid kör nu senaste versionen (ej OpenGL)
Info:
https://lists.ubuntu.com/archives/lucid ... 08401.html
Inga problem med min stationära burk.
ZX Spectrum
Re: nVidia-tråden
Frågan är hur jag ska kunna köra Lucid på min bärbara dator Asus Pro50G (Geforce 8200M)?
Som det är nu så kan jag inte ens boota den i felsäkert läge.
Är plymouth så nästlad att det inte ens går att boota ickegrafiskt?!?
Rune.K
Re: nVidia-tråden
Inlägg av Rune.K »
ZX Spectrum skrev:Frågan är hur jag ska kunna köra Lucid på min bärbara dator Asus Pro50G (Geforce 8200M)?
Nu vet jag inte om Lilo finns i förrådet till Lucid.
Jag fick stora problem med min Kubuntu 9.10-installation efter en uppdatering...
Grafiken fungerande inte, jag har ett nvidiakort.
Efter att ha testat olika drivrutiner och inställningar i "recovery mode" utan positivt resultat så bytte jag ut grub2 mot Lilo.
Sedan dess så fungerar mitt Kubuntu utan problem.
Dessutom har jag haft stora problem med Lucid, så det har jag gett upp tillsvidare.
Prova att byta ut grub2 mot Lilo som bootloader. Det är mitt tips.
ZX Spectrum
Re: nVidia-tråden
Hur ska det gå till när jag inte kommer in i recovery-läget?
