Netbeans vill inte starta
Ubununtu 9.10, 64-bit version. Netbeans vill inte starta. Har provat att ominstallera utan att det hjälpte. Vad är problemet?
Re: Netbeans vill inte starta
Ett bra sätt att kolla vad som är fel är att köra programmen genom terminalen (Program-> Tillbehör->Terminal) och dår får du fram information om varför programmet inte startar.
orion@home:~$ netbeans
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available
-server to select the "server" VM
-cacao to select the "cacao" VM
-zero to select the "zero" VM
The default VM is server.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A : separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -jre-no-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions with specified granularity
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions with specified granularity
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
See http://java.sun.com/javase/reference for more details.
Fixat, det var nån knas med OpenJDK som jag tog bort tidigare. Trodde att Netbeans använde sig av Suns Java moduler vilka jag installerat istället. Efter en OpenJDK installation så fungerar nu Netbeans.
