Pakethanteraren Synaptic startar inte....
rog
Inlägg av rog »
Jag får upp följande felmedelande när jag försöker starta Synaptic.
Ett fel inträffade.
Följande detaljer tillhandahålls:
E: Typ "“deb" är okänd på rad 29 i listan över källor /etc/apt/sources.list
E: Källistan kunde inte läsas.
Gå till förrådsdialogen för att rätta till problemet.
I förrådsmenyn är samtliga val förbockade.
"/etc/apt/sources.list" ser ut så här:
## Major bug fix updates produced after the final release of the
## distribution.
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
# deb http://se.archive.ubuntu.com/ubuntu/ edgy universe
# deb-src http://se.archive.ubuntu.com/ubuntu/ edgy universe
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://se.archive.ubuntu.com/ubuntu/ edgy-backports main restricted universe multiverse
# deb-src http://se.archive.ubuntu.com/ubuntu/ edgy-backports main restricted universe multiverse
# deb http://security.ubuntu.com/ubuntu edgy-security universe
# deb-src http://security.ubuntu.com/ubuntu edgy-security universe
deb http://www.getautomatix.com/apt edgy main
“deb http://www.getautomatix.com/apt edgy main�
deb http://archive.ubuntu.com/ubuntu/ edgy universe main multiverse restricted
deb-src http://archive.ubuntu.com/ubuntu/ edgy universe main multiverse restricted #Added by software-properties
På rad 29 står nåt om Automatix som jag nån gång försökte installera.
Kan det ha med saken att göra??.. Kör Ubuntu 6,10
Tacksam för hjälp :)
iveqy
Inlägg av iveqy »
det kan absolut hame ddet att göra. Hela den raden ser felformaterad ut. Du kan ta bort den utan problem. Så bordet det funka igen
rog
Inlägg av rog »
Tack för snabbt svar.
Försökte att ta bort den i textredigeraren men jag får inte spara filen efter; nåt om behörighet. Kan jag göra det på annat sätt?
iveqy
Inlägg av iveqy »
du måste vara root för att öppna den. Öppna din terminal och skriv
sudo gedit /etc/apt/sources.list
Petri
Inlägg av Petri »
[quote="iveqy"]du måste vara root för att öppna den. Öppna din terminal och skriv
[/quote]
INTE sudo
gksudo om det ska vara något pprogram med grafiskt gränssnitt
Det fungerar att göra så men risken att sabba X finns. Jag tror jag har förstört två installationer på så vis.
Terminalbaserade kommandon som behöver root rättigheter: sudo
Grafiska program som vill ha root rättigheter: gksudo
People willing to sacrifice freedom for temporary security will loose both and deserve neither.
rog
Inlägg av rog »
Tusen tack.
Nu e det åtgärdat :))
iveqy
Inlägg av iveqy »
just gedit har inga problem att använda sudo. Men du har rätt i att man bör undvika det. Mitt fel, använder aldrig en grafisk editor själv...
