inne på hardware drivers
(software modem)
Om mitt system:"this driver is activated but not currently in use" och vidare står det:
if this driver is not enabled, you will not be able to use your modem.
http://img412.imageshack.us/img412/4025 ... hot1ce.png
lshwLinux pc 2.6.31-15-generic #50-Ubuntu SMP Tue Nov 10 14:54:29 UTC 2009 i686 GNU/Linux
Description: Ubuntu 9.10
2.6.31-15-generic i686
kim@pc:~$ sudo lshw
pc
description: Notebook
product: AMILO Pa 1510
vendor: FUJITSU SIEMENS
version: Not Applicable
serial: 5041770A23
width: 32 bits
capabilities: smbios-2.4 dmi-2.4 smp-1.4 smp
configuration: boot=normal chassis=notebook cpus=2 uuid=80C56DAB-1A64-0010-B51D-3D0C96A726C8
*-core
description: Motherboard
physical id: 0
serial: Not Applicable
*-firmware
description: BIOS
physical id: 0
version: 1.03C (07/27/06)
capacity: 960KiB
capabilities: pci pnp upgrade shadowing escd cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer int10video acpi usb agp biosbootspecification
*-cpu:0
description: CPU
product: AMD Turion(tm) 64 X2 Mobile Technology TL-50
vendor: Advanced Micro Devices [AMD]
physical id: 4
bus info: cpu@0
version: 15.8.2
slot: Socket M2/S1G1
capacity: 4GHz
width: 64 bits
clock: 200MHz
capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt rdtscp x86-64 3dnowext 3dnow extd_apicid pni cx16 lahf_lm cmp_legacy svm extapic cr8_legacy cpufreq
*-cache:0
description: L2 cache
physical id: 5
slot: L2 Cache
capacity: 1MiB
capabilities: synchronous internal write-back
*-cache:1
description: L1 cache
physical id: 0
*-cache:2
physical id: 1
*-memory
description: System Memory
physical id: 1b
slot: System board or motherboard
*-bank:0
description: DIMM DRAM Synchronous
physical id: 0
slot: S1
width: 64 bits
*-bank:1
physical id: 1
slot: S2
width: 64 bits
*-cpu:1
physical id: 1
bus info: cpu@1
version: 15.8.2
capacity: 800MHz
capabilities: cpufreq
*-cache:0
physical id: 0
*-cache:1
physical id: 1
*-pci:0
description: Host bridge
product: RS480 Host Bridge
vendor: ATI Technologies Inc
physical id: 100
bus info: pci@0000:00:00.0
version: 10
width: 32 bits
clock: 66MHz
configuration: latency=64
*-pci:0
description: PCI bridge
product: RS480 PCI Bridge
physical id: 1
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: pci ht bus_master cap_list
resources: ioport:9000(size=4096) memory:c0100000-c01fffff ioport:c8000000(size=134217728)
*-display UNCLAIMED
description: VGA compatible controller
product: RS482 [Radeon Xpress 200M]
physical id: 5
bus info: pci@0000:01:05.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: pm bus_master cap_list
configuration: latency=66 mingnt=8
resources: memory:c8000000-cfffffff(prefetchable) ioport:9000(size=256) memory:c0100000-c010ffff memory:c0120000-c013ffff(prefetchable)
*-pci:1
physical id: 4
bus info: pci@0000:00:04.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht bus_master cap_list
configuration: driver=pcieport-driver
resources: irq:0
*-ide:0
description: IDE interface
product: IXP SB400 Serial ATA Controller
physical id: 12
bus info: pci@0000:00:12.0
logical name: scsi0
version: 80
width: 32 bits
clock: 66MHz
capabilities: ide pm msi bus_master cap_list rom emulated
configuration: driver=sata_sil latency=64
resources: irq:22 ioport:8440(size=8) ioport:8430(size=4) ioport:8420(size=8) ioport:8410(size=4) ioport:8400(size=16) memory:c0004000-c00041ff memory:40000000-4007ffff(prefetchable)
*-disk
description: ATA Disk
product: WDC WD1200BEVS-0
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 01.0
serial: WD-WXE806351507
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=9b672b8c
*-volume:0
description: EXT3 volume
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /
version: 1.0
serial: 1f109e18-8a30-4c5f-8007-52a33b707d7d
capacity: 109GiB
capabilities: primary bootable journaled large_files recover ext3 ext2 initialized
configuration: created=2008-03-09 18:01:19 filesystem=ext3 modified=2009-12-08 15:10:47 mount.fstype=ext3 mount.options=rw,relatime,errors=remount-ro,data=writeback mounted=2009-12-08 17:04:12 state=mounted
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
capacity: 2580MiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume
description: Linux swap / Solaris partition
physical id: 5
logical name: /dev/sda5
capacity: 2580MiB
capabilities: nofs
*-usb:0
description: USB Controller
product: IXP SB400 USB Host Controller
physical id: 13
bus info: pci@0000:00:13.0
version: 80
width: 32 bits
clock: 66MHz
capabilities: msi bus_master cap_list
configuration: driver=ohci_hcd latency=64
resources: irq:19 memory:c0005000-c0005fff
*-usb:1
physical id: 13.1
bus info: pci@0000:00:13.1
version: 80
width: 32 bits
clock: 66MHz
resources: irq:19 memory:c0006000-c0006fff
*-usb:2
product: IXP SB400 USB2 Host Controller
physical id: 13.2
bus info: pci@0000:00:13.2
version: 80
width: 32 bits
clock: 66MHz
capabilities: pm msi bus_master cap_list
configuration: driver=ehci_hcd latency=64
resources: irq:19 memory:c0007000-c0007fff
*-serial
description: SMBus
product: IXP SB400 SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 83
width: 32 bits
clock: 66MHz
capabilities: ht cap_list
configuration: driver=piix4_smbus latency=0
resources: irq:0 ioport:8450(size=16) memory:fed00000-fed003ff
*-ide:1
product: IXP SB400 IDE Controller
physical id: 14.1
bus info: pci@0000:00:14.1
logical name: scsi2
version: 80
width: 32 bits
clock: 66MHz
capabilities: ide msi bus_master cap_list emulated
configuration: driver=pata_atiixp latency=64
resources: irq:16 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:8460(size=16)
*-cdrom
description: DVD writer
product: DVD-RW GWA-4082N
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/cdrom1
logical name: /dev/cdrw1
logical name: /dev/dvd1
logical name: /dev/dvdrw1
logical name: /dev/scd0
logical name: /dev/sr0
version: CW02
capabilities: removable audio cd-r cd-rw dvd dvd-r
configuration: ansiversion=5 status=nodisc
*-multimedia
description: Audio device
product: IXP SB4x0 High Definition Audio Controller
physical id: 14.2
bus info: pci@0000:00:14.2
version: 01
width: 64 bits
clock: 33MHz
configuration: driver=HDA Intel latency=64
resources: irq:16 memory:c0000000-c0003fff
*-isa
description: ISA bridge
product: IXP SB400 PCI-ISA Bridge
physical id: 14.3
bus info: pci@0000:00:14.3
version: 80
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
configuration: latency=0
*-pci:2
product: IXP SB400 PCI-PCI Bridge
physical id: 14.4
bus info: pci@0000:00:14.4
version: 80
width: 32 bits
clock: 66MHz
capabilities: pci bus_master
resources: ioport:a000(size=4096) memory:c0200000-c02fffff
*-network:0
description: Wireless interface
product: AR2413 802.11bg NIC
vendor: Atheros Communications Inc.
physical id: 3
bus info: pci@0000:05:03.0
logical name: wmaster0
version: 01
serial: 00:c0:a8:c2:cb:b8
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list logical ethernet physical wireless
configuration: broadcast=yes driver=ath5k latency=168 maxlatency=28 mingnt=10 multicast=yes wireless=IEEE 802.11bg
resources: irq:23 memory:c0200000-c020ffff
*-firewire
description: FireWire (IEEE 1394)
product: Firewire (IEEE 1394)
vendor: O2 Micro, Inc.
physical id: 4
bus info: pci@0000:05:04.0
version: 02
width: 32 bits
clock: 33MHz
configuration: driver=ohci1394 latency=64
resources: irq:20 memory:c0211000-c0211fff memory:c0210000-c02107ff
*-generic
description: SD Host controller
product: Integrated MMC/SD Controller
physical id: 4.2
bus info: pci@0000:05:04.2
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm cap_list
configuration: driver=sdhci-pci latency=64
resources: irq:20 memory:c0210800-c02108ff
*-storage UNCLAIMED
description: Mass storage controller
product: Integrated MS/xD Controller
physical id: 4.3
bus info: pci@0000:05:04.3
version: 01
width: 32 bits
clock: 33MHz
capabilities: storage pm cap_list
resources: memory:c0212000-c0212fff
*-network:1
product: RTL-8139/8139C/8139C+
vendor: Realtek Semiconductor Co., Ltd.
physical id: 5
bus info: pci@0000:05:05.0
logical name: eth0
version: 10
serial: 00:03:0d:4d:94:6b
capacity: 100MB/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=64 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10MB/s
resources: irq:21 ioport:a000(size=256) memory:c0210c00-c0210cff
*-pci:1
product: K8 [Athlon64/Opteron] HyperTransport Technology Configuration
physical id: 101
bus info: pci@0000:00:18.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
product: K8 [Athlon64/Opteron] Address Map
physical id: 102
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
product: K8 [Athlon64/Opteron] DRAM Controller
physical id: 103
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
product: K8 [Athlon64/Opteron] Miscellaneous Control
physical id: 104
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=k8temp
resources: irq:0
kim@pc:~$
kim@pc:~$ sudo lshw -c network
*-network:0
physical id: 3
version: 01
width: 32 bits
clock: 33MHz
configuration: broadcast=yes driver=ath5k latency=168 maxlatency=28 mingnt=10 multicast=yes wireless=IEEE 802.11bga
*-network:1
physical id: 5
logical name: eth0
version: 10
capacity: 100MB/s
width: 32 bits
clock: 33MHz
kim@pc:~$
iwconfig - misstänkt!
kim@pc:~$ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
ath0 IEEE 802.11bg ESSID:"dlink"
Mode:Managed Frequency:2.437 GHz Access Point: Not-Associated
Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
kim@pc:~$
